Tach hunting at highway speed...no surging at idle - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 12-01-2011, 05:58 AM Thread Starter
MB Rover's Avatar
Date registered: Mar 2008
Guys, I have been surfing the forum trying to find someone who has had a similar problem and I just don't see it. So...here goes. A '97 E300D with 208k miles. Sometimes when I am cruising down the highway around 55 60 mph the tach start to fluctuate back and forth a very slight amount and I can feel the engine surge slightly. I have never observed it doing this at idle. Is this a symptom of the throttle position sensor or what? I am stumped!
'59 MB 190D helping keep a 190e rolling!
'66 MB 230SL
'68 MB 200D still for sale!
'79 MB 240D daily driver (sold)
'80 MB 240D gone on to the benz heaven
'88 MB 300SEL donated to brother-in-law
'97 MB E300D the new daily driver
'64 Land Rover SIIA 88in w/200TDI upgrade
'00 Chevy 1500 4x4 4.8L
MB Rover is offline
post #2 of 8 (permalink) Old 12-01-2011, 08:54 AM
Kajtek1's Avatar
Quoted: 1198 Post(s)
I have no knowledge about actual wiring on those cars, but driving diesels for long time I learned that in older cars tachometer pickup is taken from alternator. On this car it could come from CPS.
Start with the basics.
How old are your alternator brushes?
Display voltage on your clima LCD and observe it during driving. Than you can display rpm sensor to check if the fluctuation is in sensor, or the gauge.
Kajtek1 is online now
post #3 of 8 (permalink) Old 12-01-2011, 10:17 AM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 165 Post(s)
Since the engine is fluctuating, I suspect the tach is working as you would expect. The question is why is the engine fluctuating? Turn the ASR (or do you have ESP) off, and see if this changes things.
2005:
http://www.benzworld.org/forums/signaturepics/sigpic199506_2.gif
renault12ts is online now
post #4 of 8 (permalink) Old 12-01-2011, 10:23 AM
Kajtek1's Avatar
Thinking about it again, this is non-turbo diesel and engine surge is pretty common on it. We do have couple of topics covering it, but per my memory no solid fix.
This engine has no throttle BTW.
post #5 of 8 (permalink) Old 12-01-2011, 11:08 AM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 386 Post(s)
The lockup torque converter on W210's is different than most non Mercedes vehicles. It is not "locked" or "unlocked" it is a progressive lockup, Don't know the diesel spec's but on the 420 it isn't fully locked until 3000rpm in 5th gear, which is about 90MPH IIRC. If the diesel is similar in operation, what you could be seeing is the amount of "lockup" varying slightly depending on engine load, and that also giving the "surging" as well.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #6 of 8 (permalink) Old 12-02-2011, 04:37 AM
Date registered: Feb 2004
Vehicle: '99 E430 Sport
Send a message via AIM to johneb48 Send a message via Yahoo to johneb48
I have a '99 E430 with that like surge problem--Mercedes dealer says that it is the torque converter just like the previous post. Anyone know if the converter is electronically actuated or by fluid preasure?? Wonder if it is the Trans ECM or the torque converter?
johneb48 is offline
post #7 of 8 (permalink) Old 12-02-2011, 10:19 AM
e-420's Avatar
Quoted: 386 Post(s)
not sure how it is controlled. What I do know from looking at a graph is that on my 420 the lockup starts at about 1600rpm in high (5th) gear, but it is not fully locked until 3000 rpm in 5th gear. What that means is that in the U.S. your probably never really locked up. Cruising down the road with CC on, you can see the tach needle moving around slightly even on flat ground.
e-420 is offline
post #8 of 8 (permalink) Old 12-02-2011, 10:27 AM
Kajtek1's Avatar
Per my impression, the converter lock is not working on my E300DT.
Even at 80 mph/3000 rpm when I take the foot off gas pedal, the rpm drops about 200 rpm.
On W211 the converter lock is so firm, that for some time I was thinking I have 6 speed transmission.
Than again, the OP engine is known for surging.
    300TE Poor fuel economy/ idle miss / occasional surging idle -- ideas? ps2cho W124 E,CE,D,TD Class 8 02-23-2013 04:45 PM
    idle mixture...idle rpm hunting Bigfootdriver R/C107 SL/SLC Class 2 01-19-2011 05:18 AM
    Idle Problem-surging Idle-1990 560 SEC gregory113513 W126 S,SE,SEC,SEL,SD,SDL Class 3 08-14-2009 11:42 PM
    c220 idle speed adjustment?? / surging when stopping. doin12volt W202 C-Class 7 06-11-2007 03:49 PM
    slk 230 surging at highway speeds lsarg27 R170 SLK-Class 1 08-31-2006 02:20 PM
