Stuck gas cap - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-07-2011, 12:21 PM Thread Starter
Date registered: Aug 2006
Vehicle: 2000 e-320 wagon
Stuck gas cap
E320, 2000 wagon, 4matic. I have replaced the gas cap with a new on but that did not fix the problem. The cap turns but will not come off. The normal clicking does not occurr. I check the top of the tube leading to the tank and I did not find any bending. It seems smooth enough. After looking at this cap I can imagin what the problem is.
gurban is offline
post #2 of 13 (permalink) Old 05-07-2011, 08:50 PM
E-Fam's Avatar
Date registered: Sep 2009
Vehicle: 2001 E320 2011 E350c
I know how you feel my friend...
It most likely is your cap as I have the exact same problem right now. A 10 minute trip to the gas station turned into 45 for me.
On the left is my "new cap". On the right is my old one, which was causing code problems.
If you look at the arrows, my "new cap" got stuck because that plastic catch got unseated. It is supposed to turn against the two metal catches and turn the whole cap off. Instead, it's just turning the plastic only, leaving the metal catches locked.
As you can see, I pried mine off because it got stuck as well. I just got this cap not too long ago and I'm returning it to autohausaz for a warranty replacement.
E-Fam is offline
post #3 of 13 (permalink) Old 05-08-2011, 12:26 PM
Franasia's Avatar
Date registered: Jan 2005
Vehicle: 2000 4Matic Estate E320S4 210.282
Simple solution
This is a relatively common problem that has been discussed earlier. There is an issue with the filler neck where a tab bends and impedes the cap to be unscrewed.
The most cost effective solution, other than replacing the fuel tank, is to get a different type of cap, which is simpler but works fine. It's made by Blau (Germany) and available at autohausAZ.
I went through three new caps before getting this one that has worked great for a few years now. Hope that helps.
Cheers
jhofferman likes this.
Franasia is offline
post #4 of 13 (permalink) Old 05-09-2011, 02:11 PM Thread Starter
gas cap
Do you have a part number? autohause only list the mercedes one. When I bought the new mercedes cap it seemed to work once or twice and then failed again. So I think it must be the tube tabs even though I can't feel any bends.
gurban is offline
post #5 of 13 (permalink) Old 05-09-2011, 02:42 PM
Franasia's Avatar
Franasia is offline
post #6 of 13 (permalink) Old 05-14-2011, 09:56 AM Thread Starter
gas cap
Thanks. I'll go over to the closest car quest and get one order.
gurban is offline
post #7 of 13 (permalink) Old 06-05-2011, 11:56 AM Thread Starter
I ordered the cap from NAPA. But I believe I've got a cheaper fix. I broke the plastic ring thing out on the old cap. Put it on the tank and so far, no ce light. Been that way since 5/14. Hope this helps.
gurban is offline
post #8 of 13 (permalink) Old 06-05-2011, 02:15 PM
Date registered: Sep 2008
Vehicle: 1999 E320 190,000 miles sold 97 E320 288,000
Gurban - Seems like a great idea on breaking the white ring off. This is the second e320 I have had this problem with.
Frustrated today - I broke the white ring off as you suggested - and it works perfectly - seems to seal nice and tight. I will report back if I get the light for bad gas cap.
Cheers
DesertE320
deserte320 is offline
post #9 of 13 (permalink) Old 08-05-2016, 06:14 PM
Date registered: Aug 2016
Breaking off the white g is the sol. Thanks Gurban!!
hbell is offline
post #10 of 13 (permalink) Old 08-08-2016, 12:14 PM
gsxr's Avatar
Vehicle: Buncha W124's
Quoted: 50 Post(s)
You don't have to break anything. The problem is the tank filler neck flange, NOT the cap itself. Carefully bend the tangs back where they belong and the problem will be solved, most likely with your existing cap, no need to buy a new one.
To prevent this from happening again, DO NOT over-tighten the cap! That is what causes the issue in the first place.
gsxr is offline
    Stuck Gas cap (not) fixed Now new gas tank Chris Leon W210 E-Class 7 08-03-2012 10:23 AM
    Gas cap (petrol cap) doesn't lock Huwee R170 SLK-Class 4 08-23-2009 11:59 PM
    I am Screwed! Gas Cap stuck TyBenzo W210 E-Class 10 06-22-2007 05:17 PM
    Fuel filler cap (Gas cap) types26/36/74 R170 SLK-Class 2 09-28-2005 12:46 PM
    SL 320 gas cap, lots of pressure and gas on my shirt :-( e300d R129 SL-Class 2 07-21-2004 07:36 AM
