Cost for Replacing Harmonic Balancer with Seal - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-17-2011, 03:18 PM Thread Starter
Date registered: Mar 2011
Vehicle: 1998 Mercedes Benz E320 Base 6Cyl 3.2L
Unhappy Cost for Replacing Harmonic Balancer with Seal
Hi,
I need to fix an oil leak (not too big) in my 98 Mercedes E320. Specifically, I got the estimates for the following repairs from an independent shop:
Replace Harmonic Balancer & Seal:
Balancer $87
Seal $13
Labor $308
Replace Oil filter Housing Gasket:
Housing Gasket $22
Labor $220
Total $650
(There are 2 other extremely minute leaks, one in the Valve cover gasket and other in the rear seal, that aren't worth repairing at this time.)
The parts aren't that expensive. But the Labor is. I am in San Diego. Does anyone know of a good shop that can do the above for a lower price.
Thanks..
Sorizon is offline
post #2 of 6 (permalink) Old 05-17-2011, 07:38 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 134 Post(s)
Where in SD , and what shop ?
Where in SD, and what shop gave you the quotes ?
fabbrisd1 is offline
post #3 of 6 (permalink) Old 05-17-2011, 07:47 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
Harmonic balancer had recalls on those cars. Call dealer and ask.
It might be your lucky day.
Kajtek1 is offline
post #4 of 6 (permalink) Old 05-18-2011, 09:03 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
THAT is an excellent thought, Kajtek1.
Sorizon, I posted this several years ago (link below), so look at it and you can check to see if your HB is on the list. It's only for a couple of part numbers, but if yours is included the dealer will change it for free, and then there would only be a small additional labor charge to replace the TC seal.
Good luck!
Harmonic Balancer Recall: Key Points
Check Codes is offline
post #5 of 6 (permalink) Old 05-26-2011, 08:51 AM Thread Starter
Thanks..
Thanks guys..will check..
Sorizon is offline
post #6 of 6 (permalink) Old 08-01-2011, 08:51 PM
Date registered: Jul 2011
Vehicle: 1997 e420 sport, 2001 e430
Recall is over. Labor should only be around .5 hour.
Taylors 420 is offline
    harmonic balancer samosali W140 S-Class 0 04-09-2011 03:04 PM
    What does the harmonic balancer do? davegt W163 M-Class 3 07-13-2009 11:45 AM
    harmonic balancer MBOwner General Mercedes-Benz 9 01-03-2006 10:06 AM
    Harmonic Balancer discap G-Class 25 04-19-2005 03:30 AM
    harmonic balancer jtorre1 W210 E-Class 26 03-24-2005 11:18 PM
