» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 08-12-2009, 11:40 PM   #11 (permalink)
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 2000 E320AV RWD
After discussion with Prof Lou, we would like to sticky this separately temporarily, after modification and organization, we will put this under the transmission section of the sticky. This very post would be deleted too.
iluvJESUS
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline   Reply With Quote
Old 08-13-2009, 06:10 AM   #12 (permalink)
Musikmann's Avatar
I'd just like to say that this is an excellent idea. Please delete my comment when you decide on the final format.
Old 08-13-2009, 08:39 AM   #13 (permalink)
Date registered: Sep 2004
Vehicle: 98 E-320
Maybe if we keep it separate as a FAQ so it'd be more apparent?
My .02.
JeffreyP
JeffreyP is offline   Reply With Quote
Old 09-09-2009, 09:03 PM   #14 (permalink)
Date registered: May 2008
Vehicle: W210.265/2001, W220/S500/2000, Porsche 997 C2S/2006, GMC K1500/1992
Today, I check the transmission fluid in my S500. Start engine, after over night, shift from P-R-D-R-P, go out stuck the dip stick, engine running, outside temp. 90F, assume fluid is little higher than 25C, but dip stick measured 53 mm. Take car out drive 30 miles, come back, set to park, with engine idling, push dip stick in, fluid level over the max mark by 20 mm. Use laser thermometer check fluid pan temp. 81.5C. What will happen to the transmission if I have been running the car for 3600 miles with over filling fluid ? My transmission fluid was replaced by dealer one year ago. Please advise.
500SEC 1984 retired at 192K
Porsche 928S GT 1984 (euro) retired at 243K
daisound is offline   Reply With Quote
Old 09-09-2009, 09:14 PM   #15 (permalink)
loubapache's Avatar
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Your transmission is overfilled by about 20 mm at both 25 deg C and 0 deg C. If you are concerned, then you can suck a little out of the dipstick.
loubapache is offline   Reply With Quote
Old 09-09-2009, 09:24 PM   #16 (permalink)
Professor Lou, My car need state inspection sticker, I will go to the dealer and ask them to correct the fluid level with the state inspection job. But my major concern is the damage that has been done for the prolong incorrect fluid level. The E320 has transmission fluid change by the same dealer 2 years ago by different mechanic, after the fluid replacement, the transmission runs like new and very smooth. But the S500 has only improved very little. This suspicion make me have the courage to investigate the problem.
Old 09-09-2009, 09:27 PM   #17 (permalink)
loubapache's Avatar
I would not worry. Both the 722.6 and 722.9 have built in mechanisms to deal with fluid overfill (preventing whipping and foaming). While it is not a good idea to over fill, I doubt there is any damage.
Old 09-09-2009, 09:38 PM   #18 (permalink)
Thanks again for your expert opinion. It give me a peace of mind. I own an oil extractor from HFreight. I could have suck it out but I like the dealer to correct their job. I just replace my motor oil last week with the extractor. When I check the motor oil level in my E320, it is overfilled too. But I will let it go because I have to replace the oil in 1500 miles according to the FSS. I think all the leaking on the engine valve cover is resulted from the overfilled oil by the dealer.
Old 09-10-2009, 05:36 AM   #19 (permalink)
loubapache's Avatar
Ya, dealers often dump in the amount listed in the "capacities". It is better to check with the dipstick (if the car has one). At one time, dealers were overfilling the M104 engines left and right (which caused leaks) and MB had to issue TSBs to reduce oil capacity and also advise that the optimum oil level is the mid-way between MIN and MAX. I have always try not to fill oil above that level in any engine. That means I do not pour in the quantity listed in capacities. On my M104, I use about 6.5 quarts. On my M112, I use slightly less than 8 quarts.
Old 09-10-2009, 10:38 PM   #20 (permalink)
I took the car back to them today, they check the level and agreed that was 0.5 L too much and suck it out without charge after one year. Afterward, the transmission shifted batter. Actually, when they review my old invoice, they had flush the transmission with the MOC machine from California plus removed the filter and pan and repair the harness leak. That means the fluid in the converter is replaced. With the flush, the job is $100 more than the regular filter and fluid replacement. ($223). The MOC machine can flush motor oil, radiator fluid and power steering system. But I do not know those charges. Have you guy heard about it ?
DIY Mercedes 722.3 722.4 722.5 Transmission K1 Piston Spring Repair Kit Install HATTENATOR W201 190 Class 52 03-07-2010 05:14 PM
MB Transmission 722.6 & 722.9 oil change from MB Service Dawson AMG W210 E50 AMG, E55 AMG 23 11-24-2009 09:52 PM
Swaping 722.1 for 722.3 Transmission DieselBenzCanada W123 E,CE,D,CD,TD,TE Class 3 05-31-2009 11:01 PM
atlanta Mercedes 722.603 transmission - auto 5 speed - $650 atlantas420 W140 S-Class 0 10-02-2008 09:32 AM
Mercedes-Benz SLR 722 GT official dascrow Mercedes-Benz News 16 04-23-2008 06:49 AM
