How to clear codes - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-20-2010, 01:24 AM Thread Starter
mahicks3's Avatar
Date registered: Mar 2009
Vehicle: '98 E320
How to clear codes
Hey, guys. Just got the conductor plate replaced in my '98 e320, as well as the transmission filters and fluids replaced. The check engine light was turned off, but not in the transmission computer, so it came right back a few days later. Everything for which there was a code has been corrected, so I was wondering what the procedure is to clear the engine codes. I know there's a list of stuff the computer has to do, so does anyone have that list handy? Seems like I remember there being some coasting involved...
mahicks3 is offline
post #2 of 11 (permalink) Old 04-20-2010, 04:20 AM
atmsmshr's Avatar
Date registered: Jul 2009
Vehicle: Current - 2013 GLK350, 2007 S550, 2002 S430, 1998 ML320. Deceased - 1974 240D, 1992 400E, 1997 E420
Location: An island off the coast of Florida **Use startekinfo.com for official Mercedes technical guidance**
Quoted: 91 Post(s)
Transmission codes cannot be cleared by a hand held scanner. You will need Carsoft and adapter. It's easiest to just drive to a reputable independent mechanic and ask them to clear the fault. My indy did the tranny clear for $35 after I replaced the conductor plate - and he even gave me a printout of stored codes.
Good Luck
atmsmshr is offline
post #3 of 11 (permalink) Old 04-20-2010, 04:23 AM
Date registered: Feb 2010
Vehicle: MB W210 E220 '01 (Facelift)
You can clear codes through the Climate control unit - Go to position 3 (just before starting the engine, when the instrument cluster is illuminated), then set the left temperature to HI and the right to LO, then press simultaneously REST and EC buttons until the air circulation lamp starts blinking. Push right AUTO button and see if there are any errors (like b1416 on the left). If there aren't any it should display FF(in deutsch - Fahler Frei(No Errors)). You can search through the list by pressing the AUTO buttons. You can ALSO DELETE ERRORS by PRESSING SIMULTANEOUSLY BOTH AUTO buttons.
However, I recommend to buy yourself some sort of multiplexor and software (like Car Soft 7.4 or the official Xentry system, that is used by the MB technicians), because there are some errors that cannot be deleted by Climate Control Unit.
Hope this helps.
This is the List of the DTC codes - DOWNLOAD
HexBox is offline
post #4 of 11 (permalink) Old 04-20-2010, 04:56 AM
Date registered: Mar 2010
Vehicle: 1999 E300 Turbodiesel
Quoted: 2 Post(s)
Hope this helps.
I appreciate the advice also. I have another question. I am new and therefore all I hear is carsoft, carsoft and the associated hardware. Where do you go to download the stuff as I would like to try. Thanks
PS: I enjoy your countries wine.
jhby@qis.net is offline
post #5 of 11 (permalink) Old 04-20-2010, 09:19 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
somebody
has it seriously wrong.You can only clear climate control codes in the climate control diagnostic section.
You won't even pull up a powertrain code (P)
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #6 of 11 (permalink) Old 04-20-2010, 10:02 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hope this helps.
Drivetrain DTC codes are not accessible through the CC system. And most of the transmission codes cannot be reset through the OBD-II port. SDS, Snap-On, carsoft, etc. are the only way to clear them out. I don't recommend that the casual DIY-er invest in any of those since they are complex and far beyond what the typical user needs, and the interfaces are not very user-friendly.
BTW, no need to repost the codes. I'd respectfully suggest you may want to read through all of the DIY threads atop this forum so you can see all the topics covered...including trouble codes.
Check Codes is offline
post #7 of 11 (permalink) Old 04-20-2010, 12:24 PM
redwood's Avatar
Date registered: Dec 2004
Vehicle: 500E, E320, 190E, E55
Quoted: 13 Post(s)
Thank you HEX-BOX for the trouble code listings! very helpful. My friend has a genuine Mercedes MDS STAR computer in his garage that I have access to whenever I need. I'm not fully trained on all the functions but these codes will help. are these for W210 chassis only?
Regards
Redwood
E320 3.2 W211
E55 5.5 W211
500E 5.0 W124
190E 2.3 W201
redwood is offline
post #8 of 11 (permalink) Old 04-20-2010, 12:27 PM
As I said above - there are errors that cannot be deleted by CCU, that's why you need specific software
BTW, CarSoft is very user-friendly, but it doesn't have the capabilities of the Xentry system.
P.S @jhby@qis.net - I'm glad you like it, we have one of the finest production lines in Europe.
HexBox is offline
post #9 of 11 (permalink) Old 04-20-2010, 12:32 PM
Quoted: 35 Post(s)
Well, you're in Bulgaria, so you don't have the various options we do here. A very simple US $40 reader can plug into the OBD-II port of North American cars and read and clear codes...and it's much easier and cheaper than carsoft. But it will not clear some hard set codes, including transmission and airbag. Thus my suggestion that the casual DIY-er not pursue carsoft, because it is overkill for 99% of the stuff they'll ever care about.
post #10 of 11 (permalink) Old 04-21-2010, 12:29 AM
@redwood - I'm pretty sure that some of those codes are ONLY for w210. Probably there are differences between the newer models(like w211/w212), but I'm not sure of it.
HexBox is offline
    Can't clear fault codes rnettleship W210 E-Class 7 02-02-2010 09:17 AM
    Clear Codes - Is it safe ?? robertkhernandez W203 C-Class 2 11-29-2009 10:36 AM
    95 E320 how to clear codes Qamar W124 E,CE,D,TD Class 1 10-17-2006 04:02 PM
    How to Pull and Clear Codes DIY. pcmaher W140 S-Class 1 01-04-2006 07:31 PM
    How to check/clear computer codes? bkv W124 E,CE,D,TD Class 0 12-10-2002 08:50 PM
