Bulb H6W LL 12V 6W, Philips item # 2036LL - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 07-30-2009, 01:57 PM Thread Starter
IFS
IFS's Avatar
Date registered: May 2008
Vehicle: 00 E320 4MATIC
Angry Bulb H6W LL 12V 6W, Philips item # 2036LL
Huh, looking for this bulb in stores since this morning. No luck so far in stores like AutoZone, Advance Auto Parts, O’Reilly Auto Parts, and Philips distributors. Dealership has it in the stock and asking over 10$ for bulb size you can lose in pocket. Is there any place in Chicago area that carry on this bulb, if someone knows?
Bulb is for position lights a.k.a smaller circle light on front.
IFS is offline
post #2 of 13 (permalink) Old 07-30-2009, 02:12 PM
Yacht Master's Avatar
Date registered: Nov 2006
Vehicle: E-ZGO 53 HP., 99 E 430 sport, 04 E55 AMG, 2008 Tahoe LTZ Sold Porsche to Brother
Quoted: 47 Post(s)
Citi Lights
AKA,
12036 PHILIPS
12357-P PHILIPS
12357/P PHILIPS
12357 P PHILIPS
12357 PHILIPS
12357P PHILIPS
64132/6W/12V/BAX9S/LF OSRAM
64132/6W/12V/BAX9S OSRAM
64132/6W12V/BAX9S/LF OSRAM
64132/6W12V/BAX9S OSRAM
64132/12V/6W/BAX9S OSRAM
64132/13.5V/0.44A CEC
64132/13.5V/0.44A USA
64132/H6W/12V/6W/BAX9S/LF OSRAM
64132/H6W/12V/6W/BAX9S OSRAM
64132 CEC
64132 OSRAM
64132 USA
64132H6W12V6W/BAX9S/LF OSRAM
64132H6W12V6W/BAX9S OSRAM
68161-CP NARVA
68161/12V/6W CANDLEPOWER-INCORPORATED
68161/12V/6W NARVA
68161/CP NARVA
68161 CANDLEPOWER-INCORPORATED
68161 CP NARVA
68161 NARVA
68161CP NARVA
843117 OSRAM
883250 OSRAM
0025443194
4008321094896 OSRAM
4050300843117 OSRAM
4050300883250 OSRAM
H6W
H6W-12V-6W-BAX9S
H6W-12V/6W/BAX9S ECE
H6W-12V 6W BAX9S
H6W/12V/6W/BAX9S ECE
H6W/12V/6W/LIGHT OSRAM
H6W/12V/6W OSRAM
H6W12V6W-BAX9S ECE
H6W12V6WBAX9S
H6WATT-12-6-BAX9S ECE
H6WATT-12-6W-BAX9S ECE
H6WATT-12V-6-BAX9S ECE
H6WATT-12V-6W-BAX9S ECE
H6WATT/12/6/BAX9S ECE
H6WATT/12/6W/BAX9S ECE
H6WATT/12V/6/BAX9S ECE
H6WATT/12V/6W/BAX9S ECE
H6WATT/12VOLT/6WATT/BAX9S ECE
H6WATT 12 6 BAX9S ECE
H6WATT 12 6W BAX9S ECE
H6WATT 12V 6 BAX9S ECE
H6WATT 12V 6W BAX9S ECE
H6WATT12-6BAX9S ECE
H6WATT12-6WBAX9S ECE
H6WATT12/6BAX9S ECE
H6WATT12/6WBAX9S ECE
H6WATT12 6BAX9S ECE
H6WATT12 6WBAX9S ECE
H6WATT12V6BAX9S ECE
H6WATT12V6WBAX9S ECE
H6W - halogen light bulb lamp - donsbulbs - light bulbs lamps valve valves tube tubes
or if you want to have LEDs try
h6w bulb, great deals on eBay Motors, Electronics on eBay!
Yacht Master is offline
post #3 of 13 (permalink) Old 07-30-2009, 05:42 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 400 Post(s)
try your local NAPA parts store, but it will be at least as expensive as the dealer!
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #4 of 13 (permalink) Old 07-30-2009, 07:15 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You probably spent close to $10 in fuel going to those various retailers, or did you let your fingers do the walking? In any event, autohausaz.com apparently has any bulb you might need, now or in the foreseeable future. Order 1 or 2 of each and you should reach their minimum of $50 for free shipping. If not, throw in an oil, cabin or air filter and you will surely be there.
Musikmann is offline
post #5 of 13 (permalink) Old 07-30-2009, 07:19 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 7 Post(s)
You can find the same base
in a 4 watt at most auto stores.
Or call around to some of the metric motorcycle shops in your area. Some makes use the h6w as a side light marker bulb.
base is all that BAX9S mumbo jumbo after the wattage designation.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #6 of 13 (permalink) Old 07-30-2009, 07:26 PM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 12 Post(s)
YM gave you a long list.
Try these two: Sylvania 64132 or Philips 12036.
If you do not mind a little darker, then Sylvania 3893 (T4W) bulb could be used for the H6W.
loubapache is offline
post #7 of 13 (permalink) Old 07-31-2009, 07:45 AM Thread Starter
IFS
IFS's Avatar
I make phone call before go to store.
IFS is offline
post #8 of 13 (permalink) Old 07-31-2009, 07:46 AM Thread Starter
IFS
IFS's Avatar
Thanks a lot for all suggestions.
IFS is offline
post #9 of 13 (permalink) Old 11-09-2009, 09:52 PM
Date registered: Jun 2008
Vehicle: 2007 CLK550
Has anyone replaced the housing for this bulb? I went to replace this bulb once before and the housing had been cracked and repaired with electrical tape by the previous owner and was just shoved into place. I'd like to fix it right, but can't invest in new headlight assemblies. Any suggestions?
BAJAZEUS is offline
post #10 of 13 (permalink) Old 11-10-2009, 03:33 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
I'd suggest ebay or a wrecking yard for the assembly, I don't think the housing is a separate item from the stealer.
As far as the bulb goes, VW dealers usually have them and sell them for less than the MB dealers.
Also, if you're in a major metro area, hit a parts store that specializes in european cars, like BAP, etc. They usually will have these quirky MB bulbs, but often at prices close to the stealer. As MM says, work up an order with autohausaz and include a couple of every bulb, that way you can have spares ready to go anytime you need them. That's what I did, then I wrapped them in bubble wrap and put them in a little cheapo rubbermaid container in the trunk.
Check Codes is offline
h6w in blue :) big_mike1979 C208/A208 CLK-Class 5 06-18-2009 07:33 PM
led h6w jtbeche C208/A208 CLK-Class 3 11-19-2006 04:59 AM
FS: Philips D2R xenon HID bulb splib For Sale/Wanted/Trade/Giveaway 1 08-24-2005 08:58 PM
Charcoal Replacement and H6W xenon white bulb Black2000E430 W210 E-Class 3 06-06-2003 04:12 PM
Do these tuning shops in LA carry H6W bulbs? Anyone from the Bay area know where I can get H6W bulb Arnee C208/A208 CLK-Class 6 12-08-2001 11:45 AM
