ABS/BAS/ESP Lights Coming On - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 11-29-2011, 12:45 PM Thread Starter
Date registered: Sep 2010
Vehicle: 2000 E320 Sedan
Hello,
I've ran into a problem with my 2000 E320, whenever I start the car the ABS/BAS/ESP errors are all off, but as soon as I apply the brakes they all suddenly come on. Can anyone offer some insight into this? If it makes a difference, very occasionally these lights will not come on at all for my entire drive (I would say about 98% of the time the lights come on, but as I said, very rarely I will drive all day and they won't show up).
I've done a little research and I've heard that the ABS being the only problem can also trigger these other errors, don't know if there is any truth to this.
AdamStir is offline
post #2 of 22 (permalink) Old 11-29-2011, 01:06 PM
Sith Lord
elbeik's Avatar
Date registered: Sep 2009
Vehicle: 72 280SE 88 560SEC 92 E500 6.0 95 SL320 14 GLK350
Quoted: 215 Post(s)
Answer more likely to be residing in the W210 section.
elbeik is offline
post #3 of 22 (permalink) Old 11-29-2011, 02:19 PM
KMani1's Avatar
Date registered: Jun 2009
Vehicle: 2001 C320 W203 Black on Black. 1997 E320 W210 Silver (RIP). 1995 E320 W124 Pearl Black.
It's in the stickies, here the link.
http://www.benzworld.org/forums/w210...lly-fixed.html
RIP.
KMani1
KMani1 is offline
post #4 of 22 (permalink) Old 11-29-2011, 04:52 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Originally Posted by AdamStir View Post
Hello,
I'm curious what research you did. This is a classic issue with MB cars of this generation, not just the W210. Replace the brake light switch, source it from the dealer to assure quality (the aftermarket ones seem to be quite troublesome and it's not very expensive, around $25) and you should be good to go.
You do want to fix it though. When those lights are on, the systems they represent are disabled, which makes it more likely that you may skid in an emergency situation.
Good luck.
Check Codes is offline
post #5 of 22 (permalink) Old 11-29-2011, 07:54 PM Thread Starter
Good luck.
I've just heard it from people now and again when I've talked about this issue. I've had the problem for some time so I've asked around a bit. How sure are you that this is absolutely what is causing it? I certainly agree as the issue is FOR SURE centering around the brakes. I can idle for ages and the lights do not come on until the brakes are pressed. Thanks for the help.
AdamStir is offline
post #6 of 22 (permalink) Old 11-29-2011, 09:26 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 122 Post(s)
As a $20 dealer part and 20 minutes for the install using the stickies for instruction - why the hesitation ?
fabbrisd1 is offline
post #7 of 22 (permalink) Old 11-29-2011, 09:51 PM
Quoted: 35 Post(s)
Absolutely. In fact, if I'm wrong, I'll refund the money you paid me for my advice.
Okay, let's be serious.
Of course I can't promise you that, and no one here can, at least if they are honest and not a know-it-all turd.
But here is what I do know.
1. 95% of the time, what you have described is the brake light switch. To be clear, it has nothing to do with the brakes themselves (your suspicion), just the switch that trips when you step on the brake pedal.
2. You've lived with this got a while, which means you've been driving the safety equivalent of a 1985 Chevy Celebrity. In the event of an accident that could leave the door open for additional liability on your part.
3. If #2 concerns you, and well it should, this should be your highest priority.
4. A new brake light switch will cost you $22-30 at the dealer (depending on their greed) and 30-60 minutes of your time (depending on your ability) with ordinary tools.
5. Your only other alternative is to continue to ignore it or go pay perhaps several hundred dollars for a system diagnostic...and probably end up with a new brake light switch.
6. You came here seeking advice -- free advice -- from people who at least have some history and knowledge with these cars. If your intent was to simply challenge those who offered advice...well, that usually has a rather chilling effect.
7. If I owned your car, the first thing I'd have done as soon as I had time after those lights popped on would have been to open the trunk and get the brake light switch and replace it. (Yes, they are unreliable enough that I carry one, just waiting for that shoe to drop.)
Ummmm...Good luck.
post #8 of 22 (permalink) Old 11-29-2011, 10:34 PM
Date registered: Oct 2007
Vehicle: '03 Z4, '02 E55, '11 ML350
Check,
You were more than gracious with your answer to this guy.
I can't think of a more common, easily diagnosed, inexpensive to repair problem than the old brake light switch issue.
A good example of what a simple search would have pulled up.
Adam, try the fix. It's really very simple.
Cheers !!
Mike K.
Mike K. is offline
post #9 of 22 (permalink) Old 11-30-2011, 02:11 AM
Date registered: Feb 2010
Vehicle: w211 (E280), 2008
I had exactly the same problem, most probably it's the break switch. For me it was a faulty speed sensor and a Chinese rear tire component that didn't have a proper sensor
baddar is offline
post #10 of 22 (permalink) Old 11-30-2011, 06:10 PM
Date registered: Jan 2006
Vehicle: 2012 E350 :-) 2002 E320 (sold)
Same problem with my 2002 E320. new switch for about $30 at the dealer and DIY and problem gone.
ALLIKANBE is offline
    ABS and ETS lights coming on and off lodfill W202 C-Class 3 07-02-2011 07:30 PM
    Hazard lights intermittently coming on? derin100 W168 A-Class 0 10-11-2009 09:48 AM
    Dash lights coming on 240DieselPower W123 E,CE,D,CD,TD,TE Class 5 07-20-2007 11:02 PM
    ABS & ASR lights coming on intermittantly. help? Dave_SL60_AMG R129 SL-Class 4 03-26-2006 01:18 PM
    Has anyone else had any problems with any warning lights coming on? Ernest - Orange Coun R170 SLK-Class 2 02-25-2001 06:06 AM
