Oil level at minimum - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 10-23-2012, 06:25 AM Thread Starter
squirrelonfire's Avatar
Date registered: May 2008
Vehicle: 1998 Mercedes E320
Send a message via AIM to squirrelonfire Send a message via MSN to squirrelonfire Send a message via Yahoo to squirrelonfire
Hey guys,
I changed my oil last night. I sucked out 7.5 liters. And I put back 6.5. Then this morning the warning light came on telling me oil level is at minimum.
Several threads say I need to change the oil level sensor. Do I have to do this? I am fine by checking the oil using the dipstick.
squirrelonfire is offline
post #2 of 12 (permalink) Old 10-23-2012, 07:06 AM
Musikmann's Avatar
Quoted: 6 Post(s)
What is the level on the dipstick? If your oil level sensor does not match the stick level then the sensor is obviously off. Personally, I would live with it being off rather than going to the trouble and expense of replacing the sensor.
BTW, the best time to check the level by either method is about 10 minutes after you turn the car off and still at proper operating temperature.
Musikmann is offline
post #3 of 12 (permalink) Old 10-23-2012, 07:34 AM
Date registered: Jan 2012
Vehicle: 2001 430T 4Matic, 1999 735iA
Quoted: 14 Post(s)
Originally Posted by squirrelonfire View Post
Hey guys,
how does that work??? 1 liter missing is enough to get the message...
wouldn´t logic dictate "7.5 Liters out, 7.5 Liters back in?"
MeMySelfundIch is offline
post #4 of 12 (permalink) Old 10-23-2012, 07:42 AM
gurunutkins's Avatar
Vehicle: 2001 E320 wagon
Quoted: 20 Post(s)
you are probably way short. the capacity on my 2001 e320 is 8.5 US quarts or 8 litres. You do need more oil
check your dipstick is the right one and that you are on the level testing the oil
cheers
Barri
2001 e320 wagon, 1973 350sl euro, 1974 450sl, 1976 450sl, 1978 450 slc euro
gurunutkins is offline
post #5 of 12 (permalink) Old 10-23-2012, 07:48 AM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 121 Post(s)
Ditto - definitely check/fill using the oil stoick. The dash reading is for reference only - and the design of the sensor is so you get a electronic warning message when "low" - and was never intended to be used as the authority for oil level.
Frankly your #'s on the refill/top-off sound off - usually up to a 1/2 more need to be refilled as compared to removal to compensate for the oil, taken out with the filter removal. .
Recheck with the dipstick - and go from there - keep the beat !
fabbrisd1 is offline
post #6 of 12 (permalink) Old 10-23-2012, 09:26 AM
Kajtek1's Avatar
Quoted: 1166 Post(s)
Where are the threads that say you need to replace sensor when you are low on oil?
Kajtek1 is online now
post #7 of 12 (permalink) Old 10-23-2012, 12:10 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Good point Kajtek1, I can't remember any either!
post #8 of 12 (permalink) Old 10-23-2012, 12:14 PM
magna steyr 210.282's Avatar
Date registered: Sep 2012
Vehicle: 2000 Merc. E320 4matic Wagon 210.282 Desert Silver
ROFL!
Ethanol is the devil.
magna steyr 210.282 is offline
post #9 of 12 (permalink) Old 10-23-2012, 03:34 PM
Kajtek1's Avatar
Now I can only wonder what "put the oil back" means
No offense Squirrel, but you need to chose your wording wisely.
that unless you are on fire.
post #10 of 12 (permalink) Old 10-23-2012, 06:00 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Just for future reference, should you decide to change the air in your tires, don't weigh what you remove in order to try and figure out how much to refill. Just add air until they are properly inflated.
Check Codes is offline
