Cam Oil Guides DIY 1997 E420 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-11-2011, 04:42 PM Thread Starter
Date registered: Sep 2007
Vehicle: 1997 E420, 117,000 mls
Hi all:
It's time to replace the cam oil guides on my 97 E420. I'm going to do the driver's side first as there's a ticking sound at number 8 cylinder. I'll do the passenger side as required down the road. I've been looking for a DIY guide without success, could someone direct me to a DIY guide? Failing that, are there any special tools required? Are parts other than the cam oilers and O rings, such as gaskets required? Should I take the opportunity to perform other tasks while I have the cam cover off? Finally and rather importantly for me, as I tend to get in trouble easily, are there any pitfalls to avoid?
Thanks to all at the forum. In the last four years you've help make driving my E420 an affordable treat!
Cheers, Alan
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." Mahatma Ghandi
Chato is offline
post #2 of 3 (permalink) Old 07-11-2011, 05:27 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Buy the
good newer model ones. Metal not plastic. Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips
DIY on
PeachPartsWiki: Replacing Cam Oil Line Fittings (Oil Guides)
pictures tool list etc.
Work clean
easy job you will enjoy the reward of a quiet orphan again
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #3 of 3 (permalink) Old 07-12-2011, 05:30 PM Thread Starter
Thanks OhLord. A DIY article like that certainly gives a guy some confidence.
All the best, Chato
Chato is offline
    Pro's and cons of a 1995 E420 and a 1997 E420 London380sl W124 E,CE,D,TD Class 24 05-19-2011 08:30 PM
    1997 E420 Sean706 W210 E-Class 5 02-08-2011 06:08 PM
    Need DIY guides for 97 E420 ATF, differential & coolant change ProV1x W210 E-Class 2 10-01-2006 07:34 PM
    FS: 1997 E420 Ronald J W210 E-Class 0 02-18-2003 10:05 PM
