Ordered the part...now just need to figure out where it goes
Does anyone have a picture or can explain where the sensor is located? I'm assuming it is close to the area you put coolant in, but can't seem to find it.
Thanks very much!
PS - On a side note, I read that you can check a bad sensor with an ohm meter. What is the reading suppose to be and/or how can you tell if its bad.
Thanks very much!
