Front bumper cover removal - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 01-02-2010, 03:10 PM Thread Starter
Date registered: Dec 2009
Vehicle: 2000 MBenz E320, Turbo Lexus IS300
2000 E320 Front bumper cover removal
My dad has a 00 e320. Someone did a hit and run on him in the parking lot and his bumper got messed up. I ordered a new one and had it painted. I am not sure how to take his bumper off. I did some searching and there was a picture tutorial but it really dosent help all that much. I just want to get the bumper cover off not the actual metal bumper.
Does anyone have a tech guide or know step by step how to remove the front bumper cover?? This would help with anyone else who runs into the same issue as well. Or even somewhere where i could pay for the tech guide?? Thanks to whoever helps and give rep to anyone who helps =)
Trying to work on it tomorrow morning so need help fast!
JonnyD85 is offline
post #2 of 14 (permalink) Old 01-02-2010, 03:49 PM
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
by bumper cover you mean the impact strip? like this one in the picture Mercedes Benz E320 Replacement Bumper Trim - 2000-2002 Mercedes Benz E320 - Replacement M016101 ? i have replaced the rear bumper impact strip and that one just clips off, so i would imagine the front ones just clip off also, actually easier since there are 2 small impact strips for front bumper. a spatula might come in handy.
tirona is offline
post #3 of 14 (permalink) Old 01-02-2010, 04:21 PM Thread Starter
by bumper cover i mean the front bumper...the actual "bumper" is the metal behind the bumper...so the actual front bumper on the car needs to be removed. I have removed most bolts but seems like there are a few more.
So really just removing the front bumper...
JonnyD85 is offline
post #4 of 14 (permalink) Old 01-02-2010, 04:34 PM
tirona is offline
post #5 of 14 (permalink) Old 01-02-2010, 05:14 PM Thread Starter
yes, that is what i was using, but that really dosent help too much..its all pictures with no words. Like i have the lexus IS300 tech manual..which tells u the process from every little nut to every bolt, torque specs on all EVERYTHING. I was hoping to find something on here with word by word step process and locations on all the bolts. A couple of those pictures I am not sure where the location is... thats why i was looking for pictures with words and step processes. Wish there was a write up on it
JonnyD85 is offline
post #6 of 14 (permalink) Old 01-02-2010, 07:13 PM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(203K Miles), 2002 E320 Special Edition(174K Miles)
[QUOTE=JonnyD85;3906176 Like i have the lexus IS300 tech manual..which tells u the process from every little nut to every bolt, torque specs on all EVERYTHING. ([/QUOTE]
Ha, but that is because Lexus is meant for less intelligent drivers.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #7 of 14 (permalink) Old 01-03-2010, 08:51 AM
atmsmshr's Avatar
Date registered: Jul 2009
Vehicle: Current - 2013 GLK350, 2007 S550, 2002 S430, 1998 ML320. Deceased - 1974 240D, 1992 400E, 1997 E420
Location: An island off the coast of Florida **Use startekinfo.com for official Mercedes technical guidance**
Quoted: 91 Post(s)
Front Bumper replacement DIY
JohnnyD,
I replaced a front bumper on a 1997 E420 two months ago. Its straightforward, but you will need patience. Here are the steps used in this 4 hour job (if memory serves):
Tools
Jack + jackstands
wood chocks for rear tires
8mm socket and ratchet
10mm socket and ratchet
13mm socket
13mm box wrench
pliers
hammer
troublelight
Canvas or blanket
1) Disconnect battery.
2) Safety jack car, and place on jackstands.
3) Remove under engine cowling. 8mm
4) Remove under bumper cowling.
5) Remove side marker yellow lights (plastic finger clip is on inside, push the light outward)
6) Remove sidemarker bulb when light assembly is free of bumper
There are 4 bolts/nuts holding the front bumper in place. 13mm Two nuts are below the auxilary fan, and two bolts are at the ends of the bumper next to the sidemarkers.
7) Remove the bolts next to the sidemarkers.
8) Lift up the plastic screen in front of the aux fan (it pulls straigt up).The front bumper nuts are located at the lower left and right sides, barely visible below the aux fans. The only way I could access was by using a 5/8 inch box end wrench with a built in ratchet. (Huskey, Gearwrench and Craftsman all carry these type wrenches.) Remove nuts. The bumper will stay on because the bolts are threaded into the bumper.
9) Position 4x4 blocks directly below bumper.
10) With helper, pull bumper forward, and lay it down on blocks. Avoid having the bumper is now hang by foglight wiring.
13) Pull out the styrofoam padding behind the bumper to access foglight mounting hardware.
12) Remove foglight A-frames, each held in place with 10mm bolt and plastic snaps. (I broke the snaps, and just replaced with threadlocked machine screws during reassembly).
12) Remove whatever pieces from the bumper you plan on keeping to keep from scratching while you reassemble.
13) Lay the new bumper on blanket and put new pieces in place. (Bumper, valence, trim). The hardest part of this job is taking off the chrome and reinstalling. The spring clips need to be hammered out, and hammered back in. Best way to reinstall is to firmly compress clips with pliers beforehand.
14) Reassemble in the reverse steps. I don't have torque values, but in this non-critical application, just torque securely EXCEPT for the side bumper bolts.
15) You may need to line up the side bumper trim with the fender wheelwell. A helper makes this easier to pull/push the bumper while you secure the side bolts.
Let us know how it goes for you.
atmsmshr is offline
post #8 of 14 (permalink) Old 01-05-2010, 11:36 AM Thread Starter
that should definately be in the sticky... is the E420 have the same setup as the E320 as far as bumper removal goes?? I am not really sure if the setup is identical?
JonnyD85 is offline
post #9 of 14 (permalink) Old 01-05-2010, 11:38 AM Thread Starter
lol...well it is more of a supra IS 300 =) I did a motor swap and put a supra motor in there =)
JonnyD85 is offline
post #10 of 14 (permalink) Old 01-05-2010, 02:41 PM
Vehicle: '03 C320 4Matic Wagon
What vintage supra motor? And... why?
'03 C320 4matic Wagon
tmandel is offline
    rear bumper cover removal sproduct R129 SL-Class 1 10-25-2009 07:09 PM
    Front Bumper Cover Removal w251 waylifeshouldbe W251 R-Class 0 04-16-2009 03:32 PM
    Front Bumper Cover Removal amgmezo W163 M-Class 11 04-11-2008 02:45 PM
    Headlight removal,(bumper cover removal?) racingdave W203 C-Class 5 01-13-2005 11:05 AM
    Need help with front bumper cover removal - SLK320 Dan Latta R170 SLK-Class 1 06-06-2002 02:31 PM
