Oil Level Sensor leaking oil - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 11-05-2009, 08:00 PM Thread Starter
Date registered: Apr 2006
Vehicle: 2000 E320
Smile Oil Level Sensor leaking oil
my 2000 E320 has a small oil leak that seems to be comming from the oil level sensor. Any advice on how to replace the sensor would be appreciated.
jlbarnes is offline
post #2 of 22 (permalink) Old 11-05-2009, 08:19 PM
Kajtek1's Avatar
Quoted: 1198 Post(s)
Check the stickies. Requires oil pan drop on gasser.
Kajtek1 is offline
post #3 of 22 (permalink) Old 11-05-2009, 08:21 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
IIRC it is very straight-forward. Remove engine part of belly pan, drain oil, drop lower oil pan, replace sensor, clean pan, reinstall. Renew the gasket if dried out (I probably would anyway). I can get you the torque spec tomorrow if someone doesn't get it to you first.
Check Codes is offline
post #4 of 22 (permalink) Old 11-05-2009, 11:18 PM
daisound's Avatar
Date registered: May 2008
Vehicle: W210.265/2001, W220/S500/2000, Porsche 997 C2S/2006, GMC K1500/1992
If you do not need extra qt of oil before oil change, any repair is not necessary.
500SEC 1984 retired at 192K
Porsche 928S GT 1984 (euro) retired at 243K
daisound is offline
post #5 of 22 (permalink) Old 11-06-2009, 05:36 AM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 12 Post(s)
AFAIK, both the top and bottom pans use sealant (Loctite). They do not use gaskets.
Maybe they do not want to spend the time to clean the pans so they like to sell you new ones. Just a possibility.
loubapache is offline
post #6 of 22 (permalink) Old 11-06-2009, 08:22 AM
Quoted: 35 Post(s)
Thanks Lou. I couldn't remember if there were specific gaskets or the home-grown kind.
post #7 of 22 (permalink) Old 11-06-2009, 08:31 AM
Date registered: Sep 2004
Vehicle: 98 E-320, 2003 E-500
Hi Gregs210,
I tried to PM but couldn't, so have to hijack the thread a little bit, at least it's still about sensor.
I remember you mentioned about universal oxygen sensor and you were able to get all four for $180???
Would you please send me the link?
Thanks,
JeffreyP
JeffreyP is offline
post #8 of 22 (permalink) Old 06-14-2010, 05:56 PM
Date registered: Mar 2010
Vehicle: 1999 E300 Turbodiesel
Quoted: 2 Post(s)
1999 E300TD Oil Level Sensor Leak
Does this procedure also apply to a diesel. I am about to change the oil and I believe the sensor is leaking. Your advice regarding gasket replacement and torque spec will also be be appreciated. Thank you
jhby@qis.net is offline
post #9 of 22 (permalink) Old 06-14-2010, 06:37 PM
Kajtek1's Avatar
Diesel sensor comes right out with no need for pan drop.
There are 2 orings. The smaller one for electric connector comes in the oil filter kit.
Kajtek1 is offline
post #10 of 22 (permalink) Old 06-14-2010, 06:47 PM
Quoted: 2 Post(s)
Please clarify, what do you mean by just comes out-----I did not see and nuts bolts or screws! Please note I have a 606.692 diesel engine
Additionally, a drawing I saw back only showed a gasket. When did they start including an oil level sensor o ring with the oil filter???
My filter came with two o rings,but they are for at the end of filter housing.
    Oil level sensor plug connector leaking oil? louisodwyer R129 SL-Class 20 05-20-2011 03:45 PM
    Oil Level Sender Unit is leaking Nautor_Swan W220 S-Class 1 11-26-2008 03:09 PM
    oil leaking from oil level sensor wstasw C208/A208 CLK-Class 6 03-19-2007 09:16 PM
    oil leak from oil level sensor tangotango W220 S-Class 1 05-14-2006 12:38 PM
    how to replace oil level sensor-leaking tangotango W202 C-Class 0 05-13-2006 11:10 PM
