Squeaking noise while driving? - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 04-05-2012, 10:07 AM Thread Starter
fata1ity's Avatar
Date registered: Jul 2007
Vehicle: 1999 E320
While driving under 10mph, I can hear some loud squeaking coming from the right side of the vehicle. I'm not sure if it's a bushing or the springs. What could the problem be and what could the possible solution be? What steps should I take to locate the issue?
fata1ity is offline
post #2 of 18 (permalink) Old 04-05-2012, 11:03 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Just driving or driving over bumps or while turning?
Do you hear any noise if you radically bounce the front or rear corner on that side?
Do you feel anything (through the steering wheel or floorboard) when the squeaking is happening?
If you have a smartphone, figure out a way to affix it to the right front and then right rear suspension (zip ties usually work well), then turn on the recorder and go for a drive. That will at least help you know if it is front or rear.
Of course you could also take it to a shop and ask them what they would charge to isolate it; the use of a lift can be very helpful (and much safer) for some of these sorts of things.
Check Codes is offline
post #3 of 18 (permalink) Old 04-05-2012, 11:17 AM Thread Starter
fata1ity's Avatar
Vehicle: 1999 E320
Just driving or driving over bumps or while turning? Driving and over bumps
Do you hear any noise if you radically bounce the front or rear corner on that side?Yes I do
Do you feel anything (through the steering wheel or floorboard) when the squeaking is happening? Nope
If you have a smartphone, figure out a way to affix it to the right front and then right rear suspension (zip ties usually work well), then turn on the recorder and go for a drive. That will at least help you know if it is front or rear. I'll get my coworker to stick his head out of the window
Of course you could also take it to a shop and ask them what they would charge to isolate it; the use of a lift can be very helpful (and much safer) for some of these sorts of things. I was told that it was the rear bushing making the noise and some lubricant would fix the issue, but it doesn't seem to have helped
fata1ity is offline
post #4 of 18 (permalink) Old 04-05-2012, 11:24 AM
Quoted: 35 Post(s)
Wow. So just driving over a smooth road you can hear this? Is it a constant squeak or rhythmic/periodic, and if the latter does it vary with speed? Is it twice as fast at 10 as at five, for example?
My guess is that the noise is always there, but above a certain speed you simply can no longer hear it.
So if you bounce it and can hear it, then you should know for sure if it's from the front or rear. Driving up onto ramps on that side will allow you to get your head under there and listen while a friend bounces it; if you can't isolate it then a piece of vacuum line held to one ear and pointed around at various mounting points should get you to the place where you can identify the specific location from whence the noise cometh. Once you have that you can try a spray white lithium grease, which can work, though if it's a link bushing, etc. those are cheap and easy enough just to change. Hopefully it's not the frame/chassis bushings, those are beasts to replace from a labor perspective.
post #5 of 18 (permalink) Old 04-05-2012, 12:31 PM
suicidal4life's Avatar
Vehicle: 2001 E430
Quoted: 4 Post(s)
Is your car lowered? Does it have aftermarket camber arms? My Speedybenz arms will occasionally squeak if I haven't lubed them in a while.
Mods•Swain coated Kleemann headersMetal'catsEvosport underdrive pulleys355mm Brembo BBK front & 328mm rear19x8.5" Carlsson 1/6 wheelsCarlsson pedals & Shift knob"Carlsoon" lighted sillsburlwood steering wheel & door pullsH&R cupkitspeedybenzwave LED taillightsSprintboosterOE xenon swapSirius Howard 100 & 101
Countermeasures•Hidden Valentine1 with display etched in rearview mirrorLaser InterceptorLaserveil
suicidal4life is offline
post #6 of 18 (permalink) Old 04-05-2012, 01:02 PM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 174 Post(s)
Get a can of silicone spray and soak all the rubber bushes you can find in the area you think the noise is coming from...that'll sort it.
2005:
http://www.benzworld.org/forums/signaturepics/sigpic199506_2.gif
renault12ts is offline
post #7 of 18 (permalink) Old 04-05-2012, 01:42 PM Thread Starter
fata1ity's Avatar
Vehicle: 1999 E320
No road is smooth, so it's on minor to major bumpy roads. It's periodic, as I hit the bump the car will squeak. I don't think it varies with speed, however I do believe you're right about not being able to hear it after a certain speed.
Nope, all stock.
fata1ity is offline
post #8 of 18 (permalink) Old 04-05-2012, 05:11 PM
Date registered: Dec 2009
Vehicle: 1997 E300D
Quoted: 27 Post(s)
My bet is that it is your upper ball joint. Reach across the tire and put your hand on the ball joint which sticks up a bit just inside the tire. Bounce the car slightly. If it squeaks you should feel the ball joint vibrate. Of course it could be something else, but it sounds like my ball joints did.
nelbur is offline
post #9 of 18 (permalink) Old 04-06-2012, 11:55 AM
Date registered: Sep 2004
Vehicle: 98 E-320, 2003 E-500
I have the same squeaking at low speed on the W211, replaced the lower ball joint and that squeak went away.
Not sure if the same apply to the W210. I didn't have any squeak on my W210.
JeffreyP is offline
post #10 of 18 (permalink) Old 04-06-2012, 12:46 PM
Date registered: Nov 2010
Vehicle: 2008 E350
My 02 E320 squeaks too!
This is unbelievable as my car is doing the same thing.. Slower speed squeak from passenger side front. Drive slow and squeak-squeak-squeak. Press down on front fender and she squeaks away. Now mine is a bit tempermental. seems to act up more with road moisture and after driving awhile. MB shop said no can find problem X 2. So, recorded sound as I pressed on fender. Front struts they now say. Estimate of $920.00 for both. Non-MB shop says $522.00 (labor 1.5 hr = $135 and parts $387) Does this sound like a right amount? Thanks for any imput....
Gopher501 is offline
Outside squeaking noise superchan7 C208/A208 CLK-Class 5 01-07-2014 02:28 PM
squeaking is driving me crazy Benzat17 W220 S-Class 4 12-29-2011 03:22 AM
squeaking noise dav007 W202 C-Class 0 06-23-2011 11:20 PM
front squeaking when driving bcjm R129 SL-Class 3 09-19-2005 06:48 AM
unusual squeaking noise when driving red_dragon W124 E,CE,D,TD Class 0 08-13-2004 09:17 AM
