oil pan removal help pls - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 01-08-2011, 03:58 PM   #1 (permalink)
Date registered: Jul 2008
Vehicle: 2000 E320
I was trying to replace a little leakage from the oil level sensor on a 00 E320. I drained the oil and removed all the bolts. next is to remove the oil pan. it won't budge. trying to pry it out a little bit but I stopped. I was afraid I may break something. Could someone please advise me on how remove the oil pan? any secret please? the silicon made it stick like glue. I searched the forum but could not find anything.
Please help!!!!!!!! Thx
Tom
1nmlbenz is offline   Reply With Quote
Old 01-08-2011, 07:31 PM   #2 (permalink)
Musikmann's Avatar
Vehicle: 2001 E320 - Brilliant Silver/Ash: 99,000+
Sounds like it's been on there a long time and the gasket/sealer has hardened. Try using a flat blade screwdriver, gently wedge it in and pry every few inches all around.
Old 01-08-2011, 09:35 PM   #3 (permalink)
Kajtek1's Avatar
Vehicle: W210 E300DT x2 / Ford SD, JDtractor. Seeking diesel lawnmower
I think using gasket softener (remover) might help.
Than you can take a sharp knife and start undercutting the gasket on one side. Be careful not to score the aluminum.
Kajtek1 is offline   Reply With Quote
Old 01-08-2011, 10:17 PM   #4 (permalink)
Musikmann's Avatar
Thank you Kajtek1, I thought of that too but did not know what product would do that.
Old 01-08-2011, 10:26 PM   #5 (permalink)
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Dental floss works well with silicone gaskets. Work it in on the corners of the pan. It will slide in and break the seal and you have no chance of gouging the cast aluminum. Waxed works best, work it back and forth just like you were getting it between teeth.
I assume you are working on just the lower pan, too.
You can also put the drain plug back in and use a box-end wrench on the plug to get some leverage sideways against the pan.
Good luck.
Check Codes is offline   Reply With Quote
Old 01-09-2011, 08:43 AM   #6 (permalink)
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(165K Miles), 2002 E320 Special Edition(147K Miles)
But it's such a drag rewinding the floss back onto the spool again for using to floss yout teeth again.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Old 01-09-2011, 09:48 AM   #7 (permalink)
Vehicle: 1999 E430
Besides the pan bolts, the ATF lines need to be detached from the pan.
The level sender o-rings are available separately from the sender. Part number A023 997 43 48 or 70 48.
Hirnbeiss is offline   Reply With Quote
Old 01-09-2011, 09:53 AM   #8 (permalink)
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Pages from E-class petrol 1983-2000 workshop book.
mbvis is offline   Reply With Quote
Old 01-09-2011, 10:10 AM   #9 (permalink)
Musikmann's Avatar
Dental floss trumps my screwdriver suggestion by a mile in term of doing no damage. And a thin knife is a better idea than mine too. Good luck.
Old 01-09-2011, 01:58 PM   #10 (permalink)
The OP can ignore all of that. He's only dropping the lower oil pan, #35 in the drawing. Pull the bolts, clear the cooler lines, break it loose, off it comes.
Bookmarks
260E oil pan removal. Stych W124 E,CE,D,TD Class 3 05-10-2009 02:14 PM
Oil pan removal? Help please anyone?! TyMad101185 W202 C-Class 0 11-11-2008 04:14 PM
crossfire oil pan = e320 oil pan? (upper pan removal?) fastmayte W210 E-Class 4 06-28-2008 04:06 PM
Oil pan removal and I found... Chaw W123 E,CE,D,CD,TD,TE Class 4 11-21-2006 08:26 AM
oil pan removal help euroamg W126 S,SE,SEC,SEL,SD,SDL Class 2 03-21-2006 05:10 AM
