98 E300 TD Fuel line replacement tips needed - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 01-14-2011, 05:44 PM   #1 (permalink)
Date registered: Sep 2009
Vehicle: 1998 Mercedes Benz E300 Turbo Diesel
Thanks in advance for readin my post. I am working on replacing the o-rings in my fuel lines wit the more durable Viton o-rings. I was able to get one of the fuel lines off, but I am having a very hard time, pushing it back in, after replacing the o-ring. Te new o-rings are identical to the ones being replaced.
I was wondering if there is a simple method to getting it pushed back in place. Tapping with a rubber mallet perhaps?
Thanks
carl6405 is offline   Reply With Quote
Old 01-14-2011, 09:33 PM   #2 (permalink)
Kajtek1's Avatar
Vehicle: W210 E300DT x2 / Ford SD, JDtractor. Seeking diesel lawnmower
Should snap on with firm finger push. Put some motor oil on them if it is extremely hard.
I had bad experience with Viton orings and learned the hard way to replace whole lines with new orings on them. They are not that expensive.
Kajtek1 is online now   Reply With Quote
Old 01-15-2011, 01:17 AM   #3 (permalink)
Thanks Kaitek. I will try dropping some oil on them and see if that makes it easier.
Actually, the line I am having trouble with is a new replacement. But, I removed the stock o-ring and replaced it with the Viton. People swear by these o-rings, so, I wanted to give them a try. I would like to hear about your bad experience with these Viton 0-rings.
Thanks
Old 01-15-2011, 03:56 AM   #4 (permalink)
~BANNED~
Date registered: Oct 2010
Vehicle: 1999 E300 TD
Yep there are push fit with the locking slide. My guess is that you have the wrong size and wrong MB part.
Like suggested purchase the hose and you will have the proper o ring already pressed to the fitting. Good luck
Plutoe is offline   Reply With Quote
Old 01-15-2011, 07:34 AM   #5 (permalink)
Summary,
I had purchased the new fuel line, because I had broken the plastic piece when removing it. I removed the o-rings that came on the new fuel line and replaced them with the viton o-ring. Couldnt push it down in. Put the original (new)o-ring back on and it pushed in place, no problem.
Now, I had already replaced one of the lines o-rings with Viton, prior to this particular fuel line. It was hard to push back on, but it did go in.
If I have trouble with the next o-ring replacement, (I'm working on replacing all the orings on the fuel lines) then, I will just buy new fuel lines and keep and not replace the o-rings on the new line.
Thanks for the tips.
Old 01-15-2011, 07:54 AM   #6 (permalink)
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2000 S210 E320CDI Avantgarde
Send a message via ICQ to renault12ts Send a message via AIM to renault12ts Send a message via MSN to renault12ts Send a message via Yahoo to renault12ts
Good idea.
If your lines are the age of the car, then they, as well as the O rings, will be hardened. Replace the lot. Vitron is not needed. Think how long the original O rings have lasted.
renault12ts is offline   Reply With Quote
Old 01-15-2011, 09:01 AM   #7 (permalink)
Kajtek1's Avatar
My bad experience with Viton orings not necessary had to be material related. I bought a Viton kit from internet seller and install them on old tubings. The old tubings did show material aging and removal of old orings brings risk of scratching the plastic seats.
My conclusion was that the seats wear out over the years as much as orings.
Than new tubings come with orings already on them, while news say the new MB orings are better than original stuff.
Bottom line -even having Viton orings I didn't want to mess up OEM tubings.
If I will have to replace them again in 10 years, so be it.
Old 01-15-2011, 09:14 AM   #8 (permalink)
Kaitek, I have to agree with you, now that I have had a bad experience with trying to get the Vion orings on. Maybe I orderd the wrong ones. But, yeah. The old lines are originals and not hard to replace when using the new lines and, not to expensive.
Old 01-17-2011, 08:39 AM   #9 (permalink)
Date registered: Jan 2004
I replaced my fuel lines with new ones maybe five years ago. Popped off the O-rings that came with them and popped on the viton ones I bought from Jim at Fryer Power. Had no issues at all and no leaks so far.
Len
'59 220S Cabriolet
'83 240D original owner 348,000 miles
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 170,000 miles
'03 SLK320 27,000 miles
sokoloff is offline   Reply With Quote
Old 11-01-2011, 08:19 PM   #10 (permalink)
Date registered: Aug 2011
Vehicle: 1998 E300 Turbo Diesel, 1982 300SD Turbo Diesel
Send a message via Skype™ to Danpico
where can i get new fuel lines?
is there a kit? do you have a part number or should i just go to a MB dealership? I have a E300 1998, I see bubbles in the fuel lines.
thank you
danpico
Danpico is offline   Reply With Quote
Bookmarks
98 E300 turbo diesel with bubbles in fuel line ghardy W210 E-Class 12 12-28-2010 02:04 PM
Fuel line part number needed rocketman4321 W163 M-Class 3 10-30-2010 05:54 PM
Massive fuel line failure '95 E300 DIESEL sbaert W124 E,CE,D,TD Class 3 10-22-2008 07:28 AM
Cleaning tips NEEDED '97 E300 diesel Interior/Exterior michakaveli W210 E50 AMG, E55 AMG 2 11-03-2002 12:39 PM
Cleaning tips NEEDED '97 E300 diesel Interior/Exterior michakaveli W210 E50 AMG, E55 AMG 0 10-09-2002 09:28 PM
