what OBD II reader to buy CLK 430? - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 01-05-2010, 03:06 PM Thread Starter
500SEC_AMG's Avatar
Date registered: Feb 2009
Vehicle: 500 SEC AMG Mod'd
Quoted: 5 Post(s)
Send a message via AIM to 500SEC_AMG
Guys I would like a good OBD II reader for the CLK, what reader should I get and is there any Mercedes specific unit that shows what the codes are? Can any codes or errors be reset from these readers?
500 SEC Euro Classic White repaired!!
1987 Japanese 500 SEL Tri Ys and Velour
2000 CLK 430
Photojournalist
Collector of Vinyl
www.jakewright.ca
500SEC_AMG is offline
post #2 of 16 (permalink) Old 01-05-2010, 09:22 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Any Obd2 scanner like the 50-70
buck ones at Harbor Freight Tools - Quality Tools at the Lowest Prices or at a store or online for you up there.
It will show all codes and clear them
Online has lists of obd codes and what they indicate but not meaning the solution if you don't know what they point to as a solution.That is what the forum can help with.
Mercedes-Benz Forum w210 section also has links to obd2 codes.
For a bout 100 us you can get scanner that show live data for o2 sensors but that is probably more than you need
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #3 of 16 (permalink) Old 01-05-2010, 09:32 PM Thread Starter
500SEC_AMG's Avatar
Quoted: 5 Post(s)
You guys rock. The MB dealer said theirs cost $800
2000 CLK 430
Photojournalist
Collector of Vinyl
www.jakewright.ca
post #4 of 16 (permalink) Old 01-05-2010, 09:35 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
So who sent you over from the 208 forum to ask us?
Amazon has a nice little basic unit for $40 that comes with the code disk. OBD-II is generic, but MB does have some specific codes. Only way to really get those and the chassis transmission ones is with SDS, Snap-On or Carsoft/laptop.
If you want stored analytical real-time data for advanced diagnostics, Equus makes some great units in the $140 range and up.
If all you want is to read basic codes and erase them, the $40 at Amazon is ideal. Small enough to leave under the seat so if you snag a CEL you can check it without digging out a bunch of stuff (and spending a half hour with the equus manual). Plug in, two buttons, simple as it gets.
Check Codes is offline
post #5 of 16 (permalink) Old 01-05-2010, 09:41 PM Thread Starter
500SEC_AMG's Avatar
Quoted: 5 Post(s)
Here is the deal, I own 2 w126 and 1 w208. The guys on the W126 forum know their stuff. There are few issues we can't solve. As for W208... god bless them but, errr not the same caliber. So I figured there would be plenty of E class guys who were serious drivers who could help. I have a pretty steep learning curve and crave to know everything about the cars I own.
2000 CLK 430
Photojournalist
Collector of Vinyl
www.jakewright.ca
post #6 of 16 (permalink) Old 01-05-2010, 09:50 PM
Quoted: 35 Post(s)
^^^Dood, I was just funnin' with you. I go over to the 208 sometimes to help out with some of the tech questions; lots of guys who know mods and phones and audio, though. The 210 folks seem to have a great mix of it all. FWIW I have all three of the things I mentioned in my post.
post #7 of 16 (permalink) Old 01-05-2010, 10:10 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
Most readers can clear the code but if it is real, the code will come back. The smog tester can detect if a code was cleared.
mbvis is offline
post #8 of 16 (permalink) Old 01-05-2010, 10:10 PM Thread Starter
500SEC_AMG's Avatar
Quoted: 5 Post(s)
I know your just busting my chops, I will check out those links you posted. I will be getting the car diagnosed tomorrow at 8am. I am only getting limited throttle and it won't kick down. After I rest the ECU I have a month until it happens again
2000 CLK 430
Photojournalist
Collector of Vinyl
www.jakewright.ca
post #9 of 16 (permalink) Old 01-05-2010, 10:17 PM Thread Starter
500SEC_AMG's Avatar
Quoted: 5 Post(s)
If the cats are gone I am not paying for $1000 cats, I will get after market ones or cut them out, will the 430 run without cats?
2000 CLK 430
Photojournalist
Collector of Vinyl
www.jakewright.ca
post #10 of 16 (permalink) Old 01-05-2010, 11:29 PM
Quoted: 35 Post(s)
You don't need to, there are aftermarket ones that are quite affordable, assuming Canada's laws are not so draconian as California. You can pull the rear ones but if you do the fronts you'll live with CELs forever, even if you don't mind irritating Al Gore.
    What OBD-II reader to use? utopiazz V-Class 55 04-03-2016 02:02 AM
    obd II reader zenedge V-Class 0 12-16-2008 11:34 AM
    OBD reader problem.... dhcrowder W210 E-Class 5 08-17-2007 11:45 AM
    which obd-2 reader? numitor R170 SLK-Class 5 01-02-2007 10:45 AM
    Shopping for a OBD II reader Tectite.Metal W203 C32 AMG, C55 AMG 2 07-19-2006 01:21 AM
