MAF replacement - can't remove it... - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 12-16-2010, 07:32 PM Thread Starter
Date registered: Dec 2006
Vehicle: 1997 E420
Does anybody know how to remove the MAF unit on a 97 E420? I tried today but couldn't get it out. Removed the plastic cover and had the MAF in front of me. Could unplug the sensor, the other connector adjacent to it and I could twist it a bit but I could not remove it. Anybody know how to get it out?
thank you very much for the help.
nvest80 is offline
post #2 of 14 (permalink) Old 12-16-2010, 07:39 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 134 Post(s)
Try this, three clips on the other end from the clamp/ring:
how to remove the MAF on 97 E420? - MBWorld.org Forums
fabbrisd1 is offline
post #3 of 14 (permalink) Old 12-16-2010, 09:51 PM Thread Starter
Vehicle: 1997 E420
thanks for the reply. I did a search but must have missed the one you linked to. I found the DIY for the 94 model but that one is different. Will give it another try tomorrow.
nvest80 is offline
post #4 of 14 (permalink) Old 12-16-2010, 10:05 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
That model is a known nightmare for pulling the MAF assembly. A flex-shaft screwdriver is helpful to get to the clamp; alternatively a 1/4" ratchet may assist.
You could also look in the W140 and W124 forums as well as the R129, all of them had your M119 engine, same MAF configuration.
Good luck, you have my sympathy.
Check Codes is offline
post #5 of 14 (permalink) Old 12-17-2010, 09:12 AM Thread Starter
Vehicle: 1997 E420
ok, good to know it's not just me. I'm by no means a mechanic but I enjoy learning and doing things myself. So far I've exchanged the A/C control CPU, the rear window regulator and the radiator. I would like to learn more and be able to do more repairs and replacements myself.
Now I want to get the MAF done and as simple as it should be I just struggled with it. I would also like to replace the spark plugs but would feel more comfortable if I could see pics of a DIY job. I took a closer look at it yesterday removed some of those metal clamps. Wow, one of those metal clamps was nearly impossible to put back on. I either put it on first and then I couldn't "squeeze" the clamp enough so it would snap on, or I'd end up putting it on only to not being able to secure it with the clamp afterwards. No room for my fingers...I ended up using a tiny cable tie. This way I could have the clamps squeezed together "permanently" as the cable tie "squeezed" that metal clamp. With that help I could easily put the metal clamp back on and I then used a knife to cut the cable tie and the clamp snapped right back to secure the piece in place.
I see now...a flex screw driver is what I need...thanks...wish this MAF was horizontally placed in the open like I saw in some pictures of V6 320s...that would make it so much easier to work on.
nvest80 is offline
post #6 of 14 (permalink) Old 12-17-2010, 09:33 AM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
Without the right tool, the MF in MAF mean something else to a mechanic.
mbvis is offline
post #7 of 14 (permalink) Old 12-17-2010, 10:04 AM Thread Starter
Vehicle: 1997 E420
You lost me there.
I was looking at replacing this
but can't remove it. I can see the screw but it's situated horizontally without much room to work on so I i can't get to it. I'll buy a flex shaft screwdriver later today and give that a try.
Could you please elaborate in what you meant with "the MF in MAF mean something else to a mechanic." Thank you.
nvest80 is offline
post #8 of 14 (permalink) Old 12-17-2010, 10:58 AM
Quoted: 35 Post(s)
Originally Posted by nvest80 View Post
You lost me there.
"MF" is shorthand for a common curse-phrase, one that appeared in all versions of Carlin's "Seven Words You Can't Say on Television".
It might, perhaps, be uttered or shouted by someone trying to remove the screw on that clamp.
Hopefully the head of the clamp is a hex (they often are, around 7-8mm or 5/16"), so you can actually use a flex-shaft 1/4" drive socket on it. Trying to keep a flat-blade screwdriver tip aligned while using a flex-shaft driver will typically cause the utterance of many curse words.
post #9 of 14 (permalink) Old 12-17-2010, 12:56 PM
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Quoted: 132 Post(s)
I recently had trouble removing my MAF on the M119 of the W140...
Out of all the "toys" at my disposal, the ONLY thing which worked was the 12 point 7mm Deep Offset Spanner.
G
G-AMG is offline
post #10 of 14 (permalink) Old 12-17-2010, 01:49 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
Looking at the picture -that looks like a job for my 1/4" nut driver with 10" extension and U-joint right at the socket.
Kajtek1 is offline
    How to remove the MAF on V8? sniperdude W140 S-Class 151 05-27-2013 02:46 AM
    How remove MAF on 430CLK ??? Pancho C208/A208 CLK-Class 4 05-29-2009 06:33 AM
    How to remove MAF sensor on 97 E420? ProV1x W210 E-Class 0 03-28-2007 04:19 PM
    how to remove MAF from 97 E420? cabby850 W210 E-Class 1 01-15-2007 02:29 PM
    Anyone Know how to Remove the MAF (2003 C230K)? dexter.clampett W203 C-Class 2 09-19-2006 04:46 PM
