Misfires clear with restart? P0302 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-24-2011, 03:51 PM Thread Starter
Date registered: Sep 2011
Vehicle: 04 E320 Wagon, 99 E320 Wagon, 02 C240 6-speed
OK, I get misfires and they clear as soon as I restart the car.
I pull over, ignition off, restart, runs fine.
>Only get them on the freeeway, especially on downside of hill
>Usually just P0302, and that can be felt in the idle when I pull over.
>One occasion P0300,P0302,P0304,P0306 and the car barely ran..
In the past I got the CEL once on a 40 mile trip, if at all. Today 6 times, so the gig is up.
I have changed the fuel filter.
I think I have cat rattle.
Given the severity that clears with just an ignition reset, it seems like something that puts the engine computer 'off'
-MAF?
-Crank sensor?
I can't see how it can be coils/wires/plugs
Runs just perfect inbetween faults.
Thanks
Benzer aus Mehlem is offline
post #2 of 7 (permalink) Old 12-24-2011, 04:27 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
It could be lots of things.
The misfires are in all probability happening all the time. That's why the cel is on.
When they are bad enough the ecu shuts down the cylinders to protect cats, etc. That resets when you restart the car.
My first guess, if you want one, is that your maf is failing. That often will throw myriad and random misfires.
But it could be many other things. If you have been deferring maintenance, you might need plugs and O2 sensors, for example. Or since they are all on the same bank, perhaps a vacuum leak, perhaps a clogged cat.
Some live data would be useful, but that is more diagnostics. That said, I'd probably start by checking for vacuum leaks and be sure I had a good air filter in place, plus taking care of any deferred maintenance.
Good luck.
Check Codes is offline
post #3 of 7 (permalink) Old 12-27-2011, 12:45 PM Thread Starter
Good luck.
Thanks Check Codes
>OK makes sense that the cylinder is being shut down, then clears.
>Reading elsewhere I now understand your point about CEL. I thought it came on automatically with codes, but others have lots of codes and no CEL.
>However, if I check for codes, I don't find any, until the CEL comes on and I am down a cylinder
>CEL flashed for the first time last time out, so I guess that is something extra bad
>So, I think I am getting some event the both triggers the P0302 (or more) and shuts down cylinder(s)
-Bad wire short on #2?
-I'm 120k and don't know the plugs were changed.
I overpaid on the car from a widow based on all the care they supposedly took. Body and interior nice, but the breathers and front were covered with oil. Bad sign when superb care doesn't include the oil blank off.
post #4 of 7 (permalink) Old 12-31-2011, 12:35 AM Thread Starter
I found this post, and this IS my problem
http://www.benzworld.org/forums/w210...m-misfire.html
But I read to the end and there is no concluding post !!
Notice he wrote: "However, yesterday morning I was about 20-miles into a 150 mile trip when the CEL again illuminated and the same old symptoms had returned. I restarted, clearing the rough engine, and turned around for home not wanting to risk further damage. While the engine ran fine on the way home, I did have the CEL flash about 10-times while coasting down a hill with no throttle input,"
This CEL on the long trips when coasting, increased vacuum, has got to be a clue.
Cars like to backfire under this condition, and that has me thinking cats.
I am changing plugs this weekend, and since I live in the socialist republic of California, am looking into 50 state cats...
post #5 of 7 (permalink) Old 12-31-2011, 07:48 PM
dykaar's Avatar
Date registered: Mar 2008
Vehicle: 2001 E320 4matic Wagon
I had misfires on all cylinders on one bank. Thread here. It was a clogged cat. Had an aftermarket cat welded in, codes and misfires went away.
Regards,
doug
86 951 (http://pcaucr.org/media/image-galler...all&gallery=22)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
dykaar is offline
post #6 of 7 (permalink) Old 01-12-2013, 10:54 PM Thread Starter
The PLUGS!
Late update, but the car had 120M and was still on original plugs. Put in the NGKs and no problem since, more than 6 months.
It had gotten so bad I parked the car for 6 months, again, only ever happened on the freeway.
Also, driving with the scanner I could see that there were no codes until the moment the misfire came on the respective cylinder shut down on the spot
post #7 of 7 (permalink) Old 01-13-2013, 07:04 AM
dykaar's Avatar
Bad coil? You could swap coils and see if the code moves to a different cylinder.
Regards,
doug
83 944 (sold in 86)
dykaar is offline
    Rough Idle P0302 - Help! Twang W163 M-Class 15 06-10-2016 10:23 AM
    Need Help quick Code p0300 p0302 Brandonh87 W140 S-Class 16 07-15-2010 01:37 PM
    p0300, p0301, p0302, etc... 3-Pointed-Star R170 SLK-Class 13 06-02-2010 02:34 AM
    P0302, P0455 & P0442 kyates W210 E-Class 8 10-15-2008 03:42 PM
    CEL P0302 NEED HELP cstonepro W210 E-Class 10 12-17-2007 07:44 PM
