w210 e 220 cdi wont start - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-08-2012, 08:44 AM Thread Starter
Date registered: Jan 2012
hi,i wonder if anybody can help me.i have 2001 e 220 cdi.today i took the egr valve off and cleaned it thouroughly.when i put everything back together the car would not start it turns over but wont start.i also tried to get a lot of the gunk out of the inlet manifold the top part,it was very dirty i think i may have pushed a lot of gunk down into the ports that lead to the head.would this cause the car to not start,do i need to take the manifold off,is it much of a job.hoping someone can come up with an answer.........peter.
peter.g is offline
post #2 of 6 (permalink) Old 01-09-2012, 12:15 AM
Date registered: Nov 2011
Vehicle: w124 e200 saloon 1990
Post help with this one needed
come on people some off you must know whats going on with this car
ady1 is offline
post #3 of 6 (permalink) Old 01-09-2012, 08:48 AM
Kajtek1's Avatar
Quoted: 1248 Post(s)
We don't have designated diesel section and cdi on W210 are very rare. I would advise you to repost the topic in General section when owners of those engines in other models can give you direct advise.
Generally pushing crap down the intake is never a good idea, but soft dirt should not kill the engine. The only way to kill turning diesel is not go give it fuel. Check under the hood for a plug you could disconnect working on the engine. Did you scan it for codes? Checking the fuel pressure would be the first thing to troubleshoot.
Kajtek1 is online now
post #4 of 6 (permalink) Old 01-09-2012, 08:57 AM Thread Starter
everything is ok now engine running, took vacume pipe off egr valve got my son to bring his car to my house, we then connected his battery to mine with jump leads and gave it a good crank the engine spluttered into life with clouds of black smoke reved the engine for a couple of minutes,then re-conected the vacume hose and took the car for an italian tune up{fast run} the car now starts and runs perfectly......
peter.g is offline
post #5 of 6 (permalink) Old 01-10-2012, 09:06 PM
Date registered: Aug 2008
Vehicle: 2004 S55
I wish they have that car here in america i wouldn't think twice about buying it . Great car i use to have a E270 00 WHEN i lived in Albania and loved every minute of it.
seanmeti is offline
post #6 of 6 (permalink) Old 01-10-2012, 09:51 PM
Kajtek1's Avatar
There is plenty E320cdi on US market
Good to hear OP got his issue fixed.
    Starting Problems - Car wont start/starter motor wont stop winding. EnzedSurfer W210 E-Class 13 05-23-2012 02:26 PM
    replaced wire harness....now key wont come out CAR WONT START pfisher W140 S-Class 2 08-08-2011 08:14 PM
    w210 wont start seandiesel W210 E-Class 2 09-13-2010 06:44 PM
    02 C240 Wont Upshift / Weird Messages / Now Wont Start jondag W203 C-Class 7 12-03-2008 07:15 PM
    After wire harness change temp gauge wont work, and now wont start daanmuller W140 S-Class 4 06-14-2007 08:00 AM
