ACC Skid Control: ASR error! Car Stalls! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-08-2011, 10:14 PM Thread Starter
Date registered: Nov 2010
Vehicle: 1999 E320
I have a 1999 E320 with 129,000 miles. Recently, the car has been getting an ACC Skid Control and ASR error when i take hard turns and go over bumpy roads. The orange triangle would also light up. Sometimes the Car will completely stall. I have to put it back in P and turn it on again.
Also, windows would not roll up or down when this happens.
Last week the Car Stalled in a parking lot. I put in P and try to turn the Key but the key wouldn't turn. It locked up. I could pull it out, just won't turn.
Eventually I Popped the back seat and saw the negative (i think) terminal was loose. I tightened it down and everything worked again. That was about 4 days ago and I haven't had any errors pop up or any stalling since.
Could those errors be from the loose battery terminal or does that have nothing to do with it? Thanks!
beezy is offline
post #2 of 5 (permalink) Old 09-08-2011, 10:22 PM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(203K Miles), 2002 E320 Special Edition(174K Miles)
Yes, it very likely could. You are lucky if this was the only problem that occurred.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #3 of 5 (permalink) Old 09-09-2011, 09:32 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
Good one. I got to remember this battery terminal fix when such problem occurs.
mbvis is offline
post #4 of 5 (permalink) Old 09-09-2011, 10:50 AM
brandon671's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes-Benz 420 SEL(RIP),1997 Mercedes-Benz E420
Quoted: 9 Post(s)
Yes the ASR reading could pop up, if the battery terminal is loose, it has happened to me.
brandon671 is offline
post #5 of 5 (permalink) Old 09-09-2011, 10:58 AM
brandon671's Avatar
Quoted: 9 Post(s)
Also, define "loose", was there enough play for it to obviously have moved around while you were driving?
Theres the two terminals positive, and negative that are physically attached to the battery. There also is a ground terminal, this is located near the lower part of the seat, below the cushion, where the passengers heel would be. This usually is what is used when disconnecting the battery, because it has easier access.
    ASR Skid control message, Need help Please mannaa W210 E-Class 2 12-07-2010 03:33 PM
    Acceleraton Skid Control semiretired W124 E,CE,D,TD Class 4 07-19-2010 08:17 AM
    ACC.SKID CONTROL & BAS error codes JWild W210 E-Class 5 05-11-2009 12:42 PM
    Please Help "ASR ACC.SKID CONTROL 1888RY General Mercedes-Benz 8 12-09-2007 07:36 PM
    Please Help "ASR ACC.SKID CONTROL 1888RY Audio & Telematics Forum 4 10-08-2007 10:46 PM
