HELP 2001 Mercedes E320 limp mode! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-18-2012, 02:00 PM Thread Starter
Date registered: Jan 2012
Arrow HELP 2001 Mercedes E320 limp mode!
Hey I have a 2001 Mercedes E320 that was driving fine until one day it stopped accelerating. I came an office and after I started it, pushing the gas would have no response. The check engine light went on and ESP malfunction. In P and N it revs up just a tiny bit but in D it just drives about 11mph and that's it. It does shift between first gear and second gear. I had no time to fix it so it stood without use for couple months, and the battery died. I bought a new battery and started the car, and turned off the esp button right away. Gave it a circle around my neighborhood and it was accelerating just fine. So I thought that was the fix... When I started the car again the problem came back. I changed the throttle position sensor and that didn't change anything. I called a friend and he brought his computer and it gave out the code p0120. He erased he code but it came right back up. My friend thinks the computer needs to get re flashed or relearned... Anyone who knows what this can be please help out, before I but anymore unneeded parts. Thanks in advance...
tyslyuk is offline
post #2 of 4 (permalink) Old 01-18-2012, 03:48 PM
Date registered: Nov 2008
Vehicle: 1985 500 SEL 175k mi - 1999 E320 Wagon 4matic 160K
85500sel is offline
post #3 of 4 (permalink) Old 01-18-2012, 05:41 PM
~BANNED~
Date registered: Oct 2010
Vehicle: 1999 E300 TD
P0120 is the throttle position sensor code, however and although your friend went to the library, he did not find a book.
What your friend did not do was check the varying voltage of TPS against the varying voltage change from the manifold pressure sensor and the voltage change from the engine control unit--------have a different friend do that and then he will be able to tell you what component to really buy.
Plutoe is offline
post #4 of 4 (permalink) Old 10-16-2014, 01:06 AM
CWD
Date registered: Oct 2014
Hi, this is the exact problem I am having with my 2001 E320. Did you ever find a solution? If so can you describe what solved your idle only problem?
Thank you.
So far I have changed the TPS and then the throttle body/actuator; Had the same P0120 error; it will now get to 1500 to 2000 RPM in neutral and that is it. Tried disconnecting the battery for a while to clear the errors. the only one on the dash is ESP which does not seem to be related to the throttle problem.
CWD is offline
    E320 CDI - Limp Mode P2015? jslimjeff W211 E-Class 20 03-05-2014 11:08 PM
    97 E320 in Limp Mode chels97 W210 E-Class 22 06-03-2011 06:13 PM
    96 e320 in limp mode? kikaz69 W210 E-Class 10 03-13-2011 03:34 AM
    01 e320 in Limp Mode please help mpalic W210 E50 AMG, E55 AMG 3 10-25-2008 09:52 AM
    E320 Check Engine light-Limp Mode? jchumba General Mercedes-Benz 1 10-25-2008 08:30 AM
