transmission dipstick tool--what and where to buy? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 01-01-2013, 09:23 PM   #1 (permalink)
Elvis_Presley's Avatar
Date registered: Apr 2011
Vehicle: 2002 e320 4matic Wagon
Can someone link me to a good one for a decent price?
I've decided to buy something better than my homemade one.
Thanks
Elvis_Presley is offline   Reply With Quote
Old 01-02-2013, 02:46 AM   #2 (permalink)
EMatic430's Avatar
Date registered: Mar 2012
Vehicle: 2001 E430 4Matic
eBay sells them.
EMatic430 is offline   Reply With Quote
Old 01-02-2013, 10:39 AM   #3 (permalink)
Date registered: Jan 2004
Here you go:
Mercedes 722 6 Transmission Fluid Dipstick Repair Tool | eBay
Len
'59 220S Cabriolet
'83 240D original owner 348,000 miles
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 170,000 miles
'03 SLK320 27,000 miles
sokoloff is offline   Reply With Quote
Old 01-02-2013, 11:16 AM   #4 (permalink)
Kajtek1's Avatar
Vehicle: W210 E300DT x2 / Ford SD, JDtractor. Seeking diesel lawnmower
Why would you spend $30 for something that will take space in your garage unused for the years to come?
The steel cable I already had worked perfectly for me. A bit harder to read, but than it coils conveniently when I don't use it.
There is the question if the factory dipstick stop 5 mm from the bottom of the pan, so you might want to adjust the scale, but 5 mm is well withing tolerance of fluid level and I did not have a problem with it.
Actually if one of the MB dipstick owners could measure the length that goes in before stop,that would be very helpful
Kajtek1 is online now   Reply With Quote
Old 01-02-2013, 02:31 PM   #5 (permalink)
Date registered: Nov 2006
Vehicle: 2002 e320
I vote for (and have) the ebay one. It stores pretty easily coiled up.
pvel is offline   Reply With Quote
Old 01-02-2013, 02:56 PM   #6 (permalink)
Vehicle: E320 Yr 2000, S430 YR 2002
I agree that all we need is a "springy" wire with a couple of notches at the end. The Ebay part is advertized as :
Length from tip to handle 45 1/2"
However, I suspect that there is a handle included in that measurement, so the stick should be smaller than this ?
dilsingh is offline   Reply With Quote
Old 01-02-2013, 04:44 PM   #7 (permalink)
Vehicle: 2002 e320
http://www.benzworld.org/forums/w210...ml#post3647178
Here are the dipstick dimensions for those wanting to make one.
Old 01-02-2013, 07:00 PM   #8 (permalink)
Kajtek1's Avatar
The stick is much longer than needed, so the tool length is not helping.
I did measure how much my steel cable goes in as the last bend in the tube require strong push and is easy confusing the measurements.
The issue is that the factory tool has a bigger square on the end of plastic scale, that supposed stops the dipstick few mm above the bottom of the pan, where the cable goes. Figuring out that distance would be helpful even the 5 or so mm is not crucial.
Old 01-05-2013, 05:49 AM   #9 (permalink)
atmsmshr's Avatar
Date registered: Jul 2009
Vehicle: Current - 2002 S430, 1997 E420; 1998 ML320. Deceased - 1974 240D, 1992 400E
Location: An island off the coast of Florida **Use startekinfo.com for official Mercedes technical guidance**
Some of the pros and cons of a home made versus a manufactured transmission dipstick are in this thread.
IMHO - home made dipsticks carry too much risk compared to buying a $30 tool. This thread shows one member who made a dipstick, and then compared it to a MB dipstick, noting that the ATF was too low with the home made by 10-15mm.
http://www.benzworld.org/forums/w210...ans-fluid.html
atmsmshr is offline   Reply With Quote
Old 01-06-2013, 06:30 PM   #10 (permalink)
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(165K Miles), 2002 E320 Special Edition(147K Miles)
Debate of home-made versus $30 for correct dipstick bring to mind the saying 'Penny wise, pound foolish'.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Bookmarks
