Thermostat operation: How long does the engine take to warm up? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-31-2010, 07:07 AM Thread Starter
dykaar's Avatar
Date registered: Mar 2008
Vehicle: 2001 E320 4matic Wagon
01 E320 4matic wagon 55K miles. The engine seems to take FOREVER to heat up. By comparison, The Aluminum/Magnesium V8 in the BMW only takes a couple minutes. Searching yields conflicting opinions about thermostat replacement. On longer trips the temp gauge eventually hits ~80C, and there is heat.
Comments? If in doubt, throw it out (the thermostat, not the car)?
Regards,
doug
Waterloo, Ontario Canada, eh
86 951 (https://reg.pcaucr.org/forum/post.jsp?postid=2393)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...ml#post3790569)
00 540i-6 (http:// BMW Club of Canada, Trillium Chapter |)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
86 951 (http://pcaucr.org/media/image-galler...all&gallery=22)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
76 300D (sold in 92)
83 944 (sold in 86)
dykaar is offline
post #2 of 7 (permalink) Old 03-31-2010, 07:13 AM
jlomon's Avatar
Date registered: Dec 2006
Vehicle: 2013 VW Golf Sportwagen TDI, 2011 Mazda 2, 2000 E320 4Matic Wagon (retired),1994 C280 (retired)
Hi Doug,
I'm just down the road from you in Mississauga, and have basically the same car. I can tell you from experience that the M112 V6 is a cooler running engine than other MB engines, such as the M104 inline 6 I have in my C280. Having said that, it sounds like yours isn't getting hot at all. It should find its way to about 87 degrees, the temperature where the thermostat begins to open. Your climate control should be giving you heat in the interior within 5 to 7 minutes of a cold start - you'll normally start to get warm air when your temp gauge shows ~60 degrees. You should be above 80 a few minutes after that. My guess is that your thermostat is stuck in a partially open state, allowing the coolant to circulate freely through your system, albeit somewhat restricted by the partial closure. A thermostat is a cheap and easy DIY. That's where I'd start.
jlomon is offline
post #3 of 7 (permalink) Old 03-31-2010, 07:22 AM Thread Starter
dykaar's Avatar
Thanks for the reply. That was my initial response, but then I saw that FCP groton doesn't list the part, which tells me its not a common failure. Now I see them on ebay. Is $44 the going rate?
Regards,
doug
83 944 (sold in 86)
dykaar is offline
post #4 of 7 (permalink) Old 03-31-2010, 08:19 AM
jlomon's Avatar
$39.50 here, without having to worry about eBay vendors. I use these guys all the time. Free shipping over $75. You can get your MB coolant from them at $21 a gallon. Don't use non-MB coolant. Find something else you need for $15 and you've got your shipping for free.
2001 Mercedes-Benz E320 4Matic Wagon - Thermostat Kit - BUY 2001 Mercedes-Benz E320 4Matic Wagon - Thermostat Kit
jlomon is offline
post #5 of 7 (permalink) Old 03-31-2010, 08:52 AM Thread Starter
dykaar's Avatar
I went with AutohausAZ. $26.56 for the thermostsat and free shipping over $50 (to my friends in Rochester NY). A few bits and bobs, a couple wiper blades and it adds up. My buds at at FCP Groton wouldn't match the free shipping on a small (<$100) order. Unfortunately, thats usually not a problem...
Regards,
doug
83 944 (sold in 86)
dykaar is offline
post #6 of 7 (permalink) Old 03-31-2010, 09:11 AM
stevejensen's Avatar
Date registered: Dec 2008
Vehicle: 2001 E320 4Matic, Desert Silver, 127K miles, wonderful condition.
I had the same problems you describe last winter --- replaced the thermostat -- it was stuck part way open. Fixed the problem !
stevejensen is offline
post #7 of 7 (permalink) Old 03-31-2010, 09:41 AM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 377 Post(s)
Good chance the thermostat is bad, opening early. This is a pretty common failure mode for thermostats, not just on MB, especially after 100K miles or so. The thermostat on my 97E420 failed like this. Also have had the same failure on other non MB cars between 100K-150K miles. Often times it is gradual, so you don't realize it's going until you notice how long it is really taking to warm up.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
    2003 c240 4matic wagoon takes long time to warm up contact148 W203 C-Class 5 02-12-2010 10:34 AM
    Warm Up Relay WUR operation. doug brewer W123 E,CE,D,CD,TD,TE Class 4 01-02-2010 01:25 PM
    Thermostat for 366 engine Plowguy Unimog 4 02-18-2009 01:01 AM
    How long for replacing thermostat? graftdesign W126 S,SE,SEC,SEL,SD,SDL Class 8 01-26-2007 09:00 PM
    How long do you guys do "warm up" NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 30 12-22-2004 06:42 PM
