De-oiling and Decalcifying radiator? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 11-19-2012, 09:39 AM   #1 (permalink)
squirrelonfire's Avatar
Date registered: May 2008
Vehicle: 1998 Mercedes E320
Send a message via AIM to squirrelonfire Send a message via MSN to squirrelonfire Send a message via Yahoo to squirrelonfire
Guys,
I've been reading many threads online, people say to use 2 additive to de-oil and then de-calcify the radiator to flush it. They give 2 parts for 2 different additive but when I called MB of south atlanta, they said those 2 parts# are the same the product. So what gives?
De-oil - A.001.986.21.71
De-calcify - A.000.989.10.25
I always order part from here
If you search for either of those parts, the result comes up with the new same part # 000989102511 / LEMON ACID
So do I just need to buy 1 bottle of this lemon acid to flush the radiator?
squirrelonfire is online now   Reply With Quote
Old 11-20-2012, 04:11 PM   #2 (permalink)
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(165K Miles), 2002 E320 Special Edition(147K Miles)
If you really got oil in the coolant, it will take several flushes over a period of several days. Basically add the citric acid, drive a few hundred miles, drain and repeat until water is no longer oily. Replace all radiator hoses afterwards since the oil would have affected them.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Old 11-20-2012, 04:19 PM   #3 (permalink)
Kajtek1's Avatar
Vehicle: W210 E300DT x2 / Ford SD, JDtractor. Seeking diesel lawnmower
I don't think you have to worry much about oil. It is impossible to get it out anyway. Year ago I bought a truck that had radiator replaced because the transmission cooler in it broke and radiator got ATF, while transmission got coolant.
The dealer who replaced the radiator did not worry about flushing the systems, so I had the radiator flushed 3 times before putting MB coolant (!) into my truck. Since than the coolant still shows some oil residue on the top, that I keep skimming for a year.
I would assume some oil might be actually good for the system
It is the calcium build up that will give you big headache.
I have never seen MB citric acid, so when you get it - post a picture of the label?
Kajtek1 is offline   Reply With Quote
Old 11-20-2012, 06:35 PM   #4 (permalink)
The only oil I got is that water wetter.
Also in reply to your comment, did you suggest me to refill the radiator with water and drive normally for a few hundred miles? Then do that again may be say 3 times?
Doesn't my car will over-heat / freeze like there's no tomorrow?
Old 11-20-2012, 07:23 PM   #5 (permalink)
Kajtek1's Avatar
Don't know about driving for hundreds miles. Maybe MB cleaner require that, but Prestone flush wants only get the engine warm on driveway, although I prefer to drive since my diesel takes 3 days to warm up idling.
Distillate water flushing trick is to operate it with thermostat open and heater core running before dumping, so few miles drive is all you need.
Old 11-20-2012, 07:30 PM   #6 (permalink)
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Look - I guess you are trying to accomplish something important to you.
So you know most of this stuff applied to older cast iron engine blacks and liners and not to modern aluminum/alloy engine blocks.
1) For oil residue you use Shout liquid gel for s non-suds detergent. Do a google.
2) You have a aluminum/alloy Mercedes engine - not to be confused with the olld cast iron block engines - any citirc acid based cleaner will do, and ONLY dose per instructions AND you will need new t-stat and new expansion tank cap.
Nonsense for driving with a acid flush, or a detergent flush either, all is done at idle for circulation - usually 10 minutes max..
The KEY to both procedures is REPEATED and THOROUGH flushing with clean hose water.
fabbrisd1 is offline   Reply With Quote
Old 11-21-2012, 07:26 AM   #7 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2010 E350(R.I.P) 2011 E350
On the KlunkerWagen, I used "Simple Green" and MB Citric Acid combo.
First, MULTIPLE simple green flushes, followed by 3 Citric Acid doses. I only left the Acid in 15 minutes at a time. I certainly WOULDN'T go "several hundred miles"!
Kaj, here is what you were looking for?
G-AMG is offline   Reply With Quote
Old 11-21-2012, 08:32 AM   #8 (permalink)
Kajtek1's Avatar
Thanks G AMG, but how about the label with instruction?
My vehicles run very cool, some of the with fans removed but you never know when you get another car with dirty coolant.
Old 11-24-2012, 03:58 PM   #9 (permalink)
Date registered: Jan 2004
If your system has been serviced regularly and the coolant coming out is nice and clear/clean, then there is probably no need to deoil and descale. If you feel like doing that, then the citric acid alone is NOT a deoil product. That's only for descaling. Mercedes instructions call for deoiling before descaling even if there is no evidence of oil in the system. The Shout or Liquid Tide is what will do the deoiling for you. Then follow up with the citric acid to descale rinsing everything thoroughly as has been suggested above. Citric acid can be bought online and also in the canning department of many grocery stores.
Len
'59 220S Cabriolet
'83 240D original owner 348,000 miles
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 170,000 miles
'03 SLK320 27,000 miles
sokoloff is offline   Reply With Quote
Old 11-24-2012, 11:54 PM   #10 (permalink)
The 22oz bottle of Permatex 80032 Heavy Duty Aluminum Radiator Flush (Cooling System Flush) most rave is much better than citric acid alone. It's sold in a good # of stores or online, cost effective OK under $18
I have attached the instructions and pdf file of the MSDS listing the contents.
Unless you have severe oil/tranny fluid mix - this "one step" formula has emulsifiers that take care of "normal" oil/film scum as well.
As noted by the instructions, needs to be followed with earnest flushing, and that immediately followed by correct coolant (MB or G05) any water mix needs to be distilled for proper neutral ph.
Bookmarks
