Weird Oily, Odorless, Colorless Substance Leaking on Garage Floor--1998 E300 DT - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-08-2010, 05:27 PM Thread Starter
Date registered: Jul 2009
Vehicle: 1995 E320, 1998 E300 Turbodiesel, 1999 E320 4M Wagon, 2001 E320
I need some help identifying a leak under my 1998 E300 Turbodiesel. There is a long oily, odorless, and colorless trail left under my car overnight. I thought it was water until I felt how slick it was. No diesel odor. No black diesel oil color. Anyway, today the check coolant light came on which really puzzled me because coolant isn't greasy is it?
Any suggestions would be great!
Happy Holidays!
RLGDiesel is offline
post #2 of 5 (permalink) Old 12-08-2010, 05:53 PM
Date registered: Jan 2008
Vehicle: 2001 Mercedes Benz E320
Coolant is kind of greasy. The higher the ratio of coolant to water, the greasier it is.
winerocks is offline
post #3 of 5 (permalink) Old 12-09-2010, 08:01 AM
~BANNED~
Date registered: Oct 2010
Vehicle: 1999 E300 TD
Happy Holidays!
Well if the check coolant light came on, and before starting the car I would check the coolant level.
If needed, I would add distilled water. Then with the hood open, start the car and while heating up, run the heater on high and start looking for leaks.
You also have a good holiday season!!
PS: Regarding the long slime line, that could have been the result of what you ran over earlier in the day!!
Plutoe is offline
post #4 of 5 (permalink) Old 12-09-2010, 09:24 AM
Kajtek1's Avatar
Quoted: 1193 Post(s)
The belly pans make detecting leaks and sources pretty tricky. You can wash the car in the morning and in the evening pulling on steep driveway you will have good amount of oily water coming out of the pans.
Check the coolant level for sure and start with taking a look at the water pump and radiator hoses.
Kajtek1 is offline
post #5 of 5 (permalink) Old 12-09-2010, 04:03 PM Thread Starter
Thanks for the input everyone...problem solved...WATER PUMP!
    GARAGE FLOOR MATT32AMG R170 SLK-Class 19 12-13-2010 07:44 AM
    oily substance rayzx W163 M-Class 4 11-30-2009 04:06 PM
    identify "oily" substance bababoy W124 E,CE,D,TD Class 6 05-06-2008 09:55 PM
    Best garage floor surface kingjnod R129 SL-Class 7 02-04-2008 07:50 PM
    Dark oily stuff in garage.... Ometofu W163 M-Class 0 01-18-2004 07:53 AM
