Washer Nozzle Removal? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 01-03-2011, 11:47 AM   #1 (permalink)
Date registered: Mar 2009
My E430 4Matic's windshield washers are not working. How do you remove the nozzle assembly from the underside of the hood (bonnet)? How do you replace it? How do you remove the nozzles from the assembly? I'm hoping to avoid what the dealer says would cost hundreds of dollars! I'd be grateful for any advice.
bwosl is offline   Reply With Quote
Old 01-03-2011, 12:01 PM   #2 (permalink)
Musikmann's Avatar
Vehicle: 2001 E320 - Brilliant Silver/Ash: 99,000+
Not enough information given.
What did the dealer say the problem is? See if the pump still works and if so then check for loose or leaking hoses. There is also a possibility that the nozzles are clogged and you can clear those with a safety pin or something similar. Or maybe it's the switch in the stalk. Then again it might be a fuse/relay.
Old 01-03-2011, 03:34 PM   #3 (permalink)
Thank you for your reply. The dealer said he thought it was clogged nozzles, and I tried a single thin stiff wire from a wire brush in the openings of the nozzles. The wire went in alomst 1cm, and I moved it in and out in hopes of scrubing the interior of the nozzles. The wire might have been too thin, it was much smaller than the diameter of the openings. There was no change after using the wire.
One of the nozzle units squirts feebly and the other has good flow, but comes flowing out from somewhere in the nozzle unit, but not through the nozzle openings.
The dealer said that the parts are $50 each, so if I replaced them myself, I'd save the labor charge, which apparently is over $100.
Is it difficult to remove and replace the nozzle units? How do you do it? Do you need special tools?
Old 01-03-2011, 05:14 PM   #4 (permalink)
juve010's Avatar
Date registered: Aug 2010
Vehicle: 01 e320 4matic wagon
http://www.caschy.com/benz/docs/nozzle1.pdf
this doesn't really help much but at least it shows the angle/position of the nozzle squirting direction
Can't find anything in WIS to show about removing them...wierd
01 e320 4matic wagon - Travertine Beige/Java - 18" AMG reps, Lorinser roof spoiler, depo xenons (6k w/silverstars in hb), depo cyrstal fogs,clear side markers w/chrome bulbs, alum doorpins and surrounds, chrome gauge rings, LEDs in gauge cluster, alum "MB" engraved pedals, oem all-weather MB floor mats w/ oem cargo liner, OEM rear side window shades, Custom shift boot, 7" headrest monitors, IPOD touch multimedia system(mp3, video, GPS) 3G data via VirginMobile MIFI = (streaming xm and TV!!!)
juve010 is offline   Reply With Quote
Old 01-03-2011, 06:04 PM   #5 (permalink)
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(165K Miles), 2002 E320 Special Edition(147K Miles)
Thanks for the spray pattern document. I've been looking for it for ages.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Old 01-04-2011, 11:16 AM   #6 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2010 E350(R.I.P) 2011 E350
The Specified Tool (110 589 02 63 00) aka Hazet 4850-1 is a Nifty "Dual Purpose" device which has come in quite handy.
Yes, the One End has the Needle for Cleaning and Adjusting the Windscreen Sprayer Nozzle, but the other actually hasn a Magnet in the Telescoping end used to direct the spray pattern.
Great for those "Doohhhhooo" moments when you drop a ferromagnetic piece into the engine bay....
http://www.samstagsales.com/images/hz4850-1.jpg
G-AMG is offline   Reply With Quote
Old 01-04-2011, 11:42 AM   #7 (permalink)
Kajtek1's Avatar
Vehicle: W210 E300DT x2 / Ford SD, JDtractor. Seeking diesel lawnmower
Well ,,,,, I am disappointed. I pulled my slide caliper to do a perfect job only to discover there are no measurements given.
Kajtek1 is offline   Reply With Quote
Old 01-05-2011, 06:26 AM   #8 (permalink)
~BANNED~
Date registered: Oct 2010
Vehicle: 1999 E300 TD
Just because water does not come squirting out---------how do you automatically know that both nozzles went bad, at the same time!! That is a leap of faith. Then to add insult to injury you go and get a sharp pin or some other Chinese knock off tool, insert the tool and puncture the squirter diaphragm and ruin a 32 dollar part.
Why not first disconnect one of the nozzles and press the switch----does water come out of the hose-------then do the same on the other side. What happens??? Ding How!!
Plutoe is offline   Reply With Quote
Old 01-05-2011, 06:35 AM   #9 (permalink)
Vehicle: 2000 E430 (base), 77 450SL, 89 420SEL, 97 E420
Is this available at big box stores, or a MB only part?
Thanks,
Weegee14 is offline   Reply With Quote
Old 01-05-2011, 06:50 AM   #10 (permalink)
~BANNED~
Remember the real MB part looks nothing like the Hazet Chinese knock off.
The MB part is a 33 dollar part---get the dealer part-----no sharp edges and the correct length!!
Bookmarks
Headlight washer nozzle dfwcl500 W215 CL Class 1 08-19-2010 07:22 PM
Washer Nozzle cookie79 R/C107 SL/SLC Class 8 08-22-2007 12:28 AM
Windscreen washer nozzle removal..? Slk230UK99 W163 M-Class 3 12-09-2006 06:53 AM
Washer Nozzle Wires Cheelyv W126 S,SE,SEC,SEL,SD,SDL Class 2 06-17-2006 06:20 AM
Washer nozzle heat Airjunky W163 M-Class 6 01-01-2005 10:55 PM
