CV boot or Axle - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-27-2009, 08:32 PM Thread Starter
Date registered: Feb 2004
Vehicle: 01 E430 4Matic, 98 BWM M3
CV boot or Axle
I was told the passenger side CV boot was torn and needed to be replaced but now I also hear unpleasant clicking noises when I make a sharp turn...
Do I need to replace axle or just CV boot?
If I need to replace the axle and knowing what the stealer's price ($1200) for the axle kit, I'm kinda leaning toward to an aftermarket parts.
Is there any quality or any issue I need to aware of the aftermarket parts or will I be safe?
BTW, it is 01 E430 4Matic... and has about 135000 miles now.
taeandji is offline
post #2 of 7 (permalink) Old 05-27-2009, 08:36 PM
Kajtek1's Avatar
Quoted: 1167 Post(s)
The axle replacement was what I faced having still good boot.
That couple years ago lead me to buy used axles for spare and now with 4-Matic sold they are for sale. Pictures in "For sale" section.
Kajtek1 is offline
post #3 of 7 (permalink) Old 05-27-2009, 08:41 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I just went through this with my Toyota Camry. Apparently, it is easier and more economical to buy a half axle for that car than to try and replace the boot. I was told that the axle has to be broken apart, the old boot removed, and put back together before you can re-fit the new boot. There is also the chance that the CV joint will be damaged when you do this and that it was compromised by exposure to the elements and lack of grease. Mercedes could be entirely different, but I hope this helps. Lastly, there are good and bad aftermarket parts so if you take that route, research your sources carefully. Good luck.
Musikmann is offline
post #4 of 7 (permalink) Old 05-27-2009, 09:18 PM Thread Starter
Can someone recommend good aftermarket parts store?
btw, is it CV joint or drive shaft or are they the same?
taeandji is offline
post #5 of 7 (permalink) Old 05-27-2009, 09:25 PM
Kajtek1's Avatar
Drive shaft goes to the rear axlle inside center hump in the car,
CV = constant velocity joint is the pear like shape joint at the wheel.
Mercedes is not selling CV joints separately, that is why you have to buy whole axle with inner and outer CV joints.
The inner joints are having much lesser turning angle.
Kajtek1 is offline
post #6 of 7 (permalink) Old 05-28-2009, 07:31 AM
tokaj's Avatar
Date registered: Apr 2005
Vehicle: 02 ML320 01 E320 4Matic Wagon 98BMW R1100GS 2001 E55 AMG
I just bought axles for my 01 E320 4Matic from Axles Unlimited Inc (704)399-1003
ask for Dave.
Dave states that these are Mercedes Axles that they rebuild, life time warranty $229.95 each +$150 core charge. UPS is delivering these this morning, I'm having them installed today.
I will post feedback when I return from my road trip to Henderson,this weekend.
tokaj is offline
post #7 of 7 (permalink) Old 05-28-2009, 11:00 AM
fosmith's Avatar
Date registered: Jun 2008
Vehicle: 2001 E430 211K mi. Obsidian Black metallic, Ash/Orion Grey interior
Quoted: 141 Post(s)
The clicking means that, because of the torn boot, dirt has gotten inside the cv joint and destroyed it. Now you will need to replace the axle assembly. With that mileage, I would go with an aftermarket or rebuilt unit.
This is why it's good to get under the car every few months and check out things like cv and steering rack boots. These cheap boots protect expensive parts.
Fred
fosmith is offline
    CV boot kit or axle replacement? E430 4matic markwill W210 E-Class 4 06-23-2011 09:59 AM
    Rear axle outer boot toddlnrd W123 E,CE,D,CD,TD,TE Class 4 05-21-2007 07:57 PM
    Axle boot replacement tool Trevor Sarty W123 E,CE,D,CD,TD,TE Class 0 04-11-2007 05:56 AM
    Rear differential/axle boot replacement Sergio W124 E,CE,D,TD Class 7 11-14-2006 06:03 AM
    Replacing a Boot on the rear axle? panamacolin W123 E,CE,D,CD,TD,TE Class 4 09-21-2004 02:24 PM
