BAS/ASR - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 07-30-2013, 03:05 PM Thread Starter
Date registered: Jun 2013
Vehicle: 1998 E320 W
BAS/ASR
Hi,
Just last week I completed a switch out of the electronic controller plate and pressure sensor spring in the transmission. I followed G-AMG's DIY process posted in the sticky section. It worked beautiful for about 500 miles but last night I got the ASR warning light on and then it changed to BAS, I got home and read in the owners manual and it says to get it to the dealer(naturally).
I had to drive it today for work but on the way home I got to a stop light and lo and behold, I only had the rev of the engine, no movement. What? I just fixed this I said. I limped home having to stop every 200 feet to turn off the car and let the transmission reset. Each time I restarted the car it would flash the BAS warning and then change to ASR and as soon as it did that I would loose my forward momentum like it had been shifted into neutral. I was so happy with the other fix but now I am bummed. Any of you had anything similar?
Thanks
Garth
GarthsMB is offline
post #2 of 16 (permalink) Old 07-30-2013, 05:31 PM
Date registered: Feb 2010
Vehicle: 2007 E320 Bluetec, 2008 320ML CDI
Quoted: 102 Post(s)
The search function is your friend.
Here's two possible/maybes.
http://www.benzworld.org/forums/w210...ke-lights.html
Common theme is brake light switch and/or battery voltage.
Skippy
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
SkippyJasper is offline
post #3 of 16 (permalink) Old 07-30-2013, 06:35 PM Thread Starter
Skippy,
Thanks for your response. I had looked at these posts but they didn't seem like they matched my problems. I am going to change the switch and the battery but I am most concerned with the ASR warning light affecting the transmission. Any thoughts?
Thanks again
Garth
GarthsMB is offline
post #4 of 16 (permalink) Old 07-31-2013, 03:37 AM
Quoted: 102 Post(s)
I'd start with the brake switch, dealer only part. The battery may be fine, you know best on its age and condition.
These cars are sensitive to low voltage so having clean and tight connections can cure a host of problems.
Leave the ASR light to last. It may get cured by the other actions.
Skippy
Sent from AutoGuide.com App
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
post #5 of 16 (permalink) Old 08-01-2013, 04:38 PM Thread Starter
Skippy, I did the brake light switch change out and sure enough, the BAS/ASR lights disappeared. I was delighted. (no pun intended) The engine electronics warning and the CEL were still lit but it seemed to be shifting and working well. I was headed to my friends house to have the warning lights cleared and the trans shifted into high gear and then it just acted like it was in neutral. rev goes the engine and it's off to the side of the road I go. Then it was the painful task of getting back home having to stop every few hundred yards to shut of the engine and wait for the transmission to reset. I would shift through the gears and then it would just stop driving the wheels. Neutral. Got any ideas?? Any help would be much appreciated.
GarthsMB
GarthsMB is offline
post #6 of 16 (permalink) Old 08-01-2013, 06:55 PM
Quoted: 102 Post(s)
When you started the conductor plate journey, was the car running OK? No CEL?
Possible that the TCU has a fault code stored which will require a better scanner to reset.
Did you replace the electric connector?
Correct amount of fluid?
Skippy
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
post #7 of 16 (permalink) Old 08-01-2013, 07:22 PM Thread Starter
The car was not working properly. I had been doing research on what to do about the shifting problems and determined to do the conductor plate change out. I followed the picture process the G-AMG did, found in the sticky section. I replaced it all and refilled the trans with proper fluid. I knew that in order to get it out of limp mode that I would need to have the CEL and the other codes cleared. I drove it in limp mode after the work was completed to a independent MB mechanic and he cleared the codes out of the TCU. It ran great for 500 or 600 miles until I started to get the BAS/ASR warning lights and then the transmission started to act up again. I am confident in the work that was done but I'm sure perplexed on what could be causing this now. Any ideas??
Garth
GarthsMB is offline
post #8 of 16 (permalink) Old 08-01-2013, 07:29 PM Thread Starter
I am going to the independent MB shop in the morning to have a scan done again. I will see what codes are stored and at what level. I'm sure curious what the problem is. I am finding that these cars are quite temperamental so I need to stay on top of the diagnostics.
Thanks for the attention
Garth
GarthsMB is offline
post #9 of 16 (permalink) Old 08-02-2013, 04:59 AM
Quoted: 102 Post(s)
I'd be inclined to think the BLS problem is separate from the transmission.
Now that you replaced it its back to the trans.
Maybe I missed it, but did you evaluate the electric connector in the trans? I realize you had it off to do the plate, but it is a source of problems.
Hopefully you trip to the Indy will travels something more definitive.
Skippy
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
post #10 of 16 (permalink) Old 08-02-2013, 09:53 AM Thread Starter
Are you talking about the connector that has the leak problem that wicks up the harness? I replaced it with the updated one from MB. However, I had no leak problem and the TCU was dry and looked very clean.
Thank you for your help.
Garth
GarthsMB is offline
