High Idle RPM in Idle when in P or N - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 03-21-2011, 11:27 PM Thread Starter
Date registered: Jul 2010
Vehicle: 2001 E270 CDI
Unhappy High Idle RPM in Idle when in P or N
In idle the RPM is in the 900-1100 range but if i put it in D or press the brake pedal when in P or N it drops down to normal 500-700. Any idea why idle speed is linked with the brakes?
The problem is more evident when the engine is cold and after it warms up RPM in Idle drop to about 800 range. I recently got the TPS changed and fuel pump was repaired.
carczar is offline
post #2 of 10 (permalink) Old 03-22-2011, 06:40 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
That sounds about normal to me.
If the car is otherwise running fine, why do you think something is wrong?
Just as a basic warm-up from a cold start you should let the engine come off of the initial fast idle before dropping it into gear and driving off.
Loaded (in gear) idle speed will always be lower than unloaded idle speed.
Hope that helps.
Check Codes is offline
post #3 of 10 (permalink) Old 03-22-2011, 08:11 AM
~BANNED~
Date registered: Oct 2010
Vehicle: 1999 E300 TD
At first glance I think you may have reversed your thinking----loading at idel does what??
Plutoe is offline
post #4 of 10 (permalink) Old 03-22-2011, 04:36 PM
Quoted: 35 Post(s)
^^^ Good catch. Posting from a 1.8" smartphone screen makes things look funny.
post #5 of 10 (permalink) Old 03-24-2011, 12:46 AM Thread Starter
Hope that helps.
But why would the revs drop when i press the brake pedal even when in P or N and go back up if brake is released. How is engine speed related to the brakes? Its not something serious but just want to make sure its not a precursor to a bigger problem down the road
carczar is offline
post #6 of 10 (permalink) Old 03-24-2011, 09:07 AM
wagonz's Avatar
Date registered: Feb 2010
Vehicle: '02 E320 4matic Wagon
Quoted: 14 Post(s)
When you press the brake, the vacuum booster for power brakes is in operation. So you will be drawing vacuum off the engine which can change the RPM. I have seen on a few of my cars the RPMs change a little, but not sure ever that much.
wagonz is offline
post #7 of 10 (permalink) Old 03-24-2011, 09:27 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
>>the brakes?
  • 900-1100 is high for idle in P.
  • On my car, after warming up, the rpm dropped to 800-900 in P. While in P, pressing the brake had no effect to the rpm.
The rpm only dropped when shift to D, R, ...
mbvis is offline
post #8 of 10 (permalink) Old 03-26-2011, 08:55 AM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(203K Miles), 2002 E320 Special Edition(174K Miles)
The OP has a diesel (CDI 270) so the idle speed will not be same as the gas/petrol model. Don't even know if the 270 is a 4, 5 or 6 cylinder and whether the brakes do use vacuum or a electric booster pump?
If vacuum, then it may be the booster going bad and allowing extra air in, instead of just using the vacuum to assist. Are your brakes working fine with a not too high an effort required? If effort is high, then brake booster seals may be bad and you are dumping extra air into the inlet system.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #9 of 10 (permalink) Old 03-26-2011, 09:26 AM
mbvis's Avatar
Quoted: 2 Post(s)
Whoah, diesel car gives better mileage but gets complicated.
mbvis is offline
post #10 of 10 (permalink) Old 09-15-2011, 02:42 PM
Date registered: Sep 2008
Vehicle: 2002 E430 4-Matic
Quoted: 33 Post(s)
What was the resolution??
I am having a very similar problem with a 2002 E430 4Matic. Idle speed with brake off is about 1,750 in P or N. Depress the brake and it drops to 800. Clearly not normal. I've been doing some searching and discovered that there is a Idle Speed Control component that takes one of it's inputs from the brake switch.
Figuero is offline
    high rpm 900 at idle when on P or N whatsoever C209/A209 CLK-Class 13 07-21-2011 01:53 AM
    High rev and RPM idle after start ajent420 W210 E-Class 4 04-14-2009 09:31 AM
    High Idle Rpm Chop 'n' Join W126 S,SE,SEC,SEL,SD,SDL Class 13 10-29-2006 08:49 AM
    High engine idle RPM goodguy2 Vintage Mercedes-Benz 1 10-19-2006 04:48 PM
    IDLE got high RPM panjap W202 C-Class 3 09-29-2006 11:42 PM
