Upper Oil Pan Leak - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-05-2009, 05:41 AM Thread Starter
Date registered: Aug 2009
Vehicle: 1998 E320
Upper Oil Pan Leak
I have a leak around one of the torx bolts on the upper oil pan. Does anyone have an idea of how long it should take to replace the gasket?
uttom is offline
post #2 of 5 (permalink) Old 11-05-2009, 11:30 AM
Vehicle: 1999 E430; 2005 ML500
Quoted: 59 Post(s)
Upper oil pan gasket standard time 9.8 hours (in chassis), 2.7 for the lower.
Hirnbeiss is offline
post #3 of 5 (permalink) Old 11-05-2009, 11:37 AM Thread Starter
Vehicle: 1998 E320
dealer said that one HAD to replace the pans. They can not simply be resealed, but must be replaced. Single use only. Is this true?
uttom is offline
post #4 of 5 (permalink) Old 11-05-2009, 06:35 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
First I've heard of that. WIS for replacing oil level sensor only calls for fitting a gasket on the lower pan and replacing, so we know he's fibbing at least there.
I'd use an indie anyway if not DIY-ing.
Check Codes is offline
post #5 of 5 (permalink) Old 11-05-2009, 07:15 PM
Date registered: Apr 2009
Vehicle: 96 E-320, 91 190E, various and sundry Euro and American vehicles
Quoted: 2 Post(s)
It would be interesting to hear the dealer pricing on this for a laugh.
Get a good side mechanic, or you and a mechanical friend. The gaskets are dirt cheap.
Also verify closely it is indeed a pan gasket leak, and not something above it. I used brake cleaner and got the area cleaned and dried out, only to find when I isolated the leak it was a head gasket leak, much to my disappointment. Still haven't repaired it yet (soon now).
aard
aardvark is offline
    DIY Gasket (Lower part of oil pan to upper part) (Sharing Pictures) MBs600v121998 W140 S-Class 15 10-19-2012 07:36 PM
    Removing Upper Oil Pan fastmayte W211 E-Class 3 06-28-2008 08:54 PM
    crossfire oil pan = e320 oil pan? (upper pan removal?) fastmayte W210 E-Class 4 06-28-2008 05:06 PM
    Oil Pan Gasket Leak rghoch W201 190-Class 10 03-25-2008 01:22 PM
    MAIN (upper) oil pan replacement, how does it come out ??? vikmomjian W123 E,CE,D,CD,TD,TE Class 2 01-07-2006 04:05 PM
