4-Alignment, Brakes, Chassis, Exhaust, Steering, Suspension, Wheels
131K views 6 replies 2 participants last post by  raymond-
#1 · (Edited by Moderator)
NOTE: This thread pays homage to the original DIY sticky started by OBX884 and updated by Storm, Gregs210, JOE55, and Matt L to help reduce clutter and allow for more comprehensive lists of DIY procedures, tips and tricks. DIY/TIPS threads will be updated as useful threads are added to our forum. Should the moderators miss a new addition, please post a message in the DIY/TIPS - Suggestions for the DIY sticky threads
Your BenzWorld W210 Moderators and members offer their thanks to all who have contributed!
Please also visit the General DIY post for more information.
Brakes/Chassis
Brake Fluid Flush RichardM98
Using a Pressure Brake Bleeder (with pictures) G-AMG
Make Your Own Power Bleeder (with pictures) TNTRower)
Brake Rotor/Pads Replacement (with pictures) gregs210
Rear brake shoe replacement xman084
Brake Switch Replacement (ABS/ETS Warning Light) AE1K
Brake Switch Replacement - pics DannyD
Brake Switch Replacement 2
Brake Switch Replacement 3
Brake Switch Replacement 4
Parking brake adjustment
Hood Strut Replacements (with pictures) BuffaloBenz
Swaybar Bracket Repair Slingshot
#3 · (Edited by Moderator)
Wheels/Tires/Alignment
Wheels/Alignment
Alignment Tip (bigger wheels/drops/etc.) ohlord
DIY: Wheel Repair (Scuff/Curb damage) (with Pictures) Thank Gregs210 for the link
W211 wheels on W210 - important info to consider Gregs210, -raymond, loubapache
Lug Bolts - 210 bolts with 211 ball seat (Mercedes Dealer, autohausaz.com, thepartsbin.com, etc.)
Otis Inc LA/RAD hybrid lug bolts and Prestige Wheel Accessories
Tire Size Calculator
Tire Dimensions Calculator
Wheel fitment
Wheel Offset Calculator
#4 · (Edited by Moderator)
Suspension and Steering
Chassis Number? (Necessary for ordering some parts)
It's the last 6 digits of your VIN
Ball Joints - Front Lower iluvjesus
Camber and caster adjusters, front bbirdwell
Camber adjusters, rear bbirdwell
Coil Spring Removal (video of Klann Tool KL-0025) reyna7
Lower ball joint G-AMG
Outer Tie Rods Remove and Replace DIY (w/ Pictures) mikeh285
Added 3/09/2014
Power Steering Fluid Change (w/ Pictures) G-AMG
Power Steering Shaft Seal citruspilot
Rear Axle Carrier Mount (Rear Subframe Mount) Replacement Thanks to Matt Cervi, the original author of the PDF file, and member Olivier Afor finding the link.
Shock Replacement, RWD (with pictures) raymond-
Shock Replacement - front (with pictures) G-AMG
Spring Pad Part Numbers: Frank, raymond-
Front
210 321 0184 5mm
210 321 0284 9mm
210 321 0384 13mm
210 321 0484 17mm
210 321 0585 21mm
Rear
210 325 01 84 5 mm
210 325 02 84 9 mm
210 325 03 84 13 mm
210 325 04 84 17 mm
You can check the pad number by feeling the bumps on the pad itself:
Spring Perch/Top Mount FAQ's Black Stallion & Guest
Spring Perch Recall Notice (Canada Only) Guest
Spring Perch Repair (PDF, with Pictures) jrnelson
Squeaky Steering Issue (PDF, with Pictures) reyna7
SwayBar Bushing and Link R/R - front (with picture) G-AMG
SwayBar Link R/R - rear (with picture) MAE320
You have insufficient privileges to reply here.
