Blinking low fuel light. - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 07-22-2012, 06:56 AM Thread Starter
Date registered: Jul 2012
Vehicle: 1999 E320
I have looked through forum and wanted to see what others thought. This all started after filling up and the gas pump not shutting off and overflowing I also have a P0442 code. From what I have read I think my charcoal canister might be full of gas and I should remove it and try and drain it.
be320 is offline
post #2 of 11 (permalink) Old 07-22-2012, 02:50 PM
Musikmann's Avatar
Quoted: 6 Post(s)
For that very reason I always stay with the handle until the pump shuts off. I learned my lesson with another car but all that happened then was I wasted some money. You seem to be on the right track with your proposed solution.
Musikmann is offline
post #3 of 11 (permalink) Old 07-22-2012, 03:01 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 122 Post(s)
"Normaaly" from one overfill that light "should" clear itself off in about 3 - 4 weeks of daily driving or so. Nothing with that warning light is damnin.
So the experienced answer is "wait" - and can be helpful if you drive with no more than 3/4 tanks for awhile.
While you are focused back there - take that 110K gas cap rubber gasket, pull it and reverse it putting back/fresher side up..
Keep the beat !
fabbrisd1 is offline
post #4 of 11 (permalink) Old 07-22-2012, 07:28 PM Thread Starter
Vehicle: 1999 E320
Cleared the code twice now. It has stayed off although I have not driven it much. But the blinking light came back on and it is very annoying. It does go back off after turning car off and restarting. Just reversed rubber seal and it was part wet. Also the tank is full right now
be320 is offline
post #5 of 11 (permalink) Old 07-23-2012, 08:45 AM
Musikmann's Avatar
Quoted: 6 Post(s)
If the code is staying off that is a good sign. I know it's annoying but drive the car more and what fabbrisd1 said is probably the easiest solution. If you feel that ambitious, go ahead and remove the canister and try to drain it.
post #6 of 11 (permalink) Old 07-23-2012, 10:48 AM Thread Starter
Vehicle: 1999 E320
Thanks, the code did come back. I will at lest wait until this weekend
be320 is offline
post #7 of 11 (permalink) Old 07-23-2012, 11:11 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If the tank is still full, you need to drive it. A lot. You're not going to be able to test any effects of anything you do while it's still full. After all, a full tank with probable gas in the canister isn't going to magically fix itself with a couple of trips to the grocery store...
Check Codes is offline
post #8 of 11 (permalink) Old 07-23-2012, 01:10 PM
Vehicle: Mercedes W210 E320 wagon
I had pretty similar issue, with code P0455.
New Purge valve with new hose and pair of clamps fixed this issue.
Originally, this hose was attached without clamps (I think this was an issue).
A0004703593 - purge valve
A1200780381 - out L pipe.
new rubber hose I bought in Advanced Auto parts store.
Bansai is offline
post #9 of 11 (permalink) Old 07-23-2012, 08:17 PM
Quoted: 122 Post(s)
Drive for 2-3 weeks running less than 3/4 tank which gives the cannister time to breath - and reverces the gas cap gasket to help - and you have 75%-80% chance to clear the deal for good... replace the purge valve, what-the-heck for since even if that was indicated at startup, cleaning normally takes care of that entirely a different issue in my mind..
post #10 of 11 (permalink) Old 09-05-2012, 08:51 PM Thread Starter
Vehicle: 1999 E320
Well I have waited almost six weeks and still the same. What should I do next to fix this?
be320 is offline
