1999 E300TD won't start after changing fuel filter. - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 08-12-2011, 09:16 PM Thread Starter
Date registered: Aug 2011
Vehicle: 1999 E300TD
Hi everyone,
So I'm new to DIY on my Benz and the first thing I've attempted to do is replace the fuel filter. I took out the old one, filled the new one with fresh diesel and installed it. The car started for about 5 seconds and then cut out. I tried starting it for another 5 minutes, each time it cranked for progressively less time until not at all. I thought the battery might me drained so I let it sit and then got a boost from a friends car. Still nothing. I tried again 2 hours later and the car made strange machine gun type noises while attempting to crank. Now no sound at all and no reaction when trying to start. I did nothing with the pre filter, just the main filter. Please help!!
ALLTD is offline
post #2 of 20 (permalink) Old 08-13-2011, 07:19 AM
Kajtek1's Avatar
Quoted: 1227 Post(s)
Originally Posted by ALLTD View Post
I took out the old one, filled the new one with fresh diesel and installed it. !
You mean you filled up new filter with contaminated fuel and let the contamination go to the injectors? I hope this is not the reason for your trouble.
Those engines take lot of cranking to bleed the air and the only way to do it is keep on cranking. Sounds like your battery needs recharging.
Also topping off the tank and parking the car nose down helps in putting some fuel pressure to the injection pump.
Kajtek1 is offline
post #3 of 20 (permalink) Old 08-13-2011, 04:30 PM
Date registered: Jan 2007
Vehicle: 05 E320 CDI, Formerly 96 E300 Diesel and 98 E300 Turbodiesel
Yeah it took me awhile to crank mine after changing the filter. I just kept at it. Once it turned over it was fine.
QualityLeather is offline
post #4 of 20 (permalink) Old 08-13-2011, 07:37 PM Thread Starter
Oh, well no, I put fresh diesel in that I filled in a portable tank from the station (thankfully a 10 min walk away!) I think the battery is zapped so I went and got a charger so I'll have to let it charge first before I try it again. I'm just worried about the noise, sounds like a rapid tapping when I tried to crank it before.. hope this works :/
ALLTD is offline
post #5 of 20 (permalink) Old 08-13-2011, 08:05 PM
Kajtek1's Avatar
The sounds are the hardest to describe and understand over the net, but do the obvious things first and than worry when something else comes. Charge the battery and keep the key on the starter for no longer than 10 seconds at the time, giving it at least 30 seconds between for the starter to cool off. After few attempts you might want to let it cool off for several minutes.
Kajtek1 is offline
post #6 of 20 (permalink) Old 08-14-2011, 06:54 AM
~BANNED~
Date registered: Oct 2010
Vehicle: 1999 E300 TD
Thats why those babies are changed every 50,000 miles or a new set of batteries which ever comes first!!
Plutoe is offline
post #7 of 20 (permalink) Old 08-14-2011, 04:42 PM Thread Starter
Thanks a lot for the help! I got it started! Going great now... I charged it over night and starts fine now, a lot smoother with the new filter. I'll have to get a new battery and make sure I do it right next time I change the filter!
ALLTD is offline
post #8 of 20 (permalink) Old 09-07-2011, 08:30 AM
Vehicle: 1997 E300 D one owner 65000
just changed the pre-filter and fuel filter on my 1997 E300D and now unable to start. I did prime the filter with fresh fuel when installing. Also i cranked every 30 sec for about 5 minutes still no sign of starting
GWilkes is offline
post #9 of 20 (permalink) Old 09-07-2011, 08:35 AM
Just got it running just needed to crank a little longer. Thanks for all the tips
GWilkes is offline
post #10 of 20 (permalink) Old 09-07-2011, 09:22 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
Diesel cars are slow. When I changed fuel filter on mine, it started right away.
mbvis is offline
    No Start------1999 E300TD The Post Man W210 E-Class 1 02-28-2011 10:45 AM
    E300td. 1999. will not start.!!!help!! mersas32 W210 E-Class 1 05-11-2010 06:52 AM
    1999 E300TD W210 Fuel Lines aeromobile W210 E-Class 3 07-19-2009 10:18 PM
    fuel pre-filter E300td 1998 voilodion W210 E-Class 3 01-31-2009 08:23 AM
    Need Help Changing The Oil Filter On My 1999 CLK 430 Liddleksin General Mercedes-Benz 2 07-24-2004 11:21 AM
