what is towing capacity? - Mercedes-Benz Forum
post #1 of 58 (permalink) Old 10-28-2009, 06:05 AM Thread Starter
Date registered: May 2005
Vehicle: 1983 300 SD; 2000 E320
of E320.
wagon/vs sedan difference?
couldn't find answer on search function.
Thanks
'83 SD burns no oil @ 221,000 (crashed, RIP)
2000 E320 Wagon 4matic 119,000
andrew_falky is offline
post #2 of 58 (permalink) Old 10-28-2009, 09:21 AM
Kajtek1's Avatar
Quoted: 1289 Post(s)
This is tricky question.
No passenger car in US is rated more than 1500 lb towing.
That become political issue, since to my knowledge MB wagons in Europe have 5000 lb tow ratings.
Best way to find "politically correct" answer is to call MBUSA.
Kajtek1 is offline
post #3 of 58 (permalink) Old 10-28-2009, 09:25 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Ditto. Use 800-FOR-MERC.
Musikmann is offline
post #4 of 58 (permalink) Old 10-28-2009, 09:40 AM
Date registered: Jun 2008
Vehicle: 2000 w203 c200k (Yes, it's a w203 from Germany)
Hah, I see E-classes towing huge trailers here all the time. I think the class they are in is 3000+, at the least.
jerk_chicken is offline
post #5 of 58 (permalink) Old 10-28-2009, 09:54 AM
KarlBenzSF's Avatar
Date registered: Jan 2009
Vehicle: 2000 E320 4MATIC
Quoted: 2 Post(s)
????????? E class can tow a tailer up to 3000kgs?
KarlBenzSF is offline
post #6 of 58 (permalink) Old 10-28-2009, 11:49 AM
Kajtek1's Avatar
This is the hitch for a wagon with 2200 kg ratings, what is about 4500 lb.
Even if you pay the big bucks to get it to US, it is not having US attests
Mercedes E-Klasse W210 Anhängerkupplung abnehmbar+ 7pol bei eBay.de: Anhängerkupplungen E-Sätze (endet 29.10.09 19:30:00 MEZ)
Kajtek1 is offline
post #7 of 58 (permalink) Old 10-28-2009, 12:17 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 7 Post(s)
Even the smallest
v6 2.4 w210 is rated at 1900Kg in other countries so call the dealer.
We towed over 2k no problems when we used the wagon as a tow vehicle.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #8 of 58 (permalink) Old 10-28-2009, 06:15 PM Thread Starter
general questions:
1. I thought trailer and load could never exceed weight of vehicle
2. what about tongue weight. I would think the rear end would sag
like an old woman with more than 300 lbs.
post #9 of 58 (permalink) Old 10-28-2009, 06:50 PM
ohlord's Avatar
Quoted: 7 Post(s)
ford f150
gross weight 7000lbs.
max towing capacity 9500lbs
and tongue wt is the balanced weight above the ball.Wagons self leveling suspension helps out in the w210
So you see by rating and torque of engine you can pull more than you weigh.
Get a secondary trans cooler if doing a lot of towing.
a Mercedes Benz"
ohlord
ohlord is offline
post #10 of 58 (permalink) Old 10-28-2009, 07:00 PM
Kajtek1's Avatar
ML350 weighs 2 tons, while in Europe they are rated for 3.5 tons towing.
Semi truck weight just few tons, while is pulling 40 tons trailers and in extreme applications several hundreds tons.
There is much more in towing than the "body weight"
US pickups generally make lousy towing vehicles due to long rear overhangs and soft suspension.
Lot of accidents with them involve "fishtailing" when the trailer is pushing the pickup sideways and the driver is not able to correct the movement.
The only good way you can use their towing capacity is 5-th wheel of goose-neck trailer
Kajtek1 is offline
Towing Capacity Willber14 W126 S,SE,SEC,SEL,SD,SDL Class 1 09-22-2007 10:57 PM
towing capacity unimig Unimog 9 08-26-2007 07:03 AM
G 500 towing capacity? Tom Sawyer G-Class 8 08-12-2003 12:04 PM
Towing capacity US vs German 4benzes W163 M-Class 3 12-22-2002 10:15 AM
'86 300E Towing Capacity? Guest (MBNZ) W124 E,CE,D,TD Class 1 10-03-2002 07:03 PM
