ABS, ESP, BAS Warning Lights with Faulty Brake Light Indicator... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-04-2010, 03:40 PM Thread Starter
Date registered: May 2009
Hey Folks,
I have an 02 E430. Recently I came across the issue with ABS, ESP, BAS Warning Lights with Faulty Brake Light Indicator coming up on my dash. The problem was intermittent, then became a hard fault. I started by changing the brake switch, however that was not the cause of the faults. The car would fire the code as soon as I pressed the brake pedal. I would get the faults and my brake lights would stop working. I've seen MANY threads on the internet with individuals with similar cars complaining about this issue. I was able to narrow down the issue to the actual 'headlight switch'. I swapped the headlight switch for a new one, it was roughly $250 CDN. The lights all disappeared and my brake lights began working again. The car went to about 6 different mechanics before it was diagnosed. MB wanted to change my ABS module, however I was certain that was not the issue. Nonetheless, if you encounter this particular issue, your 'headlight switch' can be a likely culprit.
Cheers,
Ricky P.
RickyP is offline
post #2 of 3 (permalink) Old 09-04-2010, 04:12 PM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 169 Post(s)
Do you mean the round switch used to turn the lights on and off etc?
2005:
http://www.benzworld.org/forums/signaturepics/sigpic199506_2.gif
renault12ts is online now
post #3 of 3 (permalink) Old 09-04-2010, 04:24 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
I regularly had those brake related lights come on, but after installing new battery I have not seen them. I imagine there could be various causes, especially ones that reduce voltages like bad contacts or grounds.
MBGraham is online now
Help. Brake light fuse keeps blowing- ABS, BAS, ESP lights on neilclarke W210 E-Class 29 09-28-2013 08:25 AM
ABS, BAS, ESP and Brake warning lights on intermittently simonva R170 SLK-Class 8 10-13-2008 07:20 AM
abs and bas esp warning lights rxphiler C208/A208 CLK-Class 9 10-29-2007 10:33 AM
BAS/ESP & ABS Fault Indicator Light On rca918 Vintage Mercedes-Benz 0 04-27-2006 04:18 AM
ABS and BAS/ESP warning lights ON?? koosha R170 SLK-Class 5 02-22-2005 08:55 AM
