Wheezing sound - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-16-2009, 08:18 PM Thread Starter
Date registered: Oct 2007
Wheezing sound
Hi all,
I recently did my regular do-it-yourself service on my 1997 E320 which included new air filter and a throttle body clean. Well, after an 800 mile round trip, I begin hearing a wheezing sound from the engine when accelerating. I do not think that this is "normal" so it got my attention. Has anyone ever had this to deal with? Is this something to worry about? What do you folks think?
NIGHTCAP is offline
post #2 of 10 (permalink) Old 08-16-2009, 08:57 PM
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 210.065
Mileage of your car?
Do you have the wheezing when you just rev the engine (i.e. car stationary)? If you do, check V-belt first and belt tensioner.
iluvJESUS
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline
post #3 of 10 (permalink) Old 08-16-2009, 09:08 PM Thread Starter
Wheezing
Milage is 220,000+ and wheezing sound noticed when car is in motion primarily when accelerating.
NIGHTCAP is offline
post #4 of 10 (permalink) Old 08-16-2009, 09:08 PM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 12 Post(s)
In addition to what IJL suggested, also make sure the duct to the throttle body is completely seated and the airbox fully closed as well.
loubapache is offline
post #5 of 10 (permalink) Old 08-16-2009, 09:10 PM
benzotech2003's Avatar
Date registered: Jun 2009
Vehicle: 1996 C280
NIghtcap,
Check your power steering fluid, while the car is running there should be little or no turbulence in the reservoir. another thing I can think of is maybe after your throttle cleaning service maybe a vacuum line fell off, but if it was a big enough one it would run rough. Hope this helps.
1996 C280
1997 S500
1994 S320 (Crashed and sitting, cant let her go)
benzotech2003 is offline
post #6 of 10 (permalink) Old 08-16-2009, 09:15 PM Thread Starter
Wheezing
Thanks guys, I will try your suggestions in the morning.
NIGHTCAP is offline
post #7 of 10 (permalink) Old 08-17-2009, 07:55 PM Thread Starter
Wheezing
I checked out everything as you guys suggested. I discovered that the wheezing (whistling) soung is coming from the throttle itself. There are no leaks that I have observed. I reved it up a few times and sure enough it is there. My indy did change the drive belt for me so I will take it to him to see if that has anything to do with it. Btw at idle I hear a rattle coming from the water pump area which leads me to believe that the belt might have something to do with it.
NIGHTCAP is offline
post #8 of 10 (permalink) Old 08-17-2009, 09:06 PM
iluvjesus's Avatar
Vehicle: 210.065
Then you need to check the water pump, bear in mind that problem with the belt tensioner could cause that too. So I would check that also. You may ask your mechanic to clean your throttle body for you or you DIY with a carb cleaner.
iluvJESUS
post #9 of 10 (permalink) Old 08-18-2009, 06:25 PM Thread Starter
Thanks, I will my indy check out everything.
NIGHTCAP is offline
post #10 of 10 (permalink) Old 08-23-2009, 08:19 PM Thread Starter
Checked everything out and all seems OK except for that whistling sound. My indy mechanic seems to believe that it is because it is breathing better. Still confused.
NIGHTCAP is offline
    Popping sound subwoofer in HK sound syste, Hsheikh W211 E-Class 5 04-30-2010 11:52 AM
    No Sound on radio, No Sound on TV, No CDC changer and NO PHONE! st_tropez72 Audio & Telematics Forum 4 09-01-2008 09:59 PM
    Funny 'wheezing' engine noise - 300 TD stevebower W210 E-Class 5 11-19-2007 03:53 AM
    Sound system ... working on better sound viper1619 W203 C-Class 3 05-16-2004 07:07 AM
    High pitch sound sensor sound ~ E320 wagon luvmywagon W124 E,CE,D,TD Class 1 10-04-2003 10:40 AM
