97 E320. Do I have to remove engine to remove oil pan? Manual says so. - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 08-24-2011, 05:44 AM   #1 (permalink)
Date registered: Aug 2011
Vehicle: 95 C220
Just bought it, it needs engine repair.
car5car is offline   Reply With Quote
Old 08-24-2011, 05:57 AM   #2 (permalink)
eric242340's Avatar
Vehicle: S320 (W220) and Zotye 1.3/Rolls Royce on back order (LOL)
Is your engine the 104 in line 6 cylinder or the 112 V6? For 97 I guess it must be the 104, this can be done without taking the engine out but you will need an engine hoist or support bar as the engine has to be raised slightly, engine mountings removed.
ERIC.
eric242340 is online now   Reply With Quote
Old 08-24-2011, 06:07 AM   #3 (permalink)
eric242340's Avatar
Here are a couple of pics to give you the idea.
97 E320. Do I have to remove engine to remove oil pan? Manual says so.-snap3.jpg   97 E320. Do I have to remove engine to remove oil pan? Manual says so.-snap4.jpg
Old 08-24-2011, 06:55 AM   #4 (permalink)
Vehicle: 95 C220
It is inline. Thanks, Eric!
It seems like head gasket is bad. How should I hold chain, when head is removed?
Old 08-24-2011, 07:29 AM   #5 (permalink)
eric242340's Avatar
On the 104 that is simple, put the chain around the arms for the engine mountings. It needs to be lifted approx 4". And with the head removed you have plenty of space, but make sure the fan and fan housing are removed first.
Old 08-24-2011, 10:04 AM   #6 (permalink)
Vehicle: 95 C220
Sorry, I didn't explain it right. Question was about timing chain. I guess, I need to hold chain tight somehow to keep on crank sprocket, or it doesn't matter?
Old 08-24-2011, 06:27 PM   #7 (permalink)
eric242340's Avatar
You can tie it off, piece of string and tie it to a unit on the side of the engine or simply put a screw driver through the chain to stop it falling into the engine.
Old 08-25-2011, 04:30 AM   #8 (permalink)
Date registered: Jan 2007
Vehicle: 2000 E320 4Matic Sedan
Not 100% certain about this engine but I have done a lot of head gaskets, most recently on a Jag V12.
Use steel wire to lock the chain in position around the gear.
Release (or remove) the chain tensioner.
Clearly mark the camshaft gear location relative to the cam and remove it.
Be very careful not to drop the bolts into the engine. I stuff a rag in there at this step, just in case.
Tie off the chain/cam grear to the front of the engine.
You want to avoid too much chain slack at any time that might allow it to slip off the drive gear below.
I do not see a need to remove the oil pan for a head gasket repair, unless a piston(s) need servicing.
Thx.
Gasman59 is offline   Reply With Quote
Old 08-25-2011, 04:39 AM   #9 (permalink)
eric242340's Avatar
^Interesting point, he did not say why he needed to take the oil pan off, but no it is not required for an head gasket job.
Old 08-26-2011, 11:03 AM   #10 (permalink)
Date registered: Mar 2011
Vehicle: 1997 E320
There's no reason to remove the oil pan to do a head gasket. That said, I had our project car with the M104 just up on the lift and I can't see any way you could get the pan off with out raising the engine up.
jared at pelican parts is offline   Reply With Quote
Bookmarks
how to completely remove manual sunroof dropnosky W123 E,CE,D,CD,TD,TE Class 10 12-20-2010 05:44 PM
Do I need to remove front bumper to remove viscous fan? Coolant pump arrives today HACK THT W163 M-Class 2 10-18-2010 10:11 AM
How do I remove the handle/nob on manual DS mirror? Werner W R/C107 SL/SLC Class 4 06-15-2010 08:07 PM
***Need service manual instructions to remove and clean sunroof*** johnstonmurray W140 S-Class 0 01-16-2007 10:35 AM
How to remove the shift knob (manual transmission & pre-facelift SLK) Jordan (ITALY) R170 SLK Class 2 10-29-2002 01:48 PM
