Reprogramming the E320 computer for check engine light illuminating - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 01-14-2010, 03:48 PM Thread Starter
ziggie's Avatar
Date registered: Nov 2008
Hay,
My 2002 E320 Station Wagon has illuminated check engine light.
I changed all 4 Oxygen Sensors, two Catalytic Converters, and then reset the check engine light with diagnostic tool. But , the check engine light gets illuminated just after 25 miles of driving. I was the codes of 403 and 402 which says the Catalytic Converters below threshold.
I was reading that before and I still read that after installing to new Cats.
What seems to be the problem I can not figure it out. And it is not the Gas Cap either.
Do I need to reprogram the engine computer to fix this problem? Please help
ziggie is offline
post #2 of 11 (permalink) Old 01-14-2010, 04:21 PM
Big"D"inTheMB's Avatar
Date registered: Jun 2007
Vehicle: 2005 C240-Retired
What codes are you getting before you clear them?
That would be a huge help in getting your question answered.
Mercedes Benz, enough said.
Big"D"inTheMB is offline
post #3 of 11 (permalink) Old 01-14-2010, 04:27 PM Thread Starter
ziggie's Avatar
ng the e320 computer for check engine light illuminating
the codes are 403 and 402 which says the Catalytic Converters below threshold.
ziggie is offline
post #4 of 11 (permalink) Old 01-14-2010, 04:33 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Maybe if you disconnect the battery, wait a few minutes, then reconnect. That will reset the ECU.
Musikmann is offline
post #5 of 11 (permalink) Old 01-14-2010, 04:36 PM Thread Starter
ziggie's Avatar
I actually replaced the battery for this car about two months ago so I don't think that would be the solution.
ziggie is offline
post #6 of 11 (permalink) Old 01-14-2010, 04:43 PM
Musikmann's Avatar
Quoted: 6 Post(s)
It might not be but did you replace the battery before or after you replaced the cats? You asked about reprogramming the "engine computer" and I told you how to reset/reboot the engine control unit. Or are we talking about 2 different things?
Another possibility: Are you sure the new cats are compatible with your car and are installed properly?
post #7 of 11 (permalink) Old 01-14-2010, 04:49 PM Thread Starter
ziggie's Avatar
Yes the new cats are M/B and installed okay
ziggie is offline
post #8 of 11 (permalink) Old 01-16-2010, 06:10 AM
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 210.065
Any symptoms when driving it? Are the O2 sensors genuine too? Don't worry ziggie, it usually reprograms itself. Drive for a few more days and the CEL may disappear.
iluvJESUS
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline
post #9 of 11 (permalink) Old 01-16-2010, 06:38 AM
Date registered: Dec 2009
Vehicle: w210 E320 2001, BMW E34 1991, w124 E300
this happened to me, i have reset the CEL 3 days ago, it gets illuminated again after 2 km.
today when i turn the engine, the light was off.
So as iluvjesus said,maybe it reprograms itself.
samijusuf is offline
post #10 of 11 (permalink) Old 01-16-2010, 02:02 PM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(203K Miles), 2002 E320 Special Edition(174K Miles)
This is an interesting one. The cats doesn't have any sensors and analysis of the cat operation depends on readings from the two o2 sensors before and after the first cat. Since you had installed MB cats, I think we can assume that they are operating correctly.
Now what may have happened if you had driven for a long time with bad cats and/or O2 sensors, is that the adaptive values for fuel trim, etc., may have tried to compensate for the bad parts and totally screwed up the mixture. Now that you have working parts in, the mixture may be totally wrong! If that is the case, some more driving cycles may bring the values into the correct range. Or you can also have all adaptations reset to the default values using STAR or Carsoft.
Of course you may also have a MAF going bad screwing up the fuel mixture, but that should normally throw codes as well. Are you sure you have the correct MAF fitted for the car?
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
    Check engine light e320 cc238 W210 E-Class 16 06-26-2009 06:47 AM
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 03:37 PM
    94 E320 Check Engine Light Jolinie General Mercedes-Benz 2 01-19-2006 04:09 PM
    E320 "CHECK ENGINE" light klym22 General Mercedes-Benz 2 10-28-2004 04:44 PM
    '95 E320 Check Engine Light Guest (MBNZ) W124 E,CE,D,TD Class 5 01-15-2002 11:56 AM
