1997 e420 thermostat grrrrrrrrrrr.... - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 02-16-2011, 12:09 PM Thread Starter
Date registered: Aug 2010
my thermostat is stuck open and the engine temp takes 20-25 min to get up to 80 degrees celsius. i got a new thermostat a couple days back and i wanted to replace it right now but i have to idea how to get to it.... there are three bolts holding it down to the water pump but only 2 of them are easily accessible. to me it looks like ill have to take off the V-belt and the water pump to take the bad thermostat off, unless there is a way to unscrew the third bolt in the back which i cant figure out how... i thought this was supposed to be an easy job that usually takes no more than 30 minutes
polishmatt1990 is offline
post #2 of 18 (permalink) Old 02-16-2011, 08:23 PM
Date registered: Jan 2008
Vehicle: W210 1996 E320 Smoke Silver. [W124 1990 300CE Artic White - Sold].
For the 3rd bolt in the back I used a ratchet with an extension on my 1996 E320.
http://www.benzworld.org/forums/w210...placement.html
W210 1996 E320 Exterior Smoke Silver, Interior Mushroom, 159,999 miles as of 09/09/09, 170K as of 02/01/2011.
texholdem is offline
post #3 of 18 (permalink) Old 02-16-2011, 10:07 PM Thread Starter
i saw that DIY but my thermostat location was different for some reason. it was on the left side of the water pump and parallel to the ground. i got it done but it took me a good couple of hours. maybe ill take a picture of it later and post it here.
matt
post #4 of 18 (permalink) Old 02-20-2011, 10:19 AM
atmsmshr's Avatar
Date registered: Jul 2009
Vehicle: Current - 2013 GLK350, 2007 S550, 2002 S430, 1998 ML320. Deceased - 1974 240D, 1992 400E, 1997 E420
Location: An island off the coast of Florida **Use startekinfo.com for official Mercedes technical guidance**
Quoted: 91 Post(s)
M119 thermostat change
Without a doubt, replacing a thermostat on my E420 last Christmas was one of the most aggravating jobs I have done because I went into it thinking, how hard could this be? I mean - really? Grrrrrrrrrr
Combined this job with a coolant system drain, belt replacement and a Duovalve changeout. Fully committed by cutting off the short angle hose using garden shears, which was later a bear in itself to get the new one back on. (Had to boil the hose to soften it and use silicone grease to slip it back on - hated to do that, used as little as possible grease on the interior of the hose as to not contaminate the coolant system.)
Had to try 3 different socket - rachet combos before finding one that (barely) worked to put back the 10 mm capscrew on the opposite side of the garden shears. Settled on a tiny 1/4 combo set. Don't even think about trying to get a torque wrench on these capscrews. Another reason to use the 1/4 mini set.
TIPS - This job required removal of the serpentine belt, and removal of the oil dipstick capscrew tube to engine block bushing to access everything, particularly the back bolt. (Second photo with oil tube pushed away.) Another lesson learned, remove the engine oil dipstick and put something in place to avoid dropping anything down into the engine. I kept the dipstick in place and wound up breaking off the plastic red head with one bump. (That piece of wisdom cost me $29, and I never found the red head that rattled down.)
ID:	358249   Click image for larger version
atmsmshr is offline
post #5 of 18 (permalink) Old 02-21-2011, 05:35 AM Thread Starter
yup thats the same one i have. i used a combination of a 2 inch socket extension and one of those universal joint sockets to get that bolt out and i still had trouble. there is barely any working space in there and one of the sockets fell underneath the water pump on top of the frame and i couldnt even get it out... but i think it fell out when i first drove it after the job... what was mercedes thinking designing this car... there are so many things that in most other cars are simple but in this car they are just a pain in the a**...
post #6 of 18 (permalink) Old 02-21-2011, 08:25 AM
Kajtek1's Avatar
Quoted: 1250 Post(s)
That is why I love I6 engines
I still remember older V8 engines, that required spark plug replacement via wheel wells. Those were 20,000 miles spark plugs.
Kajtek1 is offline
post #7 of 18 (permalink) Old 02-22-2011, 04:20 PM
atmsmshr's Avatar
Quoted: 91 Post(s)
Matt - I was speculating that the M119 thermostat designer was a decendent of Marquis de Sade. The only other thing I've encountered of equal cruelty was replacement of the front driver side O2 sensor.
My E420 has marginal heat removal in the summer, wanted to see if the old thermostat popped late or was clogged. No such luck, it popped 80 deg C on the stove top inside my wife's best sauce pan using the turkey thermometer. (I still regret getting caught on that one.)
Kris - changing plugs through a wheelwell? Yikes!
Mike
atmsmshr is offline
post #8 of 18 (permalink) Old 02-22-2011, 04:33 PM
Musikmann's Avatar
Quoted: 6 Post(s)
atmsmshr,
You forgot the location of the evaporator!
Musikmann is offline
post #9 of 18 (permalink) Old 02-22-2011, 04:48 PM
atmsmshr's Avatar
Quoted: 91 Post(s)
Musikman - I'll pray to the good Lord that mine holds up and let me pass on those tight confines.
atmsmshr is offline
post #10 of 18 (permalink) Old 02-22-2011, 04:52 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Haha, same here!
    how hard is thermostat DIY install on 97 E420? ProV1x W210 E-Class 11 03-05-2016 08:10 AM
    Pro's and cons of a 1995 E420 and a 1997 E420 London380sl W124 E,CE,D,TD Class 24 05-19-2011 08:30 PM
    E420 V8 M119 thermostat change, diy? KC420 W210 E-Class 0 10-28-2008 12:26 AM
    Please HELP "94 E420 ??NO Thermostat?? chance2benz W124 E,CE,D,TD Class 7 10-26-2008 01:39 PM
