Best places to jack up car?? - Page 4 - Mercedes-Benz Forum
post #31 of 38 (permalink) Old 11-28-2011, 05:18 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Originally Posted by e-420 View Post
Once it is jacked up, I use jackstands for security. It isn't a case of "if" the hydraulic jacks goes down, it is a case of "when" it goes down, usually not quickly, but sooner or later a hydraulic jack is going to loose pressure and come down.
IIRC that is one of the strong arguments about the underlying cause that led to the crash of an American Airlines DC-10 back in 1979, which killed everyone on board. Mechanics had supported the engine and pylon assembly with a forklift and left it that way overnight, and the hydraulics in the forklift let it drop a bit, leading to a fatigue crack on the mounting point that ultimately caused the engine separation from the wing.
Check Codes is offline
post #32 of 38 (permalink) Old 11-29-2011, 01:45 AM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 168 Post(s)
Originally Posted by Elvis_Presley View Post
The Citroen DS, one of the most innovative cars ever, didn't require a jack. You just used the hydraulic suspension to lift it. ( It also had no break pedal. )
I think you are partly right...you could take off one of the rear wheels, but not a front one. I had a Citroen BX and this was the case.
2005:
http://www.benzworld.org/forums/signaturepics/sigpic199506_2.gif
renault12ts is offline
post #33 of 38 (permalink) Old 11-29-2011, 02:40 AM
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1535 Post(s)
The comments underneath the photos were pretty good!
What with all the 'engineer' types floating around here (I'm a retail kinda guy, myself), what's actually wrong with the #1 photo in this series? I mean, at first glance, it seems pretty sketchy but when you study where everything is placed and look at the additional bracing, it seems safer than the big pile o' pickup sticks that it originally appears to be. I'd climb that rig to get the job done. Can someone explain why I might be wrong?
Okay, seriously... how drunk do you have to be before this starts looking like a good idea?
Quis custodiet ipsos custodes?
Digmenow is offline
post #34 of 38 (permalink) Old 11-29-2011, 03:25 AM
Quoted: 168 Post(s)
If it's bolted together, and not used on a windy day (no side loading) then it should be safe. I wonder do they drive to the next post with the guy up the ladder?
2005:
post #35 of 38 (permalink) Old 11-29-2011, 08:12 AM
cbc atl's Avatar
Date registered: Feb 2010
Vehicle: 89 300E; 00 E320
Quoted: 15 Post(s)
Because it's cloudy.
cbc atl is offline
post #36 of 38 (permalink) Old 11-29-2011, 08:25 AM
Date registered: Sep 2004
Vehicle: 98 E-320, 2003 E-500
Don't know if it'd help but the jack spots are relatively the same on the W211. Although I used the MB tire change jack then put the jackstands on the corners behind the wheels.
The entire front can be jacked up with a hydraulic, just make sure to use jackstands on both sides. I don't know where to jack up the the rear though (again I used the MB jack to bring up one side at a time)
Here's for reference.
JeffreyP is offline
post #37 of 38 (permalink) Old 11-29-2011, 09:10 AM
Kajtek1's Avatar
Quoted: 1250 Post(s)
Quality of lumber and bracing aside -ladders are not designated to work as cantilevers. The last 12 feet of that construction is straight cantilever with no other support. Making it several floor levels above the ground sure is not adding safety.
Kajtek1 is offline
post #38 of 38 (permalink) Old 11-29-2011, 11:10 AM
Kajtek1's Avatar
Wood BTW is not giving much warning before it collapses. I do lot of crazy moves in my mechanical and construction activity, but worse come to worse, I would make a safety rope over the light construction. There is guy standing on the ground anyway, so no issues with having safety support.
Saying that I still have all my fingers attached and never had a broken bone (beside cracked ribs).
Lot of my coworkers were not so fortunate.
Kajtek1 is offline
    Mercedes Tire Jack Compatibility, W201 jack ≅ W123 jack? 2.6_Steve W201 190-Class 4 11-01-2010 04:18 AM
    Lifting car with floor jack. Bests points for jack and stands? DirtyD W203 C-Class 6 07-19-2010 09:22 AM
    Front Rubber Jack/Jack Stand point missing :( onosqv R129 SL-Class 13 01-23-2010 01:01 AM
    How To: 1 Way To Use a Floor Jack and Jack Stands + Photos slk55er R171 SLK-Class 2 03-11-2005 05:07 AM
    Where do I place a floor jack and jack stands? jcochrane007 W124 E,CE,D,TD Class 1 05-20-2003 04:02 PM
