Question on leaking washer reservoir? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 07-18-2012, 05:50 AM   #1 (permalink)
spartan10's Avatar
Date registered: Sep 2008
Vehicle: 2001 E320 4DR Sedan
Hello all - long time. Car is a 2001 E320 for reference.
Wiper fluid reservoir is leaking. Started recently.
Removed the unit from car, cleaned everything, tank seems to be fine, replaced old cap with new one, replaced rubber grommet at pump to tank fitting with new one and checked pump hose fitting. Now it is leaking worse of course.
Leak source is definately at the pump grommet, hose fitting area. It almost appears that the pump itself is leaking. Anyone ever experienced this. Seems plausible since it started suddenly instead of gradually and the old rubber grommet was in decent condition.
Also - as long as we are at it - why is there a short loop of " wire " on the end of the hose at the washer pump. It seems to only go into the hose an inch or so and I cannot figure it out. Loop to go around pump stem into tank? I'd like to cut the hose off to get some fresh material for the clamp to nipple fitting, but ??????
TIA and have a great day.
spartan10 is offline   Reply With Quote
Old 07-18-2012, 06:59 AM   #2 (permalink)
Vehicle: 2002 E430 4-Matic
I had similar symptoms when the pump went bad. Didn't want to spend the money to r&r so I had the pump removed and the system plugged.
A word of caution - I always thought that that spray system was worthless. And I didn't buy the argument about HIDs needing a headlight washer to reduce glare.
Well I found out otherwise in a snowstorm. The lights didn't generate enough heat to melt the snow accumulating on the headlights and after about 50miles the lights were pretty well covered with slush and ice - greatly reducing light produced.
Figuero is online now   Reply With Quote
Old 07-18-2012, 08:10 AM   #3 (permalink)
Darkmann's Avatar
Vehicle: 05 500
I have same problem on my 01 430. Haven't had time to look very close at it yet, but my guess is that it's the pump itself. How did you get the thing apart - can you write up some steps? Thanks.
1996 Z32 TT
A 18Hp lawn mower
370Z - I want one!
Darkmann is offline   Reply With Quote
Old 07-18-2012, 08:11 AM   #4 (permalink)
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Figuero, I think Spartan is talking about the windshield washer, not the headlight.
Spartan, please click user cp and edit details to add your vehicle and location to your profile, it's often useful information when you're seeking assistance.
The wire is a heater to keep the fluid from freezing in the line, it runs up to the nozzles.
I can't remember hearing about a pump leaking, but I suppose anything is possible. If you're 110% sure the leak is not at the grommet, then the next step would be to try a different pump. Maybe a unit from a wrecking yard just as a test?
Good luck.
Check Codes is offline   Reply With Quote
Old 07-18-2012, 11:53 AM   #5 (permalink)
Premium Member
dlafever's Avatar
Date registered: Jan 2004
Vehicle: 2002 ML320, 2001 E430
Premium Member
Send a message via AIM to dlafever Send a message via Yahoo to dlafever
Some additional data, just to confuse things. There are indeed two different pumps as well as two unique grommets for these pumps. For my 2001 E430, they are as follows;
Headlamp washer pump 210 869 11 21
Headlamp washer pump grommet 010 997 11 81
Windshield washer pump 210 869 02 21
Windshield washer pump grommet 123 997 36 81
I doubt they would be different for your E320, as long as you have the factory HID lights with washers. And YES, mine has started leaking last year and I have not fixed it yet, mostly because we get so little rain here in the desert. I have an upcoming fender/bumper repair and paint project and plan to restore operation at that point.
dlafever is offline   Reply With Quote
Old 07-18-2012, 03:06 PM   #6 (permalink)
Date registered: Oct 2011
Vehicle: 2001 E 320
Mine leaked on the left side where a circle of plastic from the molding process was formed. I took a hot glue gun and pumped on about 2 sticks of hot glue and let it sit empty of fluid overnight. No problems ever since, the hot glue melts the washer bottle plastic and seems to make a really good bond.
2001 Mercedes E 320
2006 Ford F-250
2003 Mazda MPV
2006 Forest River Sandpiper 325 BHD Fifth wheel
welfarewagon is offline   Reply With Quote
Old 07-18-2012, 03:33 PM   #7 (permalink)
spartan10's Avatar
Thanks to all for the input.
For clarification it is the windshield wiper reservoir tank. The grommet I got came from local MB dealer parts counter and I indentified it on the schematic as being the correct part. Same with the cap.
The heating wire element is interesting. I wonder if it really works. Never gets cold enough where I live to test the application.
I plan to remove the assembly again, drain, dry and silicone seal the plug and pump in place. If this fails I'm convinced it is the pump body.
Acute failure as mentioned before also lends credence to this.
Thanks to all again. My regards.
Old 07-18-2012, 04:09 PM   #8 (permalink)
Spartan, please follow up with your results as time permits.
BTW, I LOVE your avatar. I NEED MORE COWBELL!!!
Old 07-18-2012, 04:26 PM   #9 (permalink)
brandon671's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes-Benz 420 SEL(RIP),1997 Mercedes-Benz E420
What was that???!
More Cowbell?!
Okay! *DING DING DING DING* lmao. Read this post if it helps. http://www.benzworld.org/forums/w210...order-way.htmlMy reservoir heater was changed and it took me about 20 minutes with simple tools.
brandon671 is offline   Reply With Quote
Old 07-18-2012, 06:35 PM   #10 (permalink)
Date registered: Aug 2005
Vehicle: 1999 E320, 2001 E320
http://www.benzworld.org/forums/w210...appearing.html
Originally Posted by cerritos View Post
After trying every possible ways to fix the leak, I finally bought a new washer fluid reservoir and a new pump grommet. That fixed the problem.
Oh, actually, a new pump also.
I was so sick and tired of that problem, I just went ahead and replaced everything involved. I have more important things to do, you know.
BTW, mine is also a 2001 E320 4DR Sedan.
You may want to try this sequence:
1. replace pump and grommet
2. if it does not fix the leak, replace the tank also.
In my case, I don't see any crack at the tank, no crack/leak at the pump, replaced the grommet numerous times with different brands, tried every possible way to seal it. Eventually, replaced every thing. Fixed.
About the wire:
http://www.benzworld.org/forums/w210...dded-hose.html
I hope you didn't cut it. I soldered mine back together and wrapped it with heat shrink tube. I cut the "hose end" in an attempt to fix this leak.
cerritos is offline   Reply With Quote
Bookmarks
