Power Windows Wont work - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 02-12-2010, 05:22 PM Thread Starter
Date registered: Jan 2010
Post Power Windows Wont work
Does any body have an idea why would all 4 windows stop working? I know they are not on the same fuse , but I checked them and they are good.
Any suggestion?
Thanks
500s is offline
post #2 of 21 (permalink) Old 02-12-2010, 06:52 PM
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 210.065
Battery due?
it could be the CNS BUS (car computer) you may try to disconnect the battery and reconnect and see if it works. but you must have your radio code ready
iluvJESUS
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline
post #3 of 21 (permalink) Old 02-13-2010, 05:32 AM Thread Starter
Post
Originally Posted by iluvjesus View Post
Battery due?
Thanks. I tried it but no luck.
500s is offline
post #4 of 21 (permalink) Old 02-13-2010, 06:37 AM
Cancer_Researcher's Avatar
Date registered: Feb 2008
Vehicle: 03 Corvette Z06;08 GMC Acadia;84 230CE MANUAL Euro;12 Acura TL Tech Pkg; 02 Lexus LS430 Ultra Luxury
Quoted: 69 Post(s)
Did you re-synchronize your windows and sunroof after the battery was disconnected?
Cancer_Researcher is offline
post #5 of 21 (permalink) Old 02-13-2010, 08:36 AM Thread Starter
Post
The windows don't work. I cant re-synchronize them. The problem is that they wont go down at all. Sunroof works.
500s is offline
post #6 of 21 (permalink) Old 02-13-2010, 11:31 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Maybe you should try holding the windows switches in the up position for a few seconds. All the way to the auto position. Then see if they will go down.
Musikmann is offline
post #7 of 21 (permalink) Old 02-13-2010, 02:38 PM
Vehicle: 1999 E430; 2005 ML500
Quoted: 59 Post(s)
The most likely culprit for all 4 windows is the center switch unit in the center console. Do your mirrors and seat adjustments work?
Hirnbeiss is offline
post #8 of 21 (permalink) Old 10-31-2010, 10:58 AM
jc-place's Avatar
Date registered: Feb 2009
Vehicle: Have 2000 CLK320 soft top,W210s replaced with rare'11 Turbo 9-5NG (only 500 imported) , '07 9-7x.
Quoted: 2 Post(s)
500s- Did you ever get your benz power windows to work? Did you end up replacing center console switches? I have the same issue where none of my power window switches work even on back doors but sunroof works perfect.
Owner of rare '11 Turbo 9-5NG, '07 Carbon Black 9-7x & 2000 red CLK soft top. Down to one Benz left.
jc-place is offline
post #9 of 21 (permalink) Old 10-31-2010, 01:21 PM
Date registered: Jan 2004
Quoted: 32 Post(s)
Do they not move at all or is it just the auto up and down that doesn't work?
Len
'59 220S Cabriolet - for sale - http://www.bruceadams190sl.com/1959-...20s-cabriolet/
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 207,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 10,500 miles
sokoloff is offline
post #10 of 21 (permalink) Old 10-31-2010, 07:39 PM
jc-place's Avatar
Quoted: 2 Post(s)
None of the windows in the car will go up or down using any switch in any mode. Even the switches on the back doors dont work. The switches are just dead and all fuses are good. I was wanting to find out if suggestion above fixed member 500s problem since I have the exact same issue. I don't want to throw money away on a center console switch if that will not fix the problem.
Thanks.
jc-place is offline
    Power window wont work. 2000 C280 Sport W126 S,SE,SEC,SEL,SD,SDL Class 3 11-03-2009 06:05 PM
    Power Windows Don't Work Sometimes foom W124 E,CE,D,TD Class 5 11-18-2008 03:26 PM
    My trunk release and left power seat wont work! Please Help irantp4life C208/A208 CLK-Class 0 11-22-2007 06:16 PM
    windows down,wont work 86 560sl bosshoss96 R/C107 SL/SLC Class 3 09-19-2007 04:25 AM
    2000 ML 320 driver and passenger windows wont work usmanfar82 W163 M-Class 3 08-28-2007 05:01 AM
