As I step through some of my own climate control issues and vacuum leaks. The Individual Flap test is mentioned on page 35 of the AC Diagnostic thread in the w210 Sticky, but I never found the comprehensive chart that described this flap test on benzworld. So after some googling around the web, I came across the info on this website and decided to document and share over here.
MERCEDES-BENZ: A/C Diagnostics & Evaporator Replacement
It references an article by Steve Brotherton in Import Car (April 2001).
"MERCEDES-BENZ: A/C DIAGNOSTICS & EVAPORATOR REPLACEMENT"
The Individual Flap Tests are run by idling the engine, pressing the left and right "AUTO" buttons, setting temperatures to 72°, manually opening the fascia vents, and simultaneously pressing the "Rest" and "Recirculate" buttons for more than five seconds. The first step: Left display "0" and right display "LO" should appear. Pressing the left "AUTO" button changes the steps. Pressing the right "AUTO" button varies the two modes "HI" and "LO" for each step.
Just in case the website ever seems to vanish, I've taken the time to type up Chart 2 from the above link which details all the individual DTC to test flap operation in our climate control.
Chart 2 Diagnosis-- Individual Flap Test (via A/C Pushbutton Control Module [N22])
Diagnostic Trouble Code(DTC) Activated Flap Right Display Nominal Value/ Air ouput
0 All LO No flaps are activated(closed)
0 All HI All flaps opened (activated)
1 Left Diverter flap LO Left center outlet closed.
1 Left Diverter flap HI Left center outlet opened, cold air.
2 Right Diverter flap LO Right center outlet closed.
2 Right Diverter flap HI Right center outlet opened, cold air.
3 Left blend air flap LO Left center outlet closed.
3 Left blend air flap HI Left center outlet, warm air.
4 Right blend air flap LO Right center outlet closed.
4 Right blend air flap HI Right center outlet opened, warm air.
5 Left defroster flap long stroke LO Side defroster leak air.
5 Left defroster flap long stroke HI Side defroster maximum air.
6 Left defroster flap long and short stroke LO Left defroster outlet closed.
6 Left defroster flap long and short stroke HI Left defroster outlet opened.
7 Right defroster flap long stroke LO Right defroster flap open, leak air.
7 Right defroster flap long stroke HI Right defroster flap opened.
8 Right defroster flap long and short stroke LO Right defroster flap closed.
8 Right defroster flap long and short stroke HI Right defroster flap opened.
9 Main air flap long stroke LO Fresh air flow.
9 Main air flap long stroke HI Recirculated air 80%
10 Main air flap long and short stroke LO Fresh air flow.
10 Main air flap long and short stroke HI Recirculated air 100%.
11 Left footwell air flap long stroke LO Left footwell air flap closed.
11 Left footwell air flap long stroke HI Left footwell air flap opened, leak air.
12 Left footwell air flap long and short stroke LO Left footwell flap, leak air.
12 Left footwell air flap long and short stroke HI Left footwell flap, opened.
13 Right footwell air flap long stroke LO Right footwell flap, closed.
13 Right footwell air flap long stroke HI Right footwell flap opened, leak air.
14 Right footwell air flap long and short stroke LO Right footwell flap, leak air.
14 Right footwell air flap long and short stroke HI Right footwell flap, opened.
15 All Flaps LO No flaps are activated(closed)
15 All Flaps HI All flaps activated (opened).
