1999 E300TD Oil Leak - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 01-28-2013, 08:53 AM   #1 (permalink)
Date registered: Aug 2011
Vehicle: 1999 E300TD
Hello everyone,
I have unfortunately sprung a leak in my 1999TD. The oil looks to be leaking down the front drivers side and is collecting under the bumper and just behind the wheel.
The engine seems to have oil all over the front drivers side, though I can't isolate it coming from a certain hose or area. Nothing seems to be overtly loose.
The drip began yesterday after driving the car for 15 min on my way home. In that time, aprox 3/4 of the oil has drained out.
Is there a common problem I can be looking for or a way to address this DIY? Getting a tow to the dealer is not appealing!
Please let me know and thanks!
1999 E300TD Oil Leak-oil-leak-6.jpg   1999 E300TD Oil Leak-oil-leak-7.jpg   1999 E300TD Oil Leak-leak-8.jpg   1999 E300TD Oil Leak-leak-9.jpg   1999 E300TD Oil Leak-leak-10.jpg
1999 E300TD Oil Leak-leak-11.jpg   1999 E300TD Oil Leak-leak-12.jpg   1999 E300TD Oil Leak-img_2156.jpg   1999 E300TD Oil Leak-img_2164.jpg   1999 E300TD Oil Leak-img_2169.jpg
ALLTD is offline   Reply With Quote
Old 01-28-2013, 01:14 PM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 1999 E300DT
You're certainly not going to isolate it until you thoroughly clean the area.
1) Remove plastic undershields from vehicle
2) Degrease with an appropriate engine cleaner
3) Fill crankcase to proper level with oil
4) Start engine letting it reach operating temperature and check for leaks with a good flashlight
5) Post your findings
Looks like a leak somewhere in the engine oil cooler circuit. Perhaps you will get lucky and just find a bad o-ring and / or loose connection?
NOT a common problem as far as I know.
This should be TOTALLY DIYable.
1982 320i
1998 M3
1999 E300DT
2005 Pathfinder LE
Dave1965 is offline   Reply With Quote
Old 01-28-2013, 01:56 PM   #3 (permalink)
Kajtek1's Avatar
Vehicle: W210 E300DT x2 / Ford SD, JDtractor. Seeking diesel lawnmower
I see pretty corroded oil cooler pipe, but as Dave said, if you want to pinpoint it you have to wash it.
Go to EPS, or Russian site for check if the pipe is separate pipe, or comes with cooler.
Kajtek1 is online now   Reply With Quote
Old 01-28-2013, 02:33 PM   #4 (permalink)
Ok,thanks Dave. So I should be taking the plastic undershield off the front and clean. Should I be doing some kind of full engine wash as well? Then put some oil back in, turn on the car and it should be easier to find the leak... Thanks Kajtec1, I'll look into that.
Old 01-28-2013, 11:40 PM   #5 (permalink)
Well I'm having fun so far! I was about to take the plastic undercover off when I noticed a few things:
1. This fancy hose is not attached to anything and has oil on the detached end.
2. This cool cylinder thing with the two black hoses attached, makes a strange electronic sounding, sucking-type noise for a minute, after the car is turned on.
3. This black pipe, behind the rusty (oil cooler pipe?) POURS oil as soon as the car is turned on. Weather it is actually coming from there, or somewhere else...? I can take the cover off tomorrow unless these clues help? I attached these new pics to my first thread post, not sure how to add pics in a reply.
Old 01-29-2013, 08:13 AM   #6 (permalink)
Kajtek1's Avatar
Looks like you have some vacuum system disconnected. Any codes?
I wold worry about oil leak first as it is going to be hard to restore vacuum controls in this mess.
The noisy cylinder is tank pressure purging valve from what I remember - some noise from it is normal.
Old 01-29-2013, 11:24 AM   #7 (permalink)
I would just wash off the obviously oil-covered parts. Save the "Full Engine Wash" for when you get everything fixed.
Here's a link from another forum which may help you in "visualizing" the leak:
W210 oil cooler - Mercedes-Benz Owners' Forums
Another one as well:
OM606 oil leak - PeachParts Mercedes ShopForum
Please post pics of when you get everything removed?
Old 01-31-2013, 10:06 AM   #8 (permalink)
Ok, finally got under back under there!
Kajtek1, I just have the check engine light on right now - this could possibly be the cause? The engine runs rather noisy, even for a diesel!
Dave, thanks for the links, looks like that's what I have going on here! I've got some new pics uploaded. I was confused by the leak before - in the second last pic - the oil is spraying everywhere from a corroded pipe! So this pipe is the oil cooler pipe?
The links you posted have me a little worried, saying it requires superhuman strength to change the part! Is it a complicated fix and when I go to order the new part, I can just tell the shop it's an oil cooler pipe for a 1999 E300TD?
I've also noticed that my hood will not shut now :/ I am researching this too. All accounts are of a latch or a cable prob. The latch on the drivers sides seems stuck, very little range of movement. Preferably I would like to get the part(s) to fix this when I make the journey across the earth to a parts shop!
Old 01-31-2013, 02:05 PM   #9 (permalink)
Kajtek1's Avatar
Should not have to go that far for parts in Toronto?
I hope you have another ride while you are dealing with it. Sounds like the pipes and cooler cost pretty money, so I would first take it apart to see what is the problem and than spend my money. Some steel pipe corrosion can be brazed for less than high prices I see in other topics.
Disconnected vacuum pipes should trigger CEL. Search for vacuum system diagram on this engine.
Old 01-31-2013, 02:43 PM   #10 (permalink)
I actually have the MB dealer fairly close. I figure buying the part from a non-dealer German part supplier might be cheaper, but they are on the outskirts of the city, I'll be looking into prices.
The actual leak is spraying out of the metal pipe, which we can see is badly corroded. Is it just the pipe I can replace or the whole... cooling system? On another thread someone said the pipe is cheap. It should prob be replaced as oppose to brazed?
And no other ride unfortunately! I need the wheels! I'll check for that diagram..
Bookmarks
