1999 E320 Power Window Issue - Mercedes-Benz Forum
post #1 of 24 (permalink) Old 01-29-2012, 09:32 AM Thread Starter
Date registered: Jan 2012
Vehicle: 1999 E320 4Matic Sedan
Hey everyone.
I recently bought this car from a dealer that is a bit of a distance away. My dad actually helped me with this and test drove it etc as I did not now what to look for in a used MB.
I noticed yesterday that the driver, and left rear passenger windows do not work however the other other windows do. The seat adjustment etc also works fine on that side, it just seems to be those two windows.
Before I drove to the nearest city I wanted to see if I could fix it myself. I don't have an owners manual as I bought the car used. I was wondering if anyone had the fuse locations and fuse diagrams for this particular year?
Thanks
TeflonVixen is offline
post #2 of 24 (permalink) Old 01-29-2012, 10:10 AM
Date registered: Sep 2006
Vehicle: 1992 500 SEL, 1996 E320, 1997 S500, 1998 E320 4MATIC,
The main fuse box is located under the hood on the driver's side at the firewall end, easily accessible from the side. There should be a legend and spare fuses inside the box. Note that you may have to resynchronize the windows. I think this is done by operating the window in the closed direction and holding the switch in the closed direction for a couple of seconds after the window reaches the full closed position. This must be done to tell the computer where closed is in order for the automatic function to work.
greyride is offline
post #3 of 24 (permalink) Old 01-29-2012, 10:37 AM Thread Starter
Thank so much! I was about to ask where the other one was. The rear fuse box under the seat is only for the passenger side windows. Luckily there was a legend so hopefully there is one in the main one as well. Thanks again!
post #4 of 24 (permalink) Old 01-29-2012, 11:20 AM
Musikmann's Avatar
Quoted: 6 Post(s)
FYI: There is a 3rd fuse "array" behind a door in the driver's side dashboard but I don't think there are any window fuses there. Try the suggested re-sync procedure on the non-working windows. Once you do that in the closed position, repeat those steps when you get the windows open. At least I'm pretty sure you have to do that in both directions.
Musikmann is offline
post #5 of 24 (permalink) Old 01-29-2012, 02:48 PM Thread Starter
Thank you, I had no idea there were three arrays. Also, tried to resynch but the windows won't roll down at all
Unfortunately it isn't a fuse problem as I switched out what I though was a faulty fuse with one I knew worked and it still worked fine. I'm not that technical so I don't know the proper name for it, but where the window switches are located, the only switches not working is the drivers side and rear passenger windows switch.
Any ideas?
post #6 of 24 (permalink) Old 01-29-2012, 02:59 PM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(203K Miles), 2002 E320 Special Edition(174K Miles)
Any ideas?
Do you mean the driver window or the driver side REAR window, in other words both rear windows?
If both rear windows will not go down using the switches on the rear doors, then the child lock on the center console may be engaged. It still allows the rear windows to be rolled down from the center console, but not from the rear doors.
Of course, the window regulators on one or both of the rear windows may have broken and the windows were propped up in the closed position. Check the stickies, there is a lot of information on the rear window regulators.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #7 of 24 (permalink) Old 01-29-2012, 03:13 PM Thread Starter
I meant the windows on the drivers side of the car. Both the front and rear. The passenger side windows, front and rear, both work fine. Everything on the center console works fine except for the left side buttons. When I press the buttons there is no sound and no movement.
Thanks!
post #8 of 24 (permalink) Old 01-29-2012, 03:27 PM
Kobus's Avatar
And what happens if you use the switch on the rear door?
Albert Einstein
Kobus is offline
post #9 of 24 (permalink) Old 01-29-2012, 03:39 PM Thread Starter
Nothing on the drivers, side. The passenger side works fine. Something I did notice while I was checking though. The drivers side window clicks like the passenger side front and rear windows when I try to resynch but does not move. However the rear driver side window doesn't make a sound. Not sure what it means, but I'd love to at least fix my front drivers side window.
post #10 of 24 (permalink) Old 01-29-2012, 04:43 PM
Kobus's Avatar
Sounds like the driver side is getting power. Can't see any option for you but to open the doors.
Albert Einstein
Kobus is offline
    1998/E320 210.065 power seats/window/side mirror not working - wife may be the issue! rgdeja W210 E-Class 8 08-07-2015 09:35 PM
    98 C280 Power Window Issue phillyy W202 C-Class 3 11-17-2010 01:00 PM
    1999 ml430 power window problems ianb4310 W163 M-Class 2 10-05-2010 01:44 AM
    Weird Power Window Issue SParkyMerc W202 C-Class 3 02-03-2008 03:09 PM
    Power Window Issue Va170_Bill R170 SLK-Class 5 11-15-2004 09:07 PM
