97 E420 Shutting off - Mercedes-Benz Forum
post #1 of 44 (permalink) Old 04-30-2010, 02:43 PM Thread Starter
Date registered: Nov 2005
Vehicle: 1985 190E 2.3 --- Slate w/ Burgundy interior----------1997 E420 ---Blue w/ Tan interior
Hi. My 97 E420 just started shutting off when at a stop. I actually had check engine codes, and replaced 2 ignition coils, but as soon as I did, it started stopping and the battery charge and asr lights came on. I took the battery to Autozone to test, and they said it was bad, and I replaced it. I didn't think it was the battery anyway. I opened the hood and I see I need to replace the serpentine belt, but I think it's the alternator. Just trying to see if that's what you all think. It seems like it only shuts off when the temp get around 100, so maybe it's a pump or something? I don't know. Thanks in advance for your help.
'85 190E --- Slate w/ Burgundy interior
'97 E420 --- Blue w/ Tan interior
crownluv is offline
post #2 of 44 (permalink) Old 04-30-2010, 04:46 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I fail to see the cause and effect relationship between changing the ignition coils and your more recent symptoms. Ignoring those for the moment, a successful cold start and a stall once the engine is hot sounds like your crankshaft position sensor. There are several threads discussing these. Does it start again after a 10-15 minute cool down period?
Musikmann is offline
post #3 of 44 (permalink) Old 04-30-2010, 06:28 PM Thread Starter
Oh, I wasn't trying to connect the two, just that it happened right after the other. The engine starts back up immediately. I replaced the camshaft position sensor a little less than a year ago, so I hope that isnt it. It also feels like it drains energy when I use the windows or the A/C, and today when I was driving, low speed, it felt like it wanted to stall, you know, rpms surging. Also, there's no check engine light on, I believe it was on when I replaced the position sensor. Thanks again.
I did a little more reading, sorry, I see there's a difference between the two. I'm ordering a crank position sensor now. Thanks
crownluv is offline
post #4 of 44 (permalink) Old 04-30-2010, 07:17 PM
Musikmann's Avatar
Quoted: 6 Post(s)
The abbreviations are confusing. CPS should always mean camshaft and KPS crankshaft. From what I've read the KPS is by far the more commion failure.
If you notice a current drain when using windows or A/C I think you might be spot on regarding the alternator diagnosis. That is if you have the proper battery installed correctly.
post #5 of 44 (permalink) Old 04-30-2010, 08:57 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 136 Post(s)
Well...
I am in agreement with M-Man, you may have a couple of things going on.
Check the stickies under CPS sensor replacement..if you are saying this was changed about 1 year ago, if that was not the OE part but non-mname equivalent your current failure would be right about on schedule. The OE part will go out another 100K. A CPS that is failing will cause the car to shut down like a cut off switch, often coming to a stop, and also commonly cause start up problems when warm. These problems happen more and more often as the CPS progressively fails.
If it feels your engine is "cking" coming to a braked stop, and the RPM's drop like it's going to die, but catches itself..and progressively gets worse, then that could be a sysmptom from a failing MAF.. you have to watch out for a LOT of knock off and rip off low prices internet MAF's, if you go to replace buy from a reputable source like oft mentioned vendors here on this forum like autohausaz.com
Keep the faith !
fabbrisd1 is offline
post #6 of 44 (permalink) Old 05-10-2010, 07:13 AM Thread Starter
Ok..I replaced the KPS, and I'm still having the same problem..when the temp guage get around 80-100, it shuts off at stops. I have to keep my foot on both gas & brake, and it still feels like it's trying to shut off. And when it does, the ASR and battery lights come on.
So, do I go to the MAF next, or are there any other ideas? Thanks in advance.
crownluv is offline
post #7 of 44 (permalink) Old 05-10-2010, 08:26 AM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 147 Post(s)
you mentioned pulling the error codes. what were they?
raymond-
47º34'N 122º18'W
raymond- is offline
post #8 of 44 (permalink) Old 05-10-2010, 08:33 AM Thread Starter
No error codes are coming up. The last code I got was for the cylinder 3 ignition coil, which I guess is unrelated. When it stalls, the ARS and battery light come on, but that's all.
crownluv is offline
post #9 of 44 (permalink) Old 05-10-2010, 11:54 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
The lights that come on when it stalls are typical since voltage drops, so ignore that.
There is no such thing as a code for an ignition coil; I have no idea what you mean.
What *exactly* are you doing to check for codes?
Check Codes is offline
post #10 of 44 (permalink) Old 05-10-2010, 03:15 PM Thread Starter
The code was P0303 - Cylinder 3 misfire. I changed the ignition coil and it went away..I don't think it is related to the issue I'm having now. I check for codes at Autozone, but there is no CEL on, so I haven't checked for anything since the P0303 code was cleared a couple weeks ago.
crownluv is offline
Shutting Down vs Idling keyvon61 W123 E,CE,D,CD,TD,TE Class 7 02-16-2010 06:50 AM
Help with 200d not shutting off! jb.kiteley Vintage Mercedes-Benz 6 06-30-2009 11:57 AM
Radio shutting off blaydrunner W201 190-Class 8 05-22-2007 05:05 AM
A/C keeps shutting off...then on....then off!!! DestroyerW140 W140 S-Class 8 08-03-2006 08:06 PM
shutting doors golfer W163 M-Class 10 07-07-2001 11:15 AM
