OM606 electronic injection pump - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 03-29-2010, 02:13 PM Thread Starter
Date registered: Mar 2009
Vehicle: W210 1998 300TD, S124 1996 300TD (restoration)
Quoted: 16 Post(s)
Post OM606 electronic injection pump
Hi all,
Does anyone know if the newer electronic injection pumps fitted to the later W210/OM606 Diesel Turbos incorporated fuel advance and retard hooked into the ECU?
Earlier W124/OM606 were fitted with purely mechanical injection pumps which were ideal for veg as you could advance the timing to compensate.
This guy uses some pretty long words, no idea what he is talking about
spock505 is offline
post #2 of 18 (permalink) Old 03-29-2010, 05:04 PM
Date registered: Nov 2005
Vehicle: 1996 210.020
The computer for the OM606 only sets the rack position to adjust fuel delivery. The timing is still completely mechanical.
Matt L is offline
post #3 of 18 (permalink) Old 03-30-2010, 06:29 AM Thread Starter
Quoted: 16 Post(s)
Thanks for the reply Matt,
Setting the rack position for fuel delivery, is this quantity or pressure?
I am I correct in thinking the timing is static on all models with the above Bosch inline mechanical pump?
Could you explain in a bit more detail
spock505 is offline
post #4 of 18 (permalink) Old 03-30-2010, 05:20 PM
The rack position controls fuel quantity.
There is a mechanical timing device built into the chain sprocket, so while the timing is not computer-controlled, it is not static.
Matt L is offline
post #5 of 18 (permalink) Old 03-31-2010, 03:56 AM
Date registered: Mar 2010
Vehicle: 1999 E300 Turbodiesel
Quoted: 2 Post(s)
Good morning,
I have a 1999 E300 Turbo with a bad MAF. I do not have a wiring diagram but, after reading your advice can I assume that the ECU does not make adjustments to the mechanical pump. If so is that why I have not experienced any loss of power?? Thanks jhby
jhby@qis.net is offline
post #6 of 18 (permalink) Old 03-31-2010, 05:46 AM
Originally Posted by jhby@qis.net View Post
Good morning,
The ECU is responsible for setting the rack position, and thus the engine output. A bad MAF should put you into limp mode, with a severe power loss.
Matt L is offline
post #7 of 18 (permalink) Old 03-31-2010, 06:18 AM
Olivier A's Avatar
Date registered: Jun 2008
Vehicle: E300TD 1997 W210 Running on WVO and a % of dino...
Agreed with Matt. This is why I wonder if you are driving with full power or if ther MAF is really bad.
Olivier A is offline
post #8 of 18 (permalink) Old 03-31-2010, 08:03 AM
Quoted: 2 Post(s)
All I know is that I get a P0100 fault(OBDII), MAF malfunction. I do not have any loss of power. The other interesting thing is that my work shop manual came and I am hard pressed to find anything in detail about the ECU and MAF!
Advice appreciated
post #9 of 18 (permalink) Old 03-31-2010, 03:14 PM Thread Starter
Quoted: 16 Post(s)
Matt, is the "mechanical timing device built into the chain sprocket" common to all OM606's inc those fitted to the non turbo W124?
or is it a new feature fitted only to the turbo variants?
spock505 is offline
post #10 of 18 (permalink) Old 03-31-2010, 05:26 PM
It is not new at all. M-B IFI pumps have used this for decades. Perhaps from the very start.
Matt L is offline
    96 E300d (OM606) Vacuum Pump misery!! p_aplin W124 E,CE,D,TD Class 6 04-21-2011 07:50 AM
    250se injection pump (and bnz club injection repair manual) JJsAtoZatAz@MSN.COM For Sale/Wanted/Trade/Giveaway 1 02-19-2010 12:01 AM
    om605 / om606 injector pump timing help?? wilsonnw W202 C-Class 7 12-07-2009 02:37 PM
    om606 Fuel Pump SimonBond W210 E-Class 1 09-13-2008 10:35 PM
    JetTronic vs. Electronic Fuel injection? Grubeguy Vintage Mercedes-Benz 2 08-10-2006 10:19 AM
