98 E320 HD Radio Antenna Question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-07-2012, 02:25 AM Thread Starter
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: '98 E320 Wagon (non 4matic)
Send a message via AIM to TNTRower
Hey folks-
I am looking to switch to HD Radio. When I bought the wagon it came with an Alpine CDA-9856 head unit with XM Radio. The regular analog Radio is spotty at best and I am assuming it is because of the tint in the back.
My question for the forum is, does anyone know of an HD Radio Antenna that can be installed like the XM Antenna? The wife's new KIA Soul gets terrific radio reception and my E320 gets none. I don't see the use in going to HD if I cannot somehow come up with a solution for the reception issue.
Suggestions?
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
If the Arabs put down their weapons today, there would be no more violence. If the Jews put down their weapons today, there would be no more Israel. --Benjamin Netayahu
TNTRower is offline
post #2 of 3 (permalink) Old 03-07-2012, 03:53 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
wagon antenna is in the side drivers
side rear glass. It is not the antenna that gives the reception issue it is the am/fm diversity amp.
HD requires hardly any antenna to lock on a digital signal so plug it into the regular cable or bypass the diversity amp. You should have no problems.
I did an install on one of the 300's and it got HD reception on several channels even with the antenna not plugged in.
The HD signal is on a sideband of the regular signal or layered on top of so the same antenna wavelength is going to work.
An XM antenna is made to amplify satellite reception
HD is broadcast from your local radio station mast transmitter antenna.
Now if the antenna is broken that is another issue and it could easily be resolved by installing an electric motor operated antenna that goes up and down when the radio is turned on or off. Wagon rear wheel well with angled mount similar to what you see on W124 wagons.
Like
the one below or where the hole is located in my latest addition to the collection and where the new motorized antenna for the hd radio will reside shortly. That option will require routing the antenna cable and wiring to the antenna power wire on the HU.
Name:	My 94' E320 Wagon 024.jpg
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #3 of 3 (permalink) Old 03-15-2012, 03:56 AM Thread Starter
TNTRower's Avatar
Here is some info on the AM/FM Amplifier.
File Type: pdf W210 Wagon Antenna Amplifier Location.pdf (91.5 KB, 269 views)
File Type: pdf W210 Wagon Removal_Installation, Steps 1 - 4.pdf (67.6 KB, 224 views)
Who's John Galt.
TNTRower is offline
    antenna and radio code question. pokergod W201 190-Class 13 03-07-2011 07:05 AM
    2005 E320 Wagon - Nav Sat Antenna question CECat Audio & Telematics Forum 1 01-15-2011 07:39 AM
    Radio Antenna Question TasmanianDevil W140 S-Class 3 12-16-2010 10:59 PM
    2000 e320 bose radio antenna connector johntabako W210 E-Class 0 01-23-2006 09:47 AM
    Satellite radio question .. where does the antenna go???? ron_dodge R170 SLK-Class 8 01-19-2006 07:42 PM
