Can someone please post the part number for the xenon headlight level sensor - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 07-13-2012, 11:48 PM   #1 (permalink)
brandon671's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes-Benz 420 SEL(RIP),1997 Mercedes-Benz E420
the connecting rod(#4) is broken at the joint. There is no more plastic piece to hold that "ball joint" in place. Can someone please post the part number for this, I assume its a dealer only item cause I can't find it on aftermarket sites.
This part according to the site is called the, "Front Axle Headlamp Range Adjustment Sensor"
for 1997 E420
Thanks
Brandon
Can someone please post the part number for the xenon headlight level sensor-83533533.gif
brandon671 is offline   Reply With Quote
Old 07-14-2012, 01:38 AM   #2 (permalink)
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2000 S210 E320CDI Avantgarde
Send a message via ICQ to renault12ts Send a message via AIM to renault12ts Send a message via MSN to renault12ts Send a message via Yahoo to renault12ts
2103203089
renault12ts is offline   Reply With Quote
Old 07-14-2012, 04:56 AM   #3 (permalink)
brandon671's Avatar
Thank you
Old 10-19-2012, 03:02 PM   #4 (permalink)
brandon671's Avatar
Hey guys I'm following up on this part. The arm or rod has separated on both the front and rear axle and I want that cool factor on my headlamps when they adjust themselves...I've only witnessed this on a 98 CL500 which a BMW dealership let me take home for a weekend to test drive, amazing car.
Anyways I've only found Mercedes Benz of south Atlanta that has this part. Where else could I get this?
It separated at the number 4 mark.
ROD. for Mercedes (2103203089)
Old 10-21-2012, 05:30 PM   #5 (permalink)
brandon671's Avatar
This thread may be better to use than my http://www.benzworld.org/forums/w210...t-does-do.html post since it already has a diagram and part number.
Still calling up multiple dealerships to find it. Unfortunately it's Sunday in most parts of the mainland and parts departments are closed.
Heck I'll even order from china or Russia if I have to. In the meantime, please post where you think I can find this part. Thanks
Old 11-10-2012, 03:53 AM   #6 (permalink)
brandon671's Avatar
So heres an update.
I couldn't find it anywhere. So I called several MB dealerships some in CA, TX, HI, and others. I found one on ebay but the seller only sold the rod with the adjustment sensor. I reached MB of Cincinnati and ordered the part through them. Overall it only cost about $35 which included shipping.
According to ALLDATA if the sensor(A52) were to be replaced you'd have to program using something called "HHT"...what is this? It says to program at zero position.
Do you think it needs to be programed again if it were not disconnected? If I do need a programming and it is only a MB tool then I'll have to turn it in for programming at a shop.
I can see the rear rod is also not attached...I'll order this one if it can't be repaired, I haven't thoroughly checked.
Just a tip.
MB of Honolulu does not return calls. I must have left 2 messages over a period of a few months.
Can someone please post the part number for the xenon headlight level sensor-img_0518.jpg
Old 11-10-2012, 08:57 AM   #7 (permalink)
My rear rod broke at one end. I ordered a new one...but while waiting for it to arrive I drilled it and fitted a nut and bolt. That was three years ago. I still have the new rod for when the temporary fix fails!
Old 11-10-2012, 04:17 PM   #8 (permalink)
brandon671's Avatar
Interesting if you have the time can you post a pic of yours? I'm surprised there's not much info on this in the search function. If I can do what you did that'd be fine with me as long as it works.
Old 11-11-2012, 03:02 AM   #9 (permalink)
It's a ball and socket affair. The ball sits in a nylon socket. I drilled through the nylon socket. Can't take photo...it's cold and wet and dirty now.
Old 11-11-2012, 03:36 AM   #10 (permalink)
brandon671's Avatar
No problem on the pictures. Here's what I'm looking at... I'm wondering how the unattached side works.
Can someone please post the part number for the xenon headlight level sensor-2012-11-11-21.24.06.jpg   Can someone please post the part number for the xenon headlight level sensor-2012-11-11-21.23.57.jpg
Bookmarks
