Got the warning message "Oil sensor defective" on 98 E320 - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-02-2009, 01:35 PM Thread Starter
Date registered: Jul 2008
Vehicle: 98 E320
Hi all.
Just got the warning message "Oil sensor defective" on my 98 E320. Is this a DIY task?
Does any one have procedures and pictures how to do this?
Any information is appreciated.
Thanks.
Steve
steveltx is offline
post #2 of 10 (permalink) Old 10-02-2009, 02:19 PM
Kajtek1's Avatar
Quoted: 1291 Post(s)
Start with the stickies. There have been some discussion on it already.
From what I remember gassers require dropping the oil pan for sensor replacement, on my diesel it was 2 minutes job... after I drained oil.
Kajtek1 is offline
post #3 of 10 (permalink) Old 10-03-2009, 08:02 AM
RichardM98's Avatar
Date registered: Oct 2007
Vehicle: 1998 E320 Wagon
Quoted: 26 Post(s)
If you've had any other unexplained 'errors' such as BAS or had loss of sync in windows and sunroof, you might consider testing your battery. I had a couple of "Oil sensor defective" errors prior to replacing my battery. None after.
The oil sensor is inside the lower oil pan on the front of the engine.
RichardM98 is offline
post #4 of 10 (permalink) Old 11-10-2009, 01:06 AM
Date registered: Nov 2009
When I got this message on my 01 E220 CDI I realized I had to change my oil...
NorBeta is offline
post #5 of 10 (permalink) Old 11-10-2009, 05:41 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 7 Post(s)
You mean
that you neeed a defective sensor message to remind you to change you oil?
I pity the life expectancy of that poor engine.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #6 of 10 (permalink) Old 11-10-2009, 08:21 AM
Kajtek1's Avatar
With 40,000 km oil change intervals on those engines it is easy to loose track of time....
The oil level sensor on those cars seems to be weaker point. Who knows how electrical part works? Would disconnecting the wire get rid of the error message? Or maybe bridging the wires?
My friend drives with it for years and although I am not willing to fix the sensor for him, he would be happy to get rid of the annoying message each time he starts the car.
Kajtek1 is offline
post #7 of 10 (permalink) Old 11-10-2014, 11:02 PM
Date registered: Nov 2014
Tranny won't upshift in "D"
Just purchased a 98 E320 and the transmission does not want to upshift when I put the selector in D. Is this an electrical issue? If so, what?
paulson2 is offline
post #8 of 10 (permalink) Old 11-10-2014, 11:14 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Interesting hijack.
Have you checked codes? That's where I'd start.
Good luck.
Check Codes is offline
post #9 of 10 (permalink) Old 11-10-2014, 11:22 PM
No codes.
paulson2 is offline
post #10 of 10 (permalink) Old 11-10-2014, 11:37 PM
Vehicle: 1998 e320 wagon
Quoted: 7 Post(s)
Originally Posted by Check Codes View Post
Interesting hijack.
Good luck.
Seems to have worked
Usedluxury is offline
"Lamp Defective" message on my display AdamY W210 E50 AMG, E55 AMG 14 04-11-2007 12:58 AM
Warning Message "Trailer Light" tkeskic W164 M-Class 5 01-25-2007 07:07 PM
E320 "Display Defective" and car won't shift into 2nd gear andeveron W210 E-Class 2 10-13-2006 04:08 AM
"Display Defective" message on 03 E320 ogkarma W211 E-Class 3 07-06-2006 08:08 PM
98 E320 "Oil Level Sensor Defective" warning only once a while Sky_Line W210 E-Class 6 06-03-2006 05:31 AM
